查看: 2725|回复: 0
PHILIPS Model 20PFL4102S / 60
发表于: 2017-2-8 02:01:58
The Chassis / the Version: LC4.1E the AB
Plesk Panel: LC201V02 (the SD) (the D1)
Inverter (the backlight): LIPS the TCI-D2S the F P2005234 2010BL07417001857 BL6L60P3 Bed and
Inverter the PWM: UBA2070T (16n) Sq. BIT3193G (16)
Inverter the MOSFET: 40P03GI, 40T03GP
The Supply the Power (the PSU): the DAC-12M019 AOF 3139 128 77611 LIPS
The Power the PWM: TEA1533AP, L6562D (the PFC) , TEA1532
The Power the MOSFET: P4NK80, P10NK60, BSP100, D5NM3 (chip), SRA1030 (diod) // 40T03GP , 40P03GI.
MAINBOARD: 3139_123_60192 3139 123 60192
MAINBOARD the IC: the CPU: TDA15021H1 / N1C91; Scaler: GM5221H-LF
Tuner: UR1316S / A
The Remote: rc1683803 / 01h aw 3139 238 11772
The PHILIPS
the Model: 20PFL4102S / 60
Plesk Panel: LC201V02 (the CD) (the B1)
The Supply the Power (the PSU): P2005234 3341 000 10074 BL6L60P3LPL
The Power the PWM: TEA1533AT, UBA2070T, L6562D (the PFC)
The Power the MOSFET: P10NK60ZFP, P4NK80ZFP
Tuner: UV1318S / the AI of H-3
GMT+8, 2024-12-20 01:42 , Processed in 0.058744 sec., 9 queries .
