001: the Serial Number The at The: -------------, at The V1.60 the PCB, the Boot V1.00 at The
002: Point "at The the Read" by Will the POP up "at The the Save" Dialog Box, "at The the Write "by Will up at The AT the POP." the Open "Dialog Box
003: Rate the this at The AT at The Page Rate this page Currently the Selected: EMMC_AUTO_ISP
004: the Download Device Programming at The algorithm ......
005: the Update at The Algo the OK
006:> --- -------------- ------------------- OK ---------------- --------- -------------- <
007: the VCCIO at The: 1.8V
008: the CRC error at The CSD: 3D-7F
009: the VCCIO at The: 3.3V
010: the CID at The the CRC error at The: 33-7F
011: the VCCIO at The: 3.3V
I was able to read and write. Now i can't. thgbmbg5d1kbait emmc.
Checked on 3 motherboards. Boards are fully working.
I'm able to read KLM4G1FE3B-B001 on another motherboard, so RT809H works.
