楼主: mrawzin
update boot rt809h.dead
发表于: 2016-11-15 14:36:05
If the light is not on, please click on the side of the switch, and pay attention to the USB cable, whether in the back of the chassis,
 楼主| 发表于: 2016-11-15 15:11:39
i click switch on the side. light is on
 楼主| 发表于: 2016-11-15 16:34:48
what should i do ?
how can i resolve this problem ?led is on Only when I press the switch?
 楼主| 发表于: 2016-11-15 18:08:08
发表于: 2016-11-15 20:28:13
On programmer, pay attention to the USB port is inserted at the back of the case, the programmer will be lit, then open the software, you can see the serial number of the machine, as to use, depends on you.
 楼主| 发表于: 2016-11-15 20:56:43
i'm sorry
but it is not the first time that i used .
i have rt809f + peb1
 楼主| 发表于: 2016-11-15 21:08:32
 楼主| 发表于: 2016-11-15 23:45:28
please check video
 楼主| 发表于: 2016-11-16 02:14:09
try to understand me because like i see you hadn't
i'm professionnel and it is not the first time that i use a programmer,in the first the programmer is working suddenly it stop working.
ok,all my information at this step are clear i would that you find me a solution for this,i dont play but this is the reality that your programmer is not working because what?,i dont know.
i did what did you tell me to do but no result,as  i see the probleme is not in the programmer it self but it is in the boot system's.i have to tell you that when i insert usb cable in the programmer,the lamp is enlighted then it stop and my computer does not detect the programmer.also when  i just  click in the side of the swich  lamp is enlighted then is not ,but if i  stay clicking on it,lamp stay enlighted and computer detect three component (usb  serial port ,usb serial converter A,usb serial converter B) also i try the same time  to repair usb firmware but the programmer lunch an error and seial nember stay deleted,when i remove my finger,lamp is off.
is there any possibilty to repair programmer boot systeme's ?
i try to simplify all what happen as i can ,and i wish that you try with me  all your best
 楼主| 发表于: 2016-11-16 03:41:15
GMT+8, 2025-1-15 02:29 , Processed in 0.055068 sec., 9 queries .
