查看: 7787|回复: 22
LOGO JEPG LOGO Tool V2.1.0.0 bin edit
发表于: 2016-11-26 00:05:45
发表于: 2016-11-26 00:26:05
This tools allow to change the logo for any bin file of any brand or for specific brands only?
 楼主| 发表于: 2016-11-26 00:47:30
V59  brand
发表于: 2016-11-27 01:51:52
翻译一下,俺不懂外文!!
发表于: 2016-11-28 16:02:33
翻译一下,我们不懂外文
发表于: 2016-11-28 19:22:22
Thanks for sharing
发表于: 2017-1-26 19:44:44
ITV.V59.V031  board files not supported
 楼主| 发表于: 2017-1-27 00:39:36
use IconLover --English --
发表于: 2017-1-27 01:02:09
good thanks
 楼主| 发表于: 2017-1-27 01:23:43
DVD mainstream chip is MTK and Sunplus, the firmware architecture are open, naturally good change; computer motherboard BIOS is to follow industry standards, such as EFI / UEFI, as well.
However, the LCD TV and monitor chip manufacturers dozens of firmware architecture are different, or even different models of the same manufacturers are very different, but also confidential.
2, proficient in the corresponding model of the firmware architecture, you can reverse the introduction of LOGO, remote control code location (1), the source code, you can modify the LOGO, remote control code, compile and generate firmware; , Directly change the firmware BIN file, and then write back.
Currently still a problem, not a good solution, such as MST / MTK dominate the rivers and lakes, this problem will no longer be a problem.
The use of MST / MTK chip, a new model, directly through the U disk copy pictures can change the way LOGO, but the original brand of the current board does not support.
GMT+8, 2024-12-26 01:42 , Processed in 0.058539 sec., 11 queries .
