查看: 4557|回复: 6
No K9GAG08UOE list RT809H !!!
发表于: 2017-1-17 03:56:41
No K9GAG08UOE list RT809H   Is there a problem with the handling of the memory by the programmer or just disappeared from the list?
发表于: 2017-3-11 16:52:10
add a function to avoid wrong block
Please support your admin topic
发表于: 2017-1-24 22:07:44
choose "nand_auto, speaking, reading and writing", or "nand_id" check the chip ID, then add your own model test, speaking, reading and writing.
发表于: 2017-2-9 20:30:32
Dear manufacturers. I am sorry for writing in English. I do not speak Chineese.
I just bought RT809H. I tryed to write K9GAG08UOE but could not because of bad blocks. I tried many chips and all of them contain bad blocks as well.
The RT809 does not work with bad blocks. Is there any possibility to make it happen in the nearest future. Thanks in advance.
发表于: 2017-2-9 21:02:04
We need the software to avoid bad blocks. Please add this function.
发表于: 2017-3-11 15:33:29
You can tell for this programmer can add function avoid bad block?
你可以告诉这个程序员可以添加函数避免坏块?
发表于: 2017-6-9 14:28:15
We need the software to avoid bad blocks. Please add this function      :'(:'(:'(:'(:'(:'(:'(:'(:'(:'(:'(:'(:'(:'(:'(:'(:'(:'(:'(:'(:'(:'(:'(:'(:'(:'(:'(:'(
GMT+8, 2024-11-25 13:44 , Processed in 0.055015 sec., 11 queries .
