查看: 2393|回复: 6
Leroy T.VST59S.81 1920_1080
发表于: 2017-1-12 02:03:43
发表于: 2017-3-7 01:06:13
many thanks for you
回复 支持 0 反对 1
发表于: 2017-1-12 10:22:44
  Thank you so much Mr. Ay for your firmware.I found many firmware that you had uploaded again and again.
 楼主| 发表于: 2017-1-16 01:23:28
wim 发表于 2017-1-12 07:22
Thank you so much Mr. Ay for your firmware.I found many firmware that you had uploaded again and a ...
its all new brother i copy with rt809h+f myself for all brother
发表于: 2017-1-16 04:10:55
Thank you SO much for your firmware
发表于: 2017-2-17 12:12:39
    Hello Mr.Ayyan,
Thank you for your reply.I also want to know different function between RT809F and RT809H.I have 809F only.
What is the better function of RT809H.Thank in advance.
 楼主| 发表于: 2017-2-21 23:20:38
for led rt809f bater
GMT+8, 2024-12-24 09:20 , Processed in 0.056458 sec., 10 queries .
