查看: 2570|回复: 1
BBK LED the Model: LEM2682 LEM2682DT
发表于: 2017-1-23 01:35:05
The Chassis / the Version: MSTV2407-ZC01-01
Plesk Panel: V260B2-LE11 Rev.C1
CON-T: T-con HM185WX3-400
Driver the LED (the backlight): integrated Into MAINBOARD
The LED driver the PWM: AP3608E
The Supply the Power (the PSU): integrated Into MAINBOARD
The Power the PWM: OB2273 (6 pin, analog LD7536 or SG6848)
MAINBOARD: MSTV2407-ZC01-01 // MSDV3213-ZC01-01
MAINBOARD the IC: the CPU: the LF-MST6E182VG-the Z1, the SPI the flesh: the Winbond 25Q32BVS1G
Tuner: tuner F35WT-2A-the E
The Remote: the RC-LEM100
发表于: 2017-1-23 10:21:54
  This is a rare model around me. I may need it at sometime.Thank you.
GMT+8, 2025-1-9 16:50 , Processed in 0.048202 sec., 9 queries .
