查看: 3900|回复: 6
ADMIN IS ALIVE OR NOT ??
发表于: 2017-2-12 19:44:16
提示: 作者被禁止或删除 内容自动屏蔽
 楼主| 发表于: 2017-2-14 23:01:01
提示: 作者被禁止或删除 内容自动屏蔽
回复 支持 0 反对 1
发表于: 2017-2-13 00:27:18
Dear software programmers,
The ability to work with separate areas in NAND is very important as well as work with bad block. The RT809H is a really good machine but without that function it becomes totally useless for us. Please make it come true. Thanks in advance.
 楼主| 发表于: 2017-2-12 19:45:22
提示: 作者被禁止或删除 内容自动屏蔽
 楼主| 发表于: 2017-2-13 01:05:30
提示: 作者被禁止或删除 内容自动屏蔽
发表于: 2017-2-13 02:17:14
Daer Sir,
No I did not sort out the problem - RT809H cannon work with NAND properly, to say less. It  takes your software guys to work on the problem. Thousands are waiting!
发表于: 2017-5-16 01:05:56
do you think tnm5000 programmer can solved  your  problem?if you say,that programmer is perfect,i want to buy.i have rt809h but not satify ever.i also have proman.
GMT+8, 2024-11-13 06:36 , Processed in 0.056178 sec., 10 queries .
