查看: 6863|回复: 18
PANEL LTF320AP08 problem
发表于: 2017-1-3 08:12:53
All volts are normal .
Tcon- 320AP08S4LV0.3
CKV1 7.15v
CKVB1 7.21v
STVP -12v
CKVB2 7.7v
CKV2 7.8v
STV 0v
CPV1 2.56v
CPV2 2.56v
VDD1C 3.26v
VDDS 3.26v
VCOMS4 6.85v
VCOMG2 6.85v
AP2ON 1.01v
AP2OP 0.98v
AP2EN 1.02v
AP2EP 0.98v
TEST2 0v
T3 1v
T4 1v
VCOMS3 6.85v
VSS 8.0v
VDD3_3 3.26v
VOFFE -10.8v
PG 3.25v
AVDD 14.92V
LATE 27.3v
IN 12.08v
VIN 12.08v
APSY 0.15v
INV_V 1.62v
INV_H 1.62v
TRDY 3.24v
DCC 0v
ACC 0v
RST 3.18v
WPP 3.25v
SCL 3.25v
SDA 3.25v
VDDOP 3.24v
VR 6.84v
VCOMS2 6.85v
T1 0v
T2 0v
AP1ON 1.03v
AP1OP 0.98v
AP1EN 1.03v
AP1EP 0.98v
TEST1 0v
VCOMG1 6.85v
VCOMS1 6.86v
发表于: 2017-1-8 03:50:23
glass replacement
回复 支持 0 反对 1
发表于: 2017-1-3 09:40:28
   Thank you very much for tech-sharing.
发表于: 2017-1-3 12:19:31
Is the LCD screen is damaged
发表于: 2017-1-4 21:09:46
Thank you sharing
发表于: 2017-1-8 03:47:27
Thank you sharing
发表于: 2017-1-8 13:35:43
Thank you sharing
发表于: 2017-1-8 22:48:35
楼主这样量电压法,不累吗
发表于: 2017-1-9 11:15:01
应该是外国朋友  咱看不懂 不懂英语
发表于: 2017-1-9 14:29:08
量这么多电压结果是个 伤心(三星)屏,唉!
GMT+8, 2024-12-19 20:21 , Processed in 0.056858 sec., 11 queries .
