楼主: lixiaoning
有谁用RT809H加MSTV_TOOL写创维8S16引导成功的,分享一下!
发表于: 2017-7-14 15:16:22
admin 发表于 2017-7-13 18:49
创维的升级指导书,少写了一个关键步骤,先在SecureCRT软件、串口连接下按回车,CPU停止运行,然后再打开MS ...
F或H写此8S16的机芯是用自主软件还是官方软件,MBOOT程序是厂家提供的,还是读取的,如果是厂家提供的,那会不会又不能用?
发表于: 2017-7-15 08:44:40
路过  路过    过来学习学习
发表于: 2017-7-15 11:30:06
xuex学习学习
发表于: 2017-7-24 17:34:46 来自手机
哪位师傅能提供一下用RT809H编程器备份的8S16机芯的NAND数据,我把一台创维42E360E机子升级成砖头了,看看有希望恢复活力吗。
发表于: 2017-7-31 10:51:07
下面是8S16机芯正常的打印信息
2017-7-28, 10:40:19
COM4, BaudRate:115200 bps, RXD: VGA->12,TXD: VGA->15, Printed by RT809F:
UART_115200
BIST0-OK
[123456789A][123456789A][123456789AB][123456789AB]-5566
U[AT][MB][start ub][387]
U-Boot 2011.06 (Oct 16 2014 - 13:43:46)
DRAM:  256 MiB
Hello U-Boot
Stack Pointer at: 87e3d3c0
uboot held at [8f000000~90000000]
Now running in RAM - U-Boot at: 871f0180
NAND:  DMA MODE
[NC_Init]        SDR NAND is detected
CIS is found @Blk0
FCIE is set to 54MHz
128 MiB
*** Warning - set default for mtdparts, using default environment
Creating 1 MTD partitions on "nand0":
0x000000640000-0x000000840000 : "mtd=2"
Bad block table found at page 65472, version 0x01
Bad block table found at page 65408, version 0x01
nand_read_bbt: Bad block at 0x000006000000
nand_read_bbt: Bad block at 0x000007540000
UBI: attaching mtd1 to ubi0
UBI: physical eraseblock size:   131072 bytes (128 KiB)
UBI: logical eraseblock size:    126976 bytes
UBI: smallest flash I/O unit:    2048
UBI: VID header offset:          2048 (aligned 2048)
UBI: data offset:                4096
UBI: attached mtd1 to ubi0
UBI: MTD device name:            "mtd=2"
UBI: MTD device size:            2 MiB
UBI: number of good PEBs:        16
UBI: number of bad PEBs:         0
UBI: max. allowed volumes:       128
UBI: wear-leveling threshold:    250
UBI: number of internal volumes: 1
UBI: number of user volumes:     1
UBI: available PEBs:             1
UBI: total number of reserved PEBs: 15
UBI: number of PEBs reserved for bad PEB handling: 2
UBI: max/mean erase counter: 9/6
NAND read: device 0 offset 0x180000, size 0xa8
168 bytes read: OK
Volume "MPOOL" found at volume id 0
UART BUS OFF!!UART_115200
BIST0-OK
U[AT][MB][start ub][390]
DRAM:  256 MiB
Hello U-Boot
NAND:  DMA MODE
CIS is found @Blk0
128 MiB
168 bytes read: OK
UART BUS OFF!!
发表于: 2017-8-14 16:31:21 来自手机
难道CPU和程序有ID检验?启动有看打印信息提示么?
 楼主| 发表于: 2017-9-22 23:23:06
我的没搞好,我把主板都拆件了,我把其他在好板上拷贝下来的NAND数据传上来吧!感谢老大和各位师傅的回贴!让我有看到了论坛的希望,不会让我的贴石沉大海,再次谢谢! RT809您值得拥有!!
发表于: 2017-10-24 10:46:11
小罗--强辉电子 发表于 2017-7-11 19:08
前一阵子有一台电视,卡LOGO,进不去,跟售后要了升级软件,里面包含(NAND.BIN,  U盘升级文件,软件发放 ...
老师 可以把备份NADA数据分享一下吗,谢谢啦
发表于: 2017-10-24 10:48:26
还想请教一个问题 , 串口关闭了, 命令怎么打开呢
发表于: 2017-10-24 21:24:36
下载了楼主备份的NADA数据·刷上去·故障不变·停在LOGO`
用工装升级引导·主程序后·顺利进入系统
我把修好后的NADA数据取下读出·在装回`开机还是停在LOGO`
这个机芯的NADA编程器备份出来的·用编程器写进去的是不可行的· 这个是怎么回事呢·
GMT+8, 2024-12-23 19:15 , Processed in 0.065893 sec., 9 queries .
