查看: 2010|回复: 2
MSTV2407-ZC01-01
发表于: 2016-12-9 01:49:29
Resolution: 1366x768, a WXGA
the Display-Mode: the Super the MVA, of Black Normally, Transmissive
the Active Area: 631.092x354 mm .816
the Surface: Antiglare (Haze is 1%)
Glass the Depth: 0.50 + 0.50 mm
Transmissivity: 5.4% (with Polarizer)
the Contrast the Ratio: 3000: 1
Display Colors: 16.7M (8 bit-)
the Response Time The: 9.5 (the G to the G )
the Frequency: 60Hz
the Signal the Interface: the LVDS (1 ch, 8-bit), 30 pins
Voltage: 12.0V
发表于: 2016-12-15 15:45:38
谢谢楼主的无私奉献!
发表于: 2017-8-11 10:29:05
谢谢楼主的无私奉献!
GMT+8, 2024-11-26 08:43 , Processed in 0.053333 sec., 9 queries .
