查看: 2711|回复: 5
8m50正常机打印信息。
发表于: 2016-11-23 17:42:35
UART_115200
BIST0-OK
[3456789AB]
[6789ABC]-79
 楼主| 发表于: 2016-11-23 17:44:13
UART_115200
BIST0-OK
[3456789AB]
[6789ABC]-79
_U
Hello U-Boot
U-Boot 1.1.6 (Jul 10 2012 - 16:09:10)
Board: MSTAR AMBER7 (CPU Speed 504 MHz)
DRAM:  256 MBytes
U-Boot is running at DRAM 0x87600000
Module: KEYPAD USB FAT NAND UBI UBIFS NET SPI STANDBY JFFS2 LOGO OAD ENV=SERIAL
Flash is detected (0x0711, 0xEF, 0x40, 0x15)
MDrv_SERFLASH_GetInfo()
        u32AccessWidth = 1
        u32TotalSize   = 2097152
        u32SecNum      = 32
        u32SecSize     = 65536
>>> nand: AUTO CE/WP
Flash Make code = 0x98, ID = 0xD1
NAND: 128 MBytes
In:    serial
Out:   serial
Err:   serial
Net:   MSVC00B000100100440822TH0000000T
发表于: 2016-11-23 21:43:11
谢谢楼主的无私奉献!
发表于: 2016-11-24 13:37:31
感谢分享~
发表于: 2016-12-17 21:29:39
正需要  有个机器打印不正常
发表于: 2017-8-27 06:52:36
正需要  有个机器打印不正常
GMT+8, 2024-11-28 02:33 , Processed in 0.056449 sec., 9 queries .
