查看: 8732|回复: 17
机器修好了,随便看下打印
发表于: 2016-11-9 10:11:23
板号:CV59H-E
Macaw12: BD_MST031B_10AL0_11523
SPI BOOT
Console Initial OK
BIST_0 PASS.
76
[23456789AB][123456789AB]
0066
MIU Initial OK
MW_Usb_SetFacMode_Through_Usb_File: Begin
Error> MW_Usb_SetFacMode_Through_Usb_File: port 1 connection timeout
Start Version
[Board]: BD_CVMV59H_E
[DRAM SIZE]: 64 MB
[FLASH SIZE]: 4 MB
[Tuner]: R620D
[Panel]: BOEI320WX1
[Rroduce_Time]: 20121123112112
Cultraview_Version: GC_BOE_CN_CV59HE10_BOEI320WX1_B112_M240
End Version
[msKeypad_Init]: Allocated channel number > 1 !!!
Keypad Initialize OK
MDrv_PNL_Init u32PnlRiuBaseAddr = A0200000
MDrv_PNL_Init u32PMRiuBaseAddr = A0000000
[XC,Version] 00694324
MApi_XC_Init, 558, pXC_InitData->stPanelInfo.eLPLL_Type=1
GE_SetOnePixelMode
[GOP_ALL][Driver Version]: 0870, BuildNum: 18870, ChangeList: 2147483647
[HAL_GOP_InitMux] ((gop4g<<2)|gop2g):1
[MST Macaw12 Utopia Version[12.1.21]
Error> Cannot Find Update File
g_u8DCOnOff = OFF
POWERON_MODE_OFF >>
Power down
MDrv_Power_ExecutePowerDown
=> StandBy
板号:TP.MS18VG.P77 M S82PT
SPI BOOT
Console Initial OK
Maria10: BD_MST021B_10ALG_11313_64M
[MIU]: 64MB  - DDR2 800MHz
BIST_0 PASS.
77
[23456789ABC][23456789ABCD]
0077
MIU Initial OK
康佳一代网络机LED42S2260N UART_115200
BIST0-OK
[3456789AB]
[456789ABC]-78
_U
Hello U-Boot
U-Boot 1.1.6 (Sep 15 2011 - 17:30:22)
Board: MSTAR AMBER1 (CPU Speed 576 MHz)
DRAM:  256 MBytes
U-Boot is running at DRAM 0x87600000
Module: KEYPAD USB FAT NAND FLASH UBI UBIFS NET SPI STANDBY JFFS2 LOGO OSD ENV=SERIAL
Flash is detected (0x0707, 0xEF, 0x40, 0x14)
MDrv_SERFLASH_GetInfo()
        u32AccessWidth = 1
        u32TotalSize   = 1048576
        u32SecNum      = 16
        u32SecSize     = 65536
>>> nand: AUTO CE/WP
Flash Make code = 0xAD, ID = 0xDA
NAND: 256 MBytes
In:    serial
Out:   serial
Err:   serial
Net:   MSVC00B000100100421604TH0000000T
EnvFlag =:76.....CONFIG_ENV_ADDR=:E0000
cbuffer[0] =:0xFF...cbuffer[1] =:0xFF...cbuffer[11] =:0xFF
Check USB port[0]:
Check USB port[1]:
keypad_pressed_1 is:0
[0]adc_val =:0xFF
keypad_pressed_2 is:0
--> ac boot <--
UART BUS OFF!
发表于: 2016-11-9 11:30:15
谢谢楼主分享!
发表于: 2016-11-9 11:42:07
看看打印信息,了解机理!谢谢楼主!
发表于: 2016-11-18 10:48:43
这个打印信息也不全,最后显示串口关闭
发表于: 2016-11-21 17:22:01
最后一个康佳LED42S2260N,Err:serial意思是错误:串行,应该是总线电压不正常,无法检测到U盘部分。
发表于: 2016-12-9 21:31:12 来自手机
这个怎么才能看懂啊,有木有人翻译一下
发表于: 2017-4-10 21:37:34
完全看不懂
发表于: 2017-4-10 21:46:47
谢谢楼主分享
发表于: 2017-4-12 12:21:25
就是呀。我看不懂。。。。。。。。。
GMT+8, 2024-12-22 01:32 , Processed in 0.069695 sec., 9 queries .
