查看: 3736|回复: 7
长虹UD42C6080id救砖
发表于: 2016-12-24 15:58:35
一台UD42C6080id安卓智能电视,在U盘升级过程中小区断电导致变砖,通电开机无任何反应。
估计MBOOT启动程序和EMMC主程序都已损坏。
用RT809F编程器写入同型号正常机器的MBOOT程序后,通电开机,呼吸灯和屏幕背光亮起,呼吸灯不停闪烁,说明MBOOT已成功修复。
插入装有升级文件的U盘,不能进入U盘升级模式,一直停留在黑色背景和呼吸灯闪烁状态。
用RT809F编程器查看启动信息,看到如下输出:
  1. ......
  2. U-Boot 2011.06 (Apr 25 2014 - 13:45:04)
  3. CPU  : Nike
  4. Board: BD_MST049B_10AQV_NIKE
  5. Hello U-Boot
  6. DRAM:  256 MiB
  7. SPI:  Flash is detected (0x0507, 0xC2, 0x20, 0x15)
  8. spi_init: cfg_env_offset: 0x1e0000, at 560
  9. uboot held at [2ecddf60~30000000]
  10. ......
  11.    Loading Multi-File Image ... OK
  12. [AT][MB][start kr][7718]
  13. Starting kernel   ...
  14. Uncompressing Linux... done, booting the kernel.
  15. KERN-3.1.10.00539225
  16. [    0.000000] Initializing cgroup subsys cpu
  17. [    0.000000] Linux version 3.1.10 (ChangHong@SuperServer) (gcc version 4.5.1 (Sourcery G++ Lite 2010.09-50) ) #15 SMP PREEMPT Mon Apr 28 10:30:51 HKT 2014
  18. [    0.000000] CPU: ARMv7 Processor [410fc073] revision 3 (ARMv7), cr=10c53c7d
  19. [    0.000000] CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
  20. [    0.000000] Machine: nike
  21. ......
  22. [    0.000000] Kernel command line: console=ttyS0,115200 androidboot.console=ttyS0 root=/dev/ram rw rootwait init=/init LX_MEM=0x0018800000 EMAC_MEM=0x100000 DRAM_LEN=0x20000000 LX_MEM2=0x0A0000000,0x0016B00000 CORE_DUMP_PATH=/data/core_dump.%%p.gz KDebug=1 SAR5=ON lpj=4000000 BOOTLOGO_IN_MBOOT ENV_VAR_OFFSET=0x1E0000 ENV_VAR_SIZE=0x10000 ENV=SERIAL SECURITY=OFF BOOTTIME_SBOOT=347 BOOTTIME_UBOOT=7718
  23. [    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
  24. [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
  25. [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
  26. [    0.000000] Memory: 392MB 363MB = 755MB total
  27. [    0.000000] Memory: 752016k/752016k available, 21104k reserved, 0K highmem
  28. ......
  29. [    0.593038] =====flash_thread start====
  30. [    0.594056] eMMC: has SD, 2013/0617
  31. ......
  32. [    0.687934] [mmc]:mmc_decode_cid:113 cid.prv 0x10
  33. [    0.692266] [mmc]:mmc_read_ext_csd:285 ext_csd.sectors 0x760000 prod_name 004G90 BOOT_MULTI 0x10
  34. ......
  35. [    0.746716] mmc0: new high speed MMC card at address 0001
  36. [    0.746795] RPC: Registered named UNIX socket transport module.
  37. [    0.746807] RPC: Registered udp transport module.
  38. [    0.746817] RPC: Registered tcp transport module.
  39. [    0.746826] RPC: Registered tcp NFSv4.1 backchannel transport module.
  40. <font color="Red">[    0.747140] Trying to unpack rootfs image as initramfs...
  41. [    0.776359] [mmc]:mmc_rescan_try_freq:1900 mmc0: eMMC completed
  42. [    0.810538] rootfs image is not initramfs (uncompression error); looks like an initrd</font>
  43. [    0.834310] Freeing initrd memory: 3504K
  44. ......
  45. [    1.334209] usbcore: registered new interface driver btusb
  46. [    1.339359] mmcblk0: mmc0:0001 004G90 3.68 GiB
  47. [    1.343645] mmcblk0boot0: mmc0:0001 004G90 partition 1 2.00 MiB
  48. [    1.349136] mmcblk0boot1: mmc0:0001 004G90 partition 2 2.00 MiB
  49. [    1.355128] emmc_partition()
  50. [    1.358450]  [emmc]Start_block=14336, block_count=1024
  51. [    1.363110] Start_block=15360, block_count=16384
  52. [    1.367259] Start_block=31744, block_count=8192
  53. [    1.371330] Start_block=39936, block_count=921600
  54. [    1.375556] Start_block=961536, block_count=614400
  55. [    1.379860] Start_block=1575936, block_count=122880
  56. [    1.384241] Start_block=1698816, block_count=32768
  57. [    1.388806] Start_block=1731584, block_count=16384
  58. [    1.393113] Start_block=1747968, block_count=102400
  59. [    1.397535] Start_block=1850368, block_count=5509120
  60. [    1.397646] ==> hub_port_init_0528 1
  61. [    1.397656] ==> Reset port 1
  62. [    1.407837] Start_block=7359488, block_count=32768
  63. [    1.412141]
  64. [    1.413479]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11emmc_partition()
  65. [    1.424434]  [emmc]Start_block=14336, block_count=1024
  66. [    1.429083] Start_block=15360, block_count=16384
  67. [    1.433232] Start_block=31744, block_count=8192
  68. [    1.437306] Start_block=39936, block_count=921600
  69. [    1.441533] Start_block=961536, block_count=614400
  70. [    1.445838] Start_block=1575936, block_count=122880
  71. [    1.450219] Start_block=1698816, block_count=32768
  72. [    1.454780] Start_block=1731584, block_count=16384
  73. [    1.459090] Start_block=1747968, block_count=102400
  74. [    1.463472] Start_block=1850368, block_count=5509120
  75. [    1.467931] Start_block=7359488, block_count=32768
  76. [    1.472233]
  77. [    1.473572]  mmcblk0boot1: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11
  78. [    1.478608] mmcblk0boot1: p1 start 14336 is beyond EOD, truncated
  79. [    1.484261] mmcblk0boot1: p2 start 15360 is beyond EOD, truncated
  80. [    1.489743] mmcblk0boot1: p3 start 31744 is beyond EOD, truncated
  81. [    1.495240] mmcblk0boot1: p4 start 39936 is beyond EOD, truncated
  82. [    1.500722] mmcblk0boot1: p5 start 961536 is beyond EOD, truncated
  83. [    1.506280] mmcblk0boot1: p6 start 1575936 is beyond EOD, truncated
  84. [    1.511929] mmcblk0boot1: p7 start 1698816 is beyond EOD, truncated
  85. [    1.517572] mmcblk0boot1: p8 start 1731584 is beyond EOD, truncated
  86. [    1.523221] mmcblk0boot1: p9 start 1747968 is beyond EOD, truncated
  87. [    1.528857] mmcblk0boot1: p10 start 1850368 is beyond EOD, truncated
  88. [    1.534570] mmcblk0boot1: p11 start 7359488 is beyond EOD, truncated
  89. [    1.541319] emmc_partition()
  90. [    1.544588]  [emmc]Start_block=14336, block_count=1024
  91. [    1.549228] Start_block=15360, block_count=16384
  92. [    1.553378] Start_block=31744, block_count=8192
  93. [    1.557450] Start_block=39936, block_count=921600
  94. [    1.561676] Start_block=961536, block_count=614400
  95. [    1.565981] Start_block=1575936, block_count=122880
  96. [    1.570363] Start_block=1698816, block_count=32768
  97. [    1.574916] Start_block=1731584, block_count=16384
  98. [    1.579223] Start_block=1747968, block_count=102400
  99. [    1.583605] Start_block=1850368, block_count=5509120
  100. [    1.588063] Start_block=7359488, block_count=32768
  101. [    1.592365]
  102. [    1.593703]  mmcblk0boot0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11
  103. [    1.598728] mmcblk0boot0: p1 start 14336 is beyond EOD, truncated
  104. [    1.604381] mmcblk0boot0: p2 start 15360 is beyond EOD, truncated
  105. [    1.609863] mmcblk0boot0: p3 start 31744 is beyond EOD,
  106. [    1.611125] usb 1-1: new high speed USB device number 2 using Mstar-xhci-1
  107. [    1.620775] truncated
  108. [    1.622814] mmcblk0boot0: p4 start 39936 is beyond EOD, truncated
  109. [    1.628295] mmcblk0boot0: p5 start 961536 is beyond EOD, truncated
  110. [    1.633853] mmcblk0boot0: p6 start 1575936 is beyond EOD, truncated
  111. [    1.639501] mmcblk0boot0: p7 start 1698816 is beyond EOD, truncated
  112. [    1.645137] mmcblk0boot0: p8 start 1731584 is beyond EOD, truncated
  113. [    1.650772] mmcblk0boot0: p9 start 1747968 is beyond EOD, truncated
  114. [    1.656408] mmcblk0boot0: p10 start 1850368 is beyond EOD,
  115. ......
  116. [    1.804340] >> [sdmmc] ms_sdmmc Driver Initializing...
  117. [    1.809724] >> [sdmmc_0] CDZ use Ext GPIO IRQ: 33
  118. [    1.809736] >> [sdmmc_0] Get CD => (0)
  119. [    1.817311] >> [sdmmc_0] Probe Devices...(Ret:0)
  120. ......
  121. [    2.091412] RAMDISK: gzip image found at block 0
  122. <font color="Red">[    2.158720] uncompression error
  123. [    2.436461] UDF-fs: No partition found (1)</font>
  124. [    2.471125] List of all partitions:
  125. [    2.474323] b300         3866624 mmcblk0  driver: mmcblk
  126. [    2.479167]   b301             512 mmcblk0p1 00000000-0000-0000-0000-000000000mmcblk0p1
  127. [    2.486363]   b302            8192 mmcblk0p2 00000000-0000-0000-0000-000000000mmcblk0p2
  128. [    2.493557]   b303            4096 mmcblk0p3 00000000-0000-0000-0000-000000000mmcblk0p3
  129. [    2.500751]   b304          460800 mmcblk0p4 00000000-0000-0000-0000-000000000mmcblk0p4
  130. [    2.507946]   b305          307200 mmcblk0p5 00000000-0000-0000-0000-000000000mmcblk0p5
  131. [    2.515152]   b306           61440 mmcblk0p6 00000000-0000-0000-0000-000000000mmcblk0p6
  132. [    2.522346]   b307           16384 mmcblk0p7 00000000-0000-0000-0000-000000000mmcblk0p7
  133. [    2.529540]   b308            8192 mmcblk0p8 00000000-0000-0000-0000-000000000mmcblk0p8
  134. [    2.536733]   b309           51200 mmcblk0p9 00000000-0000-0000-0000-000000000mmcblk0p9
  135. [    2.543926]   b30a         2754560 mmcblk0p10 00000000-0000-0000-0000-000000000mmcblk0p10
  136. [    2.551275]   b30b           16384 mmcblk0p11 00000000-0000-0000-0000-000000000mmcblk0p11
  137. [    2.558633] b380            2048 mmcblk0boot1  (driver?)
  138. [    2.563435] b340            2048 mmcblk0boot0  (driver?)
  139. <font color="Red">[    2.568216] No filesystem could mount root, tried:  ext3 ext2 ext4 squashfs vfat msdos iso9660 ntfs romfs udf</font>
  140. [    2.577283]
  141. [    2.577287]  Kernel_Level test
  142. <font color="Red">[    2.581443] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(1,0)</font>
  143. ......
复制代码
说明EMMC中root分区已经被破坏,电视启动过程中加载了LINUX内核,找不到root分区(主程序分区),导致内核恐慌,死机。
按照网络上的说法,开机时同时按住电视上的音量+按键和电源按键,也无法令电视进入U盘刷机模式,因此无法更新EMMC中的root分区。
大家说,我这个情况,该怎么救砖?
发表于: 2016-12-24 16:20:32
飞线刷emmc
发表于: 2016-12-24 17:05:35
用RT809F编程器写入同型号正常机器的MBOOT程序后。问一下师傅,用RT809F如何写这个引导程序?
 楼主| 发表于: 2016-12-24 19:15:00
MBOOT网上有下载,RT809F用VGA线连接电视,写入MBOOT就行了。
 楼主| 发表于: 2016-12-24 19:16:16
RT809F可以飞线刷EMMC?哪里可以找到这个机型的EMMC主程序?
发表于: 2016-12-24 21:08:13
809f不行 h可以
发表于: 2016-12-24 21:10:01
emmc主程序淘宝购买
发表于: 2016-12-25 12:03:31
谢谢师傅指导
GMT+8, 2024-11-25 03:42 , Processed in 0.058978 sec., 9 queries .
