查看: 1844|回复: 0
DAEWOO Model DSL-15D1T
发表于: 2017-2-8 01:54:00
The Chassis / the Version: the SL-100P
Plesk Panel: LC151X01-the C3Inverter (the backlight): the DS-1007NF
The Supply the Power (the PSU): the Adapter
The Power the PWM: ICE2A165 (the Standby), 1M0680
MAINBOARD: the SL-100P the MainMAINBOARD the IC: the MCU: PW166B-10T, SAA7118E, SAA5264, DS90C385; Sound processor MSP3410G; Audio: LA4635
Tuner: TCPQ9091PD27E (the SEM
Brand: the LCD LG.Philips
the Model: the C3-LC151X01
the Type: a-the TFT-the LCD of Si, Plesk Panel
's Diagonal size bed: 15.1 inch
Resolution: 1024x768, the XGA
the Display-Mode: the TN, Normally the White, Transmissive
the Active Area: 307.2 mm x230.4
Surface: Antiglare (Haze 13%), Hard coating (3H)
Brightness: 400 cd / m2
Contrast Ratio: 350: 1
Display Colors: 16.2M (6 + FRC bit-)
Response Time: 7/18 (Tr / the Td)
the Frequency: 60Hz
the Lamp the Type: 4 Driver Without the CCFL pcs
the Signal the Interface: the LVDS (1 ch, 8-bit), 20 pins
Voltage: 5.0V
GMT+8, 2025-1-9 16:38 , Processed in 0.055602 sec., 14 queries .
