iFix爱修网知识星球,等待你的加入。。。
查看: 2600|回复: 5
创伟37e70rg(8m700-1040),用809f自考
发表于: 2016-10-13 17:58:43
 楼主| 发表于: 2016-10-13 18:02:34
附打印息:UART_115200
BIST0-OK
BIST1-OK
[0123456789A][0123456789A]-55
[0123456789A][0123456789]-54
_nPD
U-Boot 1.1.6 (Aug 12 2010 - 16:09:17)
Board: MSTAR TITANIA (CPU Speed 504 MHz)
DRAM:  0x8000000
Skipping flash_init
Module: KEYPAD USB FAT NAND UBI UBIFS NET EEPROM JFFS2 LOGO
NAND:  nand_bbt: searching bbt....Bad block table found at page 65472, version 0x01
nand_bbt: searching bbt.....Bad block table found at page 65408, version 0x01
nand_read_bbt: Bad block at 0x02440000
nand_read_bbt: Bad block at 0x05ae0000
128 MiB
In:    serial
Out:   serial
Err:   serial
Net:   No ethernet found.
MSVC00B000100100222324DA:100726T
Set MIU0 group priority:c9.....
Set MIU1 group priority:c9.....
Change MIU0 select.....
Group0:d80   Group1:88    Group2:200   Group3:f1
Change MIU1 select.....
Group0:4200  Group1:e00   Group2:30    Group3:4000
cmd: md.b 0x80200000 0x1
80200000: ff    .
80200000: 5a5aa5ff    ..ZZ
.ndata_1[7fa]--->:ff
2.defatult_set is:165
3.*ucp is:255
keypad_pressed_1 is:0
keypad_pressed_2 is:0
1.MSAPI_WDT_StartHit any key to stop autoboot:  0
cmd: md.b 0x874bfef8 0x1
874bfef8: 01    .
cmd: md.b 0x874bfef9 0x1
874bfef9: 01    .
0x00220000-0x07260000 : "mtd=3"
Using volume CK
UBIFS: recovery needed
UBIFS: recovery deferred
UBIFS: mounted UBI device 0, volume 3, name "CK"
UBIFS: mounted read-only
UBIFS: file system size:   %ld bytes (%ld KiB, %ld MiB, 0 LEBs)
UBIFS: journal size:       %ld bytes (%ld KiB, %ld MiB, 0 LEBs)
UBIFS: media format:       w4/r0 (latest is w4/r0)
UBIFS: default compressor: LZO
UBIFS: reserved for root:  %lu bytes (%lu KiB)
ubifs_mount SUCCESS !!
u32ReadBuffVirAddr = a2000000, u32IntBuffVirAddr = a2050000, u32OutBuffVirAddr = a3800000
MApi_JPEG_SetDbgLevel: DbgLevel = 0x0000
verJPD_SetStatus >>>>>>>>>>>>>>>>>>>>>>>> w: 1920  h: 1080
PNL_WIDTH=0x780
M_boot Melody on
  Dsp code verify ok!!
audio DSP_SE LoadCode success..  Dsp code verify ok!!
audio DSP_DEC LoadCode success..
Write 5706 Fail!
dai Write 5706 Success!
2.MSAPI_WDT_ClearUBI already initialized!!
Volume KL found at volume id 0
read 4194304 bytes from volume 0 to 81000000(buf address)
## Booting image at 81000000 ...
   Image Name:   Linux-2.6.28.10-mstar
   Created:      2010-07-20   3:16:06 UTC
   Image Type:   MIPS Linux Kernel Image (lzo compressed)
   Data Size:    3411653 Bytes =  3.3 MB
   Load Address: 80400000
   Entry Point:  80404150
   Uncompressing Kernel Image ... OK
 楼主| 发表于: 2016-10-13 21:01:15
版主,不好意思,发错版面了.
发表于: 2016-12-29 21:31:39
谢谢了下载了
发表于: 2016-12-29 21:36:29
值得分享.谢了
GMT+8, 2024-4-28 17:57 , Processed in 0.052689 sec., 10 queries .
