真心后悔没有换购809H,待我说下原因,前些日接到一台长虹43D2000N机芯ZLS53i2存储器型号GD5F1GQ4U开机就重启,由于修过这个机器,刷机就正常了,对用户报了价,然后把用户打发走了,开始在本论坛里找数据,还真有,窃喜中,结果,插上U盘无法升级,这下傻眼了,上打印信息一看,
UART_115200
BIST0-OK
[123456789A][123456789AB][23456789AB][123456789AB]-5666
U[AT][MB][start ub][2818]
U-Boot 2011.06 (Feb 11 2015 - 08:23:42)
DRAM: 256 MiB
Hello U-Boot
Stack Pointer at: 87e45ac0
uboot held at [8f000000~90000000]
Now running in RAM - U-Boot at: 871f0180
NAND: HAL_SPINAND_SetCKG() u8CkgSpi 104
128 MiB
*** Warning - set default for mtdparts, using default environment
Creating 1 MTD partitions on "nand0":
0x000000640000-0x000000840000 : "mtd=2"
Bad block table found at page 65216, version 0x01
Bad block table found at page 65152, version 0x01
nand_read_bbt: Bad block at 0x000006000000
nand_read_bbt: Bad block at 0x000007f80000
nand_read_bbt: Bad block at 0x000007fa0000
nand_read_bbt: Bad block at 0x000007fc0000
nand_read_bbt: Bad block at 0x000007fe0000
UBI: attaching mtd1 to ubi0
UBI: physical eraseblock size: 131072 bytes (128 KiB)
UBI: logical eraseblock size: 126976 bytes
UBI: smallest flash I/O unit: 2048
UBI: VID header offset: 2048 (aligned 2048)
UBI: data offset: 4096
Can't find "CTRL" partition
restore UBI scan
UBI: attached mtd1 to ubi0
UBI: MTD device name: "mtd=2"
UBI: MTD device size: 2 MiB
UBI: number of good PEBs: 16
UBI: number of bad PEBs: 0
UBI: max. allowed volumes: 128
UBI: wear-leveling threshold: 250
UBI: number of internal volumes: 1
UBI: number of user volumes: 1
UBI: available PEBs: 1
UBI: total number of reserved PEBs: 15
UBI: number of PEBs reserved for bad PEB handling: 2
UBI: max/mean erase counter: 331/126
Volume not found!
NAND read: device 0 offset 0x180000, size 0xa8
168 bytes read: OK
Volume "MPOOL" found at volume id 0
UART BUS OFF!!UART_115200
完了!
Bad block table found at page 65216, version 0x01打印信息显示FLASH有坏块,这就没办法了,换板吧,已对用户报过价,修吧,FLASH不好搞呀,最后在论坛里又找了相关贴子,发现可以换存储器,在这里感谢备份数据的师傅们,感谢小罗-强辉电子师傅,感谢他的本存储器的烧写方法,然后购得几块存储器,将存储器焊下,拿块新的夹在存储器夹子上,将编程器软件更新至最新,点识别,果然识别出来,然后导入数据,写入成功,新程序装机,试机果然不再重启,心中兴奋,调整屏参后机器正常,交于用户!至此本机维修结束,感谢季总的神器,然后再回过头想到几年来修的多台升不了级的主板,如果能整机写入数据,或者写入引导的话,肯定能救活,这才感到了809H的重要性,想换购一台,才发现活动已经结束了,后悔呀,不是不舍得钱,而是发的全新的809F还有好几台,我这肯定没季总那好卖,所以想问一下季总,809H的换购以后还会不会有了,要是有的话我就等,拿全新的换一台,要是没了请季总给个话,发工资了直接买一台,神器必需得有!下面是修理本机的过程,及用到的数据,等等文件,全部打包,本次下载不收金币,感谢广大网友!
封贴,H已经到手~
