查看: 47205|回复: 108
真心后悔没有换购809H!长虹43D2000N机芯ZLS53i2存储器型号GD5F1GQ4U刷机之感想!
发表于: 2016-9-3 16:51:18
真心后悔没有换购809H,待我说下原因,前些日接到一台长虹43D2000N机芯ZLS53i2存储器型号GD5F1GQ4U开机就重启,由于修过这个机器,刷机就正常了,对用户报了价,然后把用户打发走了,开始在本论坛里找数据,还真有,窃喜中,结果,插上U盘无法升级,这下傻眼了,上打印信息一看,
UART_115200
BIST0-OK
[123456789A][123456789AB][23456789AB][123456789AB]-5666
U[AT][MB][start ub][2818]
U-Boot 2011.06 (Feb 11 2015 - 08:23:42)
DRAM:  256 MiB
Hello U-Boot
Stack Pointer at: 87e45ac0
uboot held at [8f000000~90000000]
Now running in RAM - U-Boot at: 871f0180
NAND:  HAL_SPINAND_SetCKG() u8CkgSpi 104
128 MiB
*** Warning - set default for mtdparts, using default environment
Creating 1 MTD partitions on "nand0":
0x000000640000-0x000000840000 : "mtd=2"
Bad block table found at page 65216, version 0x01
Bad block table found at page 65152, version 0x01
nand_read_bbt: Bad block at 0x000006000000
nand_read_bbt: Bad block at 0x000007f80000
nand_read_bbt: Bad block at 0x000007fa0000
nand_read_bbt: Bad block at 0x000007fc0000
nand_read_bbt: Bad block at 0x000007fe0000
UBI: attaching mtd1 to ubi0
UBI: physical eraseblock size:   131072 bytes (128 KiB)
UBI: logical eraseblock size:    126976 bytes
UBI: smallest flash I/O unit:    2048
UBI: VID header offset:          2048 (aligned 2048)
UBI: data offset:                4096
Can't find "CTRL" partition
restore UBI scan
UBI: attached mtd1 to ubi0
UBI: MTD device name:            "mtd=2"
UBI: MTD device size:            2 MiB
UBI: number of good PEBs:        16
UBI: number of bad PEBs:         0
UBI: max. allowed volumes:       128
UBI: wear-leveling threshold:    250
UBI: number of internal volumes: 1
UBI: number of user volumes:     1
UBI: available PEBs:             1
UBI: total number of reserved PEBs: 15
UBI: number of PEBs reserved for bad PEB handling: 2
UBI: max/mean erase counter: 331/126
Volume  not found!
NAND read: device 0 offset 0x180000, size 0xa8
168 bytes read: OK
Volume "MPOOL" found at volume id 0
UART BUS OFF!!UART_115200
完了!
Bad block table found at page 65216, version 0x01打印信息显示FLASH有坏块,这就没办法了,换板吧,已对用户报过价,修吧,FLASH不好搞呀,最后在论坛里又找了相关贴子,发现可以换存储器,在这里感谢备份数据的师傅们,感谢小罗-强辉电子师傅,感谢他的本存储器的烧写方法,然后购得几块存储器,将存储器焊下,拿块新的夹在存储器夹子上,将编程器软件更新至最新,点识别,果然识别出来,然后导入数据,写入成功,新程序装机,试机果然不再重启,心中兴奋,调整屏参后机器正常,交于用户!至此本机维修结束,感谢季总的神器,然后再回过头想到几年来修的多台升不了级的主板,如果能整机写入数据,或者写入引导的话,肯定能救活,这才感到了809H的重要性,想换购一台,才发现活动已经结束了,后悔呀,不是不舍得钱,而是发的全新的809F还有好几台,我这肯定没季总那好卖,所以想问一下季总,809H的换购以后还会不会有了,要是有的话我就等,拿全新的换一台,要是没了请季总给个话,发工资了直接买一台,神器必需得有!下面是修理本机的过程,及用到的数据,等等文件,全部打包,本次下载不收金币,感谢广大网友!
封贴,H已经到手~
发表于: 2016-9-17 22:12:49 来自手机
俺也买了809H新手不会用
发表于: 2016-9-23 12:22:51
我也很想换购一台,在线等机会。。。。
发表于: 2016-9-3 18:59:35
是啊!RT809h 早买早用早赚钱
发表于: 2016-9-3 23:53:25
是啊!RT809h 早买早用早赚钱
发表于: 2016-9-4 00:23:38
没看明白楼主使用的是809H还是809F,看图片上的是809F,但是看文字又好像用的是809H,请楼主说明清楚,不知我说的对与不对
 楼主| 发表于: 2016-9-4 16:14:59
夏小明 发表于 2016-9-4 00:23
没看明白楼主使用的是809H还是809F,看图片上的是809F,但是看文字又好像用的是809H,请楼主说明清楚,不知我 ...
用的确实是F,F也能写有些特殊的大数据, 我说的很清楚呀,并且图片配的也是F的软件界面,怎么不清呢?
发表于: 2016-9-5 02:42:56
Thank you for sharing data
发表于: 2016-9-6 08:02:57
谢谢坛友无私奉献。
发表于: 2016-9-6 09:21:37
在这个论坛里,有了809H,再有大家分享的资料。只要是数据的问题。
我相信没有搞不定的。谢谢楼主分享。
发表于: 2016-9-6 19:21:41
谢谢楼主分享经验
GMT+8, 2024-11-25 16:59 , Processed in 0.055820 sec., 11 queries .
