楼主: imperpl
thgbmbg5d1kbait CRC ERROR
发表于: 2017-1-6 21:37:53
1: connections within 10 cm as soon as possible.
2: the power supply had better use the power of television itself.
3: if use of programming power, it is better to disconnect 3.3 V power supply with master.
 楼主| 发表于: 2017-1-7 02:13:49
1 - connections are short (about 8cm) - also used another cable set
2 - I should try to read/write while TV is in standby condition?
3 - I've disconnected 3.3V from master (and also 1.8V) and nothing changed.
@Wiesiu o które rezystory Ci chodzi.
发表于: 2017-1-7 16:07:40
Can be powered from another location .
发表于: 2017-1-7 20:49:33
2 - I should try to read/write  ...
The current capacity of VCC is not enough,you can disconnect the DDR power supply,then connect VCC to TV mainboard,  or disconnect VCC and using the original power supply board.
发表于: 2017-1-7 21:02:28
TV must be in standby mode, if can ensure normal power of EMMC, the power of the other chips can be disconnected, including the master.
 楼主| 发表于: 2017-1-7 23:26:01
It's a problem with programmer itself for sure.
I borrowed second one programmer (RT809H) from my friend and everything is fine.
There is one difference, my friend has PCB V1.70, my is PCB V1.60.
Please help me...
001:  Serial number:--------------  ,PCB V1.70,Boot V1.00
002:  Point "read" will pop up "save" dialog box, "write" will pop up the "open" dialog box.
003:  The currently selected:EMMC_AUTO_ISP
004:  Download device programming algorithm......
005:  Algo update OK
006:  >------------------------------------OK---------------------------------------<
007:  VCCIO: 1.8V
008:  eMMC OCR: C0FF8080
009:  eMMC CID:  110100303034474530009492342141
010:  eMMC CSD: D05E00320F5903FFFFFFFFE7924000
011:  Chip ID:00010011,Chip Name:004GE0
012:  Chip Size: User=3776MB,Boot1=Boot2=2048KB,RPMB=512KB.
013:  D:\RT809H\EMMC_AUTO_ISP_20170107_161320\EMMC_AUTO_ISP_20170107_161320
014:  Start reading chip......
015:  .EXT_CSDRead successful, file saved.
016:  .BOOT1Read successful, file saved.
017:  .BOOT2Read successful, file saved.
018:  RPMBRead successful, file saved.
019:  .Start to read the user area data and save, large capacity, please be patient ... ...
 楼主| 发表于: 2017-1-9 16:35:47
How can I fix it?
发表于: 2017-9-25 23:48:41
hello ,i have the same problem pleas need help
发表于: 2018-2-17 21:02:17
CONNECT THE GNG PIN AS NEAR AS YOU CAN TO THE EMMC
发表于: 2018-2-22 12:55:02
DEAR ADMIN 007 I HAVE PURCHASE RT809H 8MONTH AGO HKLRF.COM BUT MY PROGRAMER PCB VERSION 1.60 AND MY FRIEND PURCHASE 1OMNTH AGO NEW RT809H HIS PROGRAMER PCB VERSION 1.70 SO MY PROGRAMER EMMC REDING TIME OUT ERROR SHOE BUT MY FRIEND PROGRAMER SAME SOCKET SAME LAPTOP USE EMMC READ PERFACTLY OK SO HOW TO UPDATE MY PROGRAMER WITH PCB VERSION 1.70 AND NEW UPDATE VERSION V.1.80 PLEASE SOLVE MY PROGRAMER PROBLEM another west my money and my programer you update and hardwer changing please send me pdf file another you send me your addres i wil send my programer your tecnical team and r&d team reserch what happend with my programer please send my mail id prakashshubh@gmail.com
GMT+8, 2024-11-25 16:32 , Processed in 0.056694 sec., 10 queries .
