查看: 3288|回复: 5
probleme emmc isp
发表于: 2017-2-2 14:41:38
Hello
I have rt809h. All it works. (Nand .nor vga). But with emmc isp i can not
I have tested more than 5 times with different devices.
I have chek .usb voltage detection .usb 4.61.vdd 3.01
I test the rt809h with the self test,all is well
I have to remove emmc, direct isp ,same problem.Why i cant read the emmc with the isp ????
发表于: 2017-2-2 15:58:12
USB power supply not working properly, please insert to the back of the computer chassis USB port or external power 9-12V1A.
 楼主| 发表于: 2017-2-2 19:20:36
9-12V1A d'alimentation externe
发表于: 2017-2-2 19:24:10
电脑usb口供电不足??????
 楼主| 发表于: 2017-2-2 19:34:35
with 11V1A d'alimentation externe
 楼主| 发表于: 2017-2-2 19:51:11
can you make screenshot a USB voltage test?
with usb cable and  external power 9-12V1A
GMT+8, 2024-12-26 19:50 , Processed in 0.062073 sec., 11 queries .
