查看: 9827|回复: 25
update boot rt809h.dead
发表于: 2016-11-14 21:18:53
Hello
I have a new rt809h
I update boot
The programmer is dead
how to repair it?
I have the original serial number
please help me
发表于: 2016-11-14 22:06:02
Specific please put the operation of the screenshot
 楼主| 发表于: 2016-11-14 22:34:03
Programmer is not connected
发表于: 2016-11-14 22:45:43
This is the programmer firmware update, now your version, no need to change.
 楼主| 发表于: 2016-11-14 23:18:53
i have updated boot   but the programmer is dead
how to fix it?
 楼主| 发表于: 2016-11-15 03:34:15
hello friend
i receive the programmer rt809h today ,it works .
unfortunately i update a new version to it .
i click setting ->rt809h boot update
then
i click  setting ->usb firmware repair
suddenly the programmer is been deconnected .now there is not any connection betwen my  computer and the programmer also my computer cant find the programmer.although the programmer is connected but the serial number  has been deleted
what should i do ?
how can i resol this problem ?
 楼主| 发表于: 2016-11-15 06:18:04
你好朋友我收到程序员rt809h今天,它的工作原理。 不幸的是,我更新了一个新的版本。 我点击设置 - > rt809h启动更新,然后我点击设置 - > usb固件修复突然程序员已经解除连接。我的电脑和程序员之间没有任何连接,我的电脑无法找到程序员。虽然程序员连接,但 序列号已被删除我该怎么办? 我怎么能解决这个问题?
发表于: 2016-11-15 11:37:31
Attention! The programmer's light is on? If the lamp, open software, there is no serial number, please click on the sample of the picture, click on the "USB firmware fix", close the software, pull the programmer, then again on the computer, open the software, OK
 楼主| 发表于: 2016-11-15 13:48:17
no light .
i try this method,Programmer is not connected
 楼主| 发表于: 2016-11-15 14:04:29 来自手机
light is off ,
GMT+8, 2025-1-15 02:15 , Processed in 0.063564 sec., 10 queries .
