查看: 2012|回复: 1
创维32e70rg打印信息UBI error是什么情况
发表于: 2017-1-25 19:03:13
2017-1-25, 18:47:24
COM4, BaudRate:115200 bps, RXD: VGA->12,TXD: VGA->15, Printed by RT809F:
UART_115200
BIST0-OK
BIST1-OK
[0123456789][0123456789A]-45
[0123456789A][0123456789]-54
_nPD
U-Boot 1.1.6 (Aug 12 2010 - 16:09:17)
Board: MSTAR TITANIA (CPU Speed 504 MHz)
DRAM:  0x8000000
Skipping flash_init
Module: KEYPAD USB FAT NAND UBI UBIFS NET EEPROM JFFS2 LOGO
NAND:  nand_bbt: searching bbt....Bad block table found at page 65472, version 0x01
nand_bbt: searching bbt.....Bad block table found at page 65408, version 0x01
nand_read_bbt: Bad block at 0x00800000
nand_read_bbt: Bad block at 0x01660000
nand_read_bbt: Bad block at 0x03120000
nand_read_bbt: Bad block at 0x03420000
nand_read_bbt: Bad block at 0x07260000
128 MiB
In:    serial
Out:   serial
Err:   serial
Net:   No ethernet found.
MSVC00B000100100222324DA:100726T
Set MIU0 group priority:c9.....
Set MIU1 group priority:c9.....
Change MIU0 select.....
Group0:d80   Group1:88    Group2:200   Group3:f1
Change MIU1 select.....
Group0:4200  Group1:e00   Group2:30    Group3:4000
cmd: md.b 0x80200000 0x1
80200000: ff    .
80200000: 5a5aa5ff    ..ZZ
.ndata_1[7fa]--->:ff
2.defatult_set is:165
3.*ucp is:255
keypad_pressed_1 is:0
keypad_pressed_2 is:0
1.MSAPI_WDT_StartHit any key to stop autoboot:  0
cmd: md.b 0x874bfef8 0x1
874bfef8: 01    .
cmd: md.b 0x874bfef9 0x1
874bfef9: 00    .
0x00220000-0x072c0000 : "mtd=3"
UBI error: ubi_scan_add_used: two LEBs with same version 1
UBI error: ubi_init: cannot attach mtd0
UBI error: ubi_init: UBI error: cannot initialize UBI, error -22
UBI init error -22
load splash resoure failed!!
2.MSAPI_WDT_Clear0x00220000-0x072c0000 : "mtd=3"
UBI init error -22
Error, no UBI device/partition selected!
## Booting image at 81000000 ...
Bad Magic Number
3.MSAPI_WDT_Stop<< MStar >>#
发表于: 2017-1-25 19:18:56
什么东东.000000000000000000000000000
GMT+8, 2024-11-27 16:42 , Processed in 0.592877 sec., 9 queries .
