查看: 2490|回复: 1
RUBIN Model: RB-23K101UF
发表于: 2017-2-17 11:27:17
he Chassis / the Version: M181
Plesk Panel: LM230WF1 (the TL) (the E3)
Driver the LED (the backlight): KB6160 471R1016 467-01A2-23731G
The LED driver the PWM: MP1007ES (16)
The LED driver the MOSFET: ME12N04 (3)
The LED driver of Trans: KTC 401-9322-27411G, KTC 401-8322-27412G
The Supply the Power (the PSU): 465-01A2-18001G LYD-3 465R1013 K-56L1
The Power the PWM: LD7575 (a flyback the PWM), OB5269CP (8)
The Power the MOSFET: SW7N65
MAINBOARD: M181-B9P191-00028 MST6M181-T6S
MAINBOARD the IC: YD1517P (18), MP1482DS (8), IT6633E-P, MT4953 (8)
Tuner: the CDT-3FC2I2-36
Brand: the LG the Display
the Model: LM230WF1-TLE3
the Type: a-the TFT-the LCD of Si, Plesk Panel
's Diagonal size bed: 23.0 inch
Resolution: 1920x1080, FHD
the Display-Mode: the TN, Normally the White, Transmissive
the Active Area: 509.184x286. 416 mm
the Surface: Antiglare, the Hard coating (3H)
the Brightness: 300 the cd / m2
the Contrast the Ratio: 1000: 1
Display Colors: 16.7M (6 bit + of Hi--the FRC)
the Response Time The: 1.3 / 3.7 (Tr of / the Td)
the Frequency: 60Hz
the Lamp the Type: 4 Driver Without the CCFL pcs
the Signal the Interface: the LVDS (2 ch, 8-bit), 30 pins
Voltage: 5.0V
发表于: 2017-2-21 10:02:19
下载备用 谢谢外国朋友
GMT+8, 2024-12-24 03:04 , Processed in 0.055133 sec., 9 queries .
