查看: 15740|回复: 34
海尔LD32U3100 主板HK_T.RT2634P91 编程器数据+打印
发表于: 2016-10-16 10:47:47
海尔LD32U3100编程器数据  贴纸DH1RV 00010 DH0FA 73666 主板HK_T.RT2634P91 屏BOEI320WX
打印
2016-10-16, 11:13:44
COM4, BaudRate:115200 bps, RXD: VGA->12,TXD: VGA->15, Printed by RT809F:
ABCDEFGHIPP#c_entry
pad_mux_audio_check  46
boot_ac_on A5280wait V5280wai= 1
b806012c = 2379beef
[initmodules.c 270]:initmodules 1
[initmodules.c 274]:initmodules 2
[initmodules.c 280]:initmodules 3
[initmodules.c 285]:initmodules 4
[initmodules.c 291]:initmodules 5
ACPU : Finish BISR testing acpu_bisr_st1:done
VCPU : Finish BISR testing vcpu_bisr_st1:done
IO Config 2= PIN_BL_ON_OFF@0000000000010a04
IO Config 2= PIN_BL_ADJ@00ffffc800800307
IO Config 2= PIN_LVDS_ON_OFF@0000000100015203
IO Config 2= PIN_KEYPAD_PWR@0000000800000101
IO Config 2= PIN_KEYPAD_SOURCE@0000000912000001
IO Config 2= PIN_KEYPAD_MENU@0000000a26000001
IO Config 2= PIN_KEYPAD_LEFT@0000000537000001
IO Config 2= PIN_KEYPAD_RIGHT@0000000a26000101
IO Config 2= PIN_KEYPAD_UP@0000000537000101
IO Config 2= PIN_KEYPAD_DOWN@0000000912000101
IO Config 2= PIN_HDMI1_HOTPLUG@0000000001011604
IO Config 2= PIN_HDMI2_HOTPLUG@0000000001011304
IO Config 2= PIN_HDMI3_HOTPLUG@0000000000000000
IO Config 2= PIN_HDMI2_IN@0000000000000304
IO Config 2= PIN_HDMI_MHL_SEL@0000000100010c04
IO Config 2= PIN_MHL_IN@0000000000000d04
IO Config 2= PIN_GLED_ON_OFF@0000000000010b04
IO Config 2= PIN_LED_ON_OFF@0000000000010b04
IO Config 2= PIN_LEDR@0000000100010004
IO Config 2= PIN_RLED_ON_OFF@0000000100010004
IO Config 2= PIN_AMP_MUTE@0000000000011004
IO Config 2= PIN_FLASH_WP@0000000000015103
IO Config 2= PIN_POWER_EN@0000000100010704ABCDEFGHIPP#c_entry
boot_ac_on A5280wait V5280wai= 0
b806012c = 2379beef
发表于: 2016-10-31 19:33:21
数据好用,装上就好,谢谢。
发表于: 2016-12-14 15:02:06
板号一样,屏号一样,我的是创维的,写进去能开机但是屏幕显示不正常,哈,最起码能开机了,证明是数据的问题,我再找找,谢谢楼主!
发表于: 2017-2-12 09:12:19
谢谢 楼主 分享   与我的 机器 是 一样的
发表于: 2017-2-12 10:03:09
谢谢楼主!谢谢 楼主 分享
发表于: 2017-2-16 12:32:14
数据好用,装上正常了,谢谢楼主分享。
发表于: 2017-3-3 20:54:15
数据好用,装上正常了,谢谢楼主分享。
发表于: 2017-3-30 11:21:42
还没装  先谢谢楼主吧! 反正正好我也遇到这毛病了  马上写好试试!
发表于: 2017-3-30 11:42:18
写入装机  正常!谢谢!
GMT+8, 2025-12-15 14:44 , Processed in 0.091696 sec., 11 queries .
