查看: 2238|回复: 0
Sitronics LCD-2770
发表于: 2017-2-1 11:48:16
Brand: the CMO
the Model: L01-V270B1
the Type: a-the TFT-the LCD of Si, Plesk Panel
's Diagonal size bed: 27.0 inch
Resolution: 1366x768, a WXGA
the Display-Mode: the Super the MVA, of Black Normally, Transmissive
the Active Area: 596.259x335. 232 mm
the Surface: Antiglare, the Hard coating (3H)
the Brightness: 550 the cd / m2
the Contrast the Ratio: 1000: 1
Display Colors: 16.7M (8-bit), CIE1931 75%
the Response Time The: 8 (the G to the G)
the Frequency: 60Hz
the Lamp Type: Embedded the CCFL 14 pcs (Inverter)
the Signal the Interface: the LVDS (1 ch, 8-bit), 30 pins
Voltage: 5.0V
Plesk Panel: V270B1-L01
MAINBOARD: GLK7.820.004-J02
MAINBOARD the IC: the CPU: the F2 VCT40X3R 000; Eeprom: 24C64, 24c08
Tuner: KSH-148DEA
GMT+8, 2025-1-9 16:58 , Processed in 0.067447 sec., 9 queries .
