查看: 4371|回复: 2
康佳康佳LED32F2200CE主板 35018251 屏 19YT开机打印信息
发表于: 2017-2-8 07:59:52
帮忙分析下开机打印信息,正常吗?
  SPI BOOT
Console Initial OK
Maria10: BD_MST021B_10ALG_11313_64M
[MIU]: 64MB  - DDR2 800MHz
BIST_0 PASS.
77
[123456789ABC][123456789ABC]
0066
MIU Initial OK
sar input test...
MDrv_PNL_Init u32PnlRiuBaseAddr = A0200000
MDrv_PNL_Init u32PMRiuBaseAddr = A0000000
=msAPI_GPIO_RegisterGPIOMethods=
MApp_DB_LoadHDCP_KEY
HDCP_DB_BANK 0x3B
F2 C0 35 39 7A 80 F5 6E B3 36 F7 A8 25 C6 D6 3
8F E1 27 FF 1B 9F 41 C7 A6 C1 96 5A 9D E9 76 7A
74 64 8F 1A 4 69 10 45 6D B8 D0 B1 59 57 27 FB
21 54 50 AB 72 0 AB 65 51 2 5E 5E B5 1D 3 5
36 3 1 B9 DA 67 17 F1 75 1E B8 28 2D 2A 39 75
AA 0 66 75 49 3A DB 61 9F D5 9A 6D 5 D C9 A0
7B 63 A5 9B 15 F6 F9 EB CB EC 91 56 D0 EB 96 7D
50 E2 AD 57 86 9A E9 DB 82 2 B4 89 B9 24 71 D2
E3 83 85 54 70 2C A0 96 EA 95 34 27 1 D7 F0 8B
1B E3 55 91 34 D4 A5 F2 A3 B 78 D4 53 FE B6 46
72 A2 52 BD 27 E8 53 7 D2 4D E3 9 62 7E 42 76
EE 62 2E 78 71 7C 49 24 89 E6 7F B0 39 F3 A3 E7
5D 8 64 80 76 9 88 41 55 5D C 34 AA 3A 8B FA
8 D5 6 D7 84 E4 A8 89 5 F0 A7 DB 6C A4 F7 EB
89 75 F1 9D 37 67 F1 76 C8 AE 53 68 A9 1 F4 1
A7 9F 33 DF A9 E D6 50 E7 72 69 72 9 26 F2 D0
19 84 33 C4 14 48 AA D8 3A 27 B3 69 C5 9A BB 8F
13 11 AC 28 AE BA D5 97 A2 A4 53 63 73 22 D6 35
E1 0 0 2 0 0 0 0 0 6 AB A5 8F 5 0 0
GE_SetOnePixelMode
PM Wakeup by 0xFF
+++++++g_IPanel.Enable-off+++++++++= = 10
s8SN0(10) s8SN1(F)
g_u8DCOnOff = ON
+++++++g_IPanel.Enable-on+++++++++= = 33
g_u8TransientBacklight = 150
bPictrueTest == 0
22 msAPI_Logo_LoadJpeg failed
load co-processor code
not need set over scan ratio!!!!
=SET AV AV OUT SEL=
^Hotel Logotime 2s^
Disable Aeon
Disable Aeon Done
DSP code loaded successfully
#EnableEQ
----else----
=SET AV AV OUT SEL=
stGenSetting.HotelSetting.HotelInitPowerOff=1
=SET AV AV OUT SEL=
after preinit----sentesu stGenSetting.g_SysSetting.fKeypad=0
========= CUS04_ATV_MM_M10 =========
DVB-T Software Version: 0.305665
[Board]: BD_MST6M182VG_KONKA
[Panel]: KBI315A1B01
[Tuner]: MAXLINER_MxL_601
[MEMORY_MAP]: MMAP_64MB
[DRAM SIZE]: 64 MB
[FLASH SIZE]: 4 MB
[ATV]: PAL
[Mirror]: 0
[ENABLE_PWS]: 1
[ENABLE_POWER_SAVING_DPMS]: 1
[DEMO_FINE_TUNE]: DFT_STD_FULLHD_CMO216
[ENABLE_DLC]
[MWE]
[DISPLAY_LOGO]
发表于: 2017-2-8 10:30:09
这个怎么变成BIN格式的啊
 楼主| 发表于: 2017-2-9 09:31:39
haihong 发表于 2017-2-8 10:30
这个怎么变成BIN格式的啊
请教大师,应该怎么转换格式
GMT+8, 2024-12-21 14:11 , Processed in 0.052628 sec., 10 queries .
