帮忙分析下开机打印信息,是否正常?
Boot-
DRAM Calibration.
Byte 0 : DQS(1 ~ 95), Size 95, Set 45.
Byte 1 : DQS(0 ~ 95), Size 96, Set 44.
Boot
Start Cmain
calling CMain.
-----start Loader Main
Loader Main
RISC
0x54 0x00000060
0x58 0x000cfef0
0x5C 0x00000000
t8032
0x74 0x00167be0
0x78 0x00021b90
0x7C 0x00000000
==> OK
Jump to 0
DTV>Flash index :0,MenuID: 0xC8, DeviceID1: 0x40, DeviceID2: 0x16
Detect flash #0: GIGADEVICE(GD25Q32B)
HADDS1: 2011/4/5 1700
HADDS2: 2011/4/5 1826 (dds mode)
[AUD]==> before 0xf01 enable: 51fc = 0x80000000
Read partA current flag: 0X3dfffc
_rNorEEPROM Info:
-----> u4EEPSize: 0X2000
-----> u4EEPNORPartId: 0
-----> u4NORSectorSize: 0X10000
-----> u4EEPNORBlockNum: 4
-----> u4EEPPartOffA: 0X3c0000
-----> u4EEPPartOffB: 0X3e0000
-----> u4EEPNORPartCurAppendOffset: 0X3de440
-----> u1EEPBuf: 0X304c0000
General Macro Info:
-----> MAX_EEPROM_BUFFER_SIZE: 0X2000
-----> NOR_EEPROM_TIMES: 0X20
-----> DEFAULT_NOR_EEPROM_SECTOR_NUMBER: 0X2
-----> CURRENT_PARTITION_FLAG_ADDR_OFF_END: 0X4
-----> OPTIONAL_RESTRICT_AREA_SIZE: 0X3fc
-----> RESTRICT_AREA_SIZE: 0X400
-----> NOR_EEPROM_PARTITION_CNT: 0X2
-----> APPEND_UINT_BTTE_CNT: 0X4
EEPROM Partition Info:
-----> Partition ID: 0X0
-----> Partition start offset: 0X3c0000
-----> Partition size: 0X40000
No valid index found from EEPROM
=========== Nucleus ==============
Cache Mem Addr 0x001dc8e8
NonCache Mem Addr 0x301dc8e8
[SA7] vDDDSInit
[NPTV]VS_WIDTH(3) u4VPorchB(3)
[NPTV]Change u4VPorchB to (6)
[LVDS] u4Freq=72400000
[LVDS] Do Loop=12
vDrvSetOCLKClockSchemaInit.
[SA7] _fgVopllUseDDDS = True
[LVDS] u2Oclk2=0xf04
[LVDS] u2Oclk=0x1574
[LVDS]CW_Read=0x479a2a6
[LVDS]CWS_Read=0x479a2a6
[LVDS] VOPLL Initialize successful !
[NPTV]Display Init[NPTV]Video SW InitVGA Internal EDID INIT
DDCCI INIT
Zero TDC memory address
[NPTV]NOT support xvYCC
[NPTV]Video HW Init[HDMI]switch I2C write fail num =10
[NPTV]vApiVideoInit
[NPTV]Verf PE Table Passed
[NPTV]FlashPQ ID OK
[NPTV]FlashPQ Qty OK
[LVDS] vDrvLVDS7To4FifoEnable !
[NPTV]Timing 0 item 20001 value c
[NPTV]Timing 0 item 20000 value b4
[NPTV]Timing 0 item 20002 value 78
[NPTV]FlashPQ Gamma OK
T8032 start address: 169a00
wakeup Reason= 00000006
u4WakeUpReason 00000006
AC power on
set to power down
?I 'm little T8032~
