查看: 2257|回复: 0
DAEWOO Model DLP-32C3
发表于: 2017-2-8 01:48:13
The Chassis / the Version: SL223P
Plesk Panel: LTA320WT-the LF2
CON-T: 320WSC4LV.5.9 (8)Inverter (the backlight): INVFT320A rev1.0 Inverter the PWM: BD9882F (16pin)
Inverter the MOSFET: AP4525GEH
Inverter of Trans: of IT-133-06AAThe Supply the Power (the PSU): W20NM60
MAINBOARD: 4859813793_03 SL223P (the MP) A.DGGT72E490
MAINBOARD the IC: the CPU: the SVP-PX66, K4D263238I-50; EEPROM; 24C32L1; Sound: MSP 4610K D6
Tuner: FQ1216ME / IH-5
Brand: the SAMSUNG
the Model: LTA320WT-the LF2
the Type: a-the TFT-the LCD of Si, Plesk Panel
's Diagonal size bed: 31.5 inch
Resolution: 1366x768, a WXGA
the Display-Mode: the S-the PVA, of Black Normally, Transmissive
the Active Area: 697.68x392 mm .26
the Surface: Antiglare (Haze is 44%), the Hard coating (3H)
the Brightness: 500 the cd / m2
the Contrast the Ratio: 1200: 1
Display Colors: 16.7M (8-bit), CIE1931 72%
the Response Time The: 8 (G to the G)
the Frequency: 60Hz
the Lamp the Type: Embedded-scan FFL (Inverter)
the Signal the Interface: the LVDS (1 ch, 8-bit), 30 pins
Voltage: 5.0V
GMT+8, 2025-1-9 17:11 , Processed in 0.051732 sec., 9 queries .
