查看: 3837|回复: 4
海信老LED39K20D故障打印信息求助
发表于: 2017-1-4 17:05:19
20金钱
问题是不开机求助大神们,
 楼主| 发表于: 2017-1-4 17:30:21
2017-1-4, 16:39:2
COM4, BaudRate:115200 bps, RXD: VGA->12,TXD: VGA->15, Printed by RT809H:
0xa(0x46) second passed...
0x14(0x50) second passed...
0x1e(0x5a) second passed...
Pon
IVR_OFF
Loop 0x0 end
REG012c:0x2379beef final
Hellowold01256@216p
ABCDEFGHIPP#NAND boot
b806012c = 2379beef
ISO_INT_SR = 0
ISO5280 wait5280 wait_INT_EN = 20
b806012c = 2379beef
bisr_flag=ffffffff
SCPU : Finish BISR testing scpu_bisr1_st1 :done
ACPU : Finish BISR testing acpu_bisr_st1:done
VCPU : Finish BISR testing vcpu_bisr_st1:done
VDEC : Finish BISR testing BIST_TEST1:done
load bbt...load factory to (addr 0x81a00000)...
pp 0 okpp 1 okpp_ok = 3
current_pp = 1 seq_num = 3254 tarsize = 2400
read factory from 81a00000 tarsize = 9216
#@#[cfyeh-debug] env_init(1378)
name=AMP_I2C ppcb_enum.Name=AMP_I2C, ppcb_enum.info=1
name=AMP_DEVICE_ADDR ppcb_enum.Name=AMP_DEVICE_ADDR, ppcb_enum.info=1b
name=PIN_AMP_MUTE ppcb_enum.Name=PIN_AMP_MUTE, ppcb_enum.info=1010c04
name=PIN_AMP_RST ppcb_enum.Name=PIN_AMP_RST, ppcb_enum.info=10d04
*****info_boot*****
REALTEK ROM Monitor, Revision 0011.5340.0002.
Copyright (c) Realtek Semiconductor Corp. - All Rights Reserved.
For a list of available commands, type 'help'.
Compilation time /version=      Nov 22 2013  18:27:15  /0011.5340.0002
MAC address =                   00.11.22.33.44.55
Processor Company ID/options =  0x01 (MIPS Technologies, Inc.) / 0x00
Processor ID/revision =         0x90 / 0x70
Endianness =                    Little
Flash memory size =             128 MByte
SDRAM size =                    128 MByte
First free SDRAM address =      0x800bb000
name=PIN_KEYPAD_MENU ppcb_enum.Name=PIN_KEYPAD_MENU, ppcb_enum.info=9b000001
Press 'ESC' to Monitor mode
b8060120 = 0
b8060120 = 0
b8060120 = 0
b8060120 = 0
b8060120 = 0
b8060120 = 0
b8060120 = 0
b8060120 = 0
b8060120 = 0
b8060120 = 0
b8060120 = 0
b8060120 = 0
b8060120 = 0
b8060120 = 0
b8060120 = 0
b8060120 = 0
b8060120 = 0
b8060120 = 0
b8060120 = 0
b8060120 = 0
b8060120 = 0
[DEBUG_MSG] fw_entry[0] offset = 0x1020000 length = 0x4d98ec (paddings = 0x4e0000)
[DEBUG_MSG] fw_entry[1] offset = 0x1500000 length = 0x168888 (paddings = 0x180000)
[DEBUG_MSG] fw_entry[2] offset = 0x1680000 length = 0x1bb070 (paddings = 0x1c0000)
[DEBUG_MSG] fw_entry[3] offset = 0x1840000 length = 0xe2b6 (paddings = 0x20000)
[DEBUG_MSG] fw_entry[4] offset = 0x1860000 length = 0x1ffd1 (paddings = 0x20000)
[DEBUG_MSG] fw_entry[5] offset = 0x1880000 length = 0x1ffd1 (paddings = 0x80000)
[DEBUG_MSG] fw_entry[6] offset = 0x1900000 length = 0x1ffd1 (paddings = 0x80000)
Linux Kernel:
        FW Image  to 0x80100000, size=0x4d98ec
Audio FW:
        FW Image  to 0x81c00000, size=0x168888
Video FW:
        FW Image  to 0x81e00000, size=0x1bb070
        FW Image  to 0x83000000, size=0xe2b6
Video data(1):7083
        FW Image  to 0x83700000, size=0x1ffd1
REG32(Audio_Mute_GPIO)=0x0
panel_init_1st
panel_init  panel->iCONFIG_DISPLAY_PORT = 0
panel_init  LVDS_4_PORTS_INDEX = 0
panel_init  LVDS_4_PORTS_MAPPING_TABLE[LVDS_4_PORTS_INDEX] = 123
DispI : Finish BISR testing IBUFBISR:done
DispI : Finish BISR testing LineBUFBISR:done
DispI : Finish BISR testing SPNRBISR:done
DispD: Finish BISR testing ShpBISR:done
GDMA : Finish BISR testing GDMABISR:done
5280Go 5280Go panel_init_2nd
set w[aViOt]  uFso=6r0c0e0 0D0T,G  cFuRrCre
nt
[=27V4O8]1S6y5n3G
e
n
= 0x80000004
[vo] Vodma(1) disable
[vo] VODMA(1) ForceBG(0)
VP_PowerOnVideo
VMM create  0x007e0000
VBM: configured to SD!
WARNING[1]:[vo] UpdateChannel: sync/(dtv/mvc/rdy) 0/(0/1/1)
WARNING[1]:VO: don't support this API line 98
POV: image filter testing
VBM: configured to HD!
POV: request Buffer, Y_BufID = 0
POV: request Buffer, C_BufID = 1
POV: image filter testing Y_bufID 0, C_BufID 1
(IMG) JPEG detect!!IMG_DEC: Create Filter fmt 0
POV:SE_SCALER: base0  0x82f60000, sz0  0x00400000,base1  0x83360000, sz1  0x00400000IMG_DEC: send Decode cmd to Dec
IMG_DEC: send cmd to Scaler
~jpg buf 6815744
(JPEG_THUMB) L:1235, size 3, start 1905, length 1739!!
(Adobe) set saw_Adobe_marker TRUE!!
(THUMB) IS USING THUMB 0, w 160, h 90, tgt_w 1280, tgt_h 720!!
(Adobe) set saw_Adobe_marker TRUE!!SE_SCALER: MPO 1 0
IMG: 0, 0, 1920, 1280, 1080, 720
WARNING[1]:SE_SCALER: (h-scal) SE (task id = 30) isn't complete
IMG_DEC: destroy
SE_Scaler_Destroy
POV: image filter testing DONE
[VO] Force DTG FRC
[VO]SynGen= 0x80890004
[vo] ipg1080p_frc_fhd_d[BiObyOTp_aAIssO][ !0!]!
0
xN3cU0L8bL 8=0=0
p
[BtOSOTl_rAVoIIOn][f1o
S h o0x3w5S08ti0el0l4P
ic[tBOuOrT_eA~IO~]
[2
] W 0AxR24090N2I0N0
[GB[O1O]:T_POAVIO:] [W3a] i 0xt adsy090s0te0m0
t
[oB OOST_AITOOP]  PEorrowr!e magri co_nun mbVeird =e o! 0x3(cbV0i8bd80e0o
D
o[nAeI O2_PA)T
H]
use default setting!
[AIO_PATH] src_sel_scart1    =  0x00000004
[AIO_PATH] src_sel_headphone =  0x00000001
[AIO_PATH] src_sel_pcm_dac0  =  0x00000001
[AIO_PATH] src_sel_pcm_dac1  =  0x00000004
init TAS5707
[ao_Init] ver_C
HDMI Raw Enable: MPG AC3 DTS MPEG2 AAC DDP WMAPRO MLP
SPDIF Raw Enable: MPG AC3 DTS MPEG2 AAC DDP WMAPRO MLP
Force 2ch Format: DTS DTSHD AC3 DDP MLP AAC WMAPRO
No Power On Music
[A] SetAudioDone to addr  0xa0001415 value  0x00000002
WARNING[1124417]OV: Wait system to STOP Power on Video!(bVideoDone 2)
WARNING[1070272]OV: Wait system to STOP Power on Video!(bVideoDone 2)
WARNING[1070422]OV: Wait system to STOP Power on Video!(bVideoDone 2)
WARNING[1070227]OV: Wait system to STOP Power on Video!(bVideoDone 2)
WARNING[1070351]OV: Wait system to STOP Power on Video!(bVideoDone 2)
WARNING[1070344]OV: Wait system to STOP Power on Video!(bVideoDone 2)
WARNING[1070223]OV: Wait system to STOP Power on Video!(bVideoDone 2)
WARNING[1070389]OV: Wait system to STOP Power on Video!(bVideoDone 2)
WARNING[1070224]OV: Wait system to STOP Power on Video!(bVideoDone 2)
WARNING[1070319]OV: Wait system to STOP Power on Video!(bVideoDone 2)
WARNING[1070325]:POV: Wait system to STOP Power on Video!(bVideoDone 2)
WARNING[1070304]:POV: Wait system to STOP Power on Video!(bVideoDone 2)
WARNING[1070405]:POV: Wait system to STOP Power on Video!(bVideoDone 2)
WARNING[1070351]:POV: Wait system to STOP Power on Video!(bVideoDone 2)
WARNING[1070429]:POV: Wait system to STOP Power on Video!(bVideoDone 2)
WARNING[1070296]:POV: Wait system to STOP Power on Video!(bVideoDone 2)
WARNING[1070379]:POV: Wait system to STOP Power on Video!(bVideoDone 2)
WARNING[1070339]:POV: Wait system to STOP Power on Video!(bVideoDone 2)
WARNING[1070247]:POV: Wait system to STOP Power on Video!(bVideoDone 2)
WARNING[1070372]:POV: Wait system to STOP Power on Video!(bVideoDone 2)
WARNING[1070301]:POV: Wait system to STOP Power on Video!(bVideoDone 2)
WARNING[1070302]:POV: Wait system to STOP Power on Video!(bVideoDone 2)
WARNING[1070341]:POV: Wait system to STOP Power on Video!(bVideoDone 2)
WARNING[1070229]:POV: Wait system to STOP Power on Video!(bVideoDone 2)
WARNING[1081092]:POV: Wait system to STOP Power on Video!(bVideoDone 2)
WARNING[1110650]:POV: Wait system to STOP Power on Video!(bVideoDone 2)
WARNING[1083618]:POV: Wait system to STOP Power on Video!(bVideoDone 2)
发表于: 2017-1-4 23:58:01
检查主板供电。
发表于: 2017-1-7 11:50:43
No Power On Music没有电源
发表于: 2017-1-13 00:00:18
查看保险电阻
GMT+8, 2024-12-22 15:51 , Processed in 0.052849 sec., 7 queries .
