查看: 3428|回复: 3
PHILIPS LED 55PFL7606H/12
发表于: 2017-2-8 02:24:32
Chassis/Version: Q522.2E LA
Panel: LC550EUF(SD)(F1) // LC550EUF(SD)(F2)
LED backlight: 3660L-0376A - 55 V6 Edge FHD-1 Rev1.0 1L/ R-Type
T-CON: 6870C-0369C
LED driver (backlight): integrated into PSU
Power Supply (PSU): PSL55-3-D-FULL PLDK-P021A
MainBoard: 313912364172 3139 123 64172 // 313929714971 (313912365192 WK1101.3)
IC MainBoard: PNX8541E1/2416, ISP1564HL, NAND512W3A2CN6, AD8197, ELPIDA E2516AEBC-6E
Тuner: TD1716F/BHXP-3
Remote: IR: GWA7.820.697-1(V0.6)
Brand : LG Display
Model : LC550EUF-SDF1
Type : a-Si TFT-LCD, Panel
Diagonal size : 55 inch
Resolution : 1920x1080, FHD
Display Mode : S-IPS, Normally Black, Transmissive
Active Area : 1209.6x680.4 mm
Surface : Antiglare (Haze 10%), Hard coating (2H)
Brightness : 400 cd/m2
Contrast Ratio : 1600:1
Display Colors : 16.7M/1.06B (8-bit / 8-bit + Dithering)
Response Time : 5 (G to G); 6 (MPRT)
Frequency : 120Hz
Lamp Type : WLED Without Driver
Signal Interface : LVDS (4 ch, 8/10-bit), 92 pins
Voltage : 12.0V
发表于: 2017-2-8 10:38:34
感谢楼主分享数据
发表于: 2017-2-9 18:01:41
感谢楼主分享数据
发表于: 2017-2-14 21:14:56
老大请不要说英文看不懂,我估计大家都在猜
GMT+8, 2025-3-11 14:35 , Processed in 0.074751 sec., 9 queries .
