查看: 2200|回复: 0
PHILIPS Model32PF3320 / 10
发表于: 2017-2-8 02:09:42
The Chassis / the Version: LC4.5E the AA
Plesk Panel: T315XW01 the VF
Inverter (the backlight): CIU11-T0045 of L-toko 45-54465543
Inverter the PWM: OZ9925GN (pl16n)
Inverter the MOSFET: 4511GH a dual smd.
The Supply the Power (the PSU): PLCD190P1 3122 137 23171
The Power the PWM: TEA1533AT (SOP14), L6562D (the PFC) , TEA1601T (SOP16)
The Power the MOSFET: STP20NM50FP (the PFC), STP11NM60FP, STF3NK80Z
MAINBOARD: 3139_123_60721
Brand: AUO
the Model: the VF T315XW01
the Type: a-the TFT-the LCD of Si, Plesk Panel
's Diagonal size bed: 31.5 inch
Resolution: 1366x768, a WXGA
the Display-Mode: QSV, of Black Normally, Transmissive
the Active Area: 697.685x392.256 mm
the Surface: Antiglare, the Hard coating (3H)
the Brightness: 500 the cd / m2
the Contrast the Ratio: 800: 1
Display Colors: 16.7M (8 bit-)
the Response Time The: 16/5 (Tr of / the Td); 8 (the G to the G)
the Frequency: 60Hz
the Lamp the Type: Embedded the CCFL 16 pcs (Inverter)
the Signal the Interface: the LVDS (1 ch, 8-bit), 30 pins
Voltage: 12.0V
GMT+8, 2024-12-20 02:13 , Processed in 0.053014 sec., 9 queries .
