查看: 7979|回复: 8
江西兴国三十七岁维修男分享LED40H150J的待机打印和开机打印信息
发表于: 2016-8-8 19:58:21
这是在待机下的打印信息
Boot-
DRAM Channel A Calibration.
Byte 0 : Gating(2 ~ 67), Size=66, Mid=34, Set=34.
Byte 1 : Gating(2 ~ 57), Size=56, Mid=29, Set=29.
Byte 2 : Gating(2 ~ 67), Size=66, Mid=34, Set=34.
Byte 3 : Gating(2 ~ 62), Size=61, Mid=32, Set=32.
HW Byte 0 : DQS(12 ~ 46), Size 35, Set 29, HW_Set 31.
HW Byte 1 : DQS(10 ~ 44), Size 35, Set 27, HW_Set 29.
HW Byte 2 : DQS(12 ~ 43), Size 32, Set 27, HW_Set 30.
HW Byte 3 : DQS(10 ~ 44), Size 35, Set 27, HW_Set 29.
DRAM A Size = 1024 Mbytes.
Boot
Start Pmain
0x0000a000
EMMC boot
CID:0xc9d9210f
:0x048600d2
:0x34473164
:0x90014a48
LZHS addr:0x00100040
LZHS size:0x000a65b0
LZHS checksum:0x0000005d
Boot
Start Lmain
MT5880 Boot Loader v0.9
Boot reason: A/C power on!!
use code based  EDID.................
Load HDMI internal EDID.................
CEC Physical offset 156
HDMI1 Physical adr 0x10
HDMI1 PA 0x10
HDMI1 checksum 0x69
HDMI2 PA 0x10
HDMI2 checksum 0x69
HDMI3 PA 0x20
HDMI3 checksum 0x59
HDMI4 PA 0x30
HDMI4 checksum 0x49
SIF_Master0: new design
IR DATA register : 0x       0
Load T8032 FW (addr: 0x  d81600, size: 24576)success!!
T8032 FW version: 73
LDR_FlashCopy 0xf010 0x59a80 0x80
1st MAC in EEP is valid (90:cf:7d:ec:cd:32)
1st : (90:cf:7d:ec:cd:32)
2nd : (ff:ff:ff:ff:ff:ff)
PDWNC_Init
Do USB upgrade
USB: Vbus turn up time = 200 ms, Max =0 ms.
No USB device.
USB upgrade stop
Boot reason: A/C power on!!Boot reason: A/C power on!!Org:0x10 Flags:0x10
Disable VGA wakeup
LEE TEST: PDWNC_SetLED_Mode 1
Standby            郆oo鄑-
HW Byte 1 : DQS(10 ~ 44),?Size 35, Set 27, HW_Set 29.
HW Byte 2 : DQS(12 ~ 44), Size 33, Set 28, HW_Set 30.
HW Byte 3 : DQS(10 ~ 45), Size 36, Set 27, HW_Set 29.
Boot
Start Pmain
0x0000a000
EMMC boot
CID:0xc9d9210f
:0x048600d2
:0x344731?4
:0x90014a48
郆oot
Start Lmain
郆oot reason: A/C power on!!
? CEC Physical offset 156
HDMI1 PA 0x10
HDMI1 checksum 0x69
HDMI2 PA 0x10
HDMI2 checksum 0x69
HDMI3 PA 0x20
HDMI3 checksum 0x59
HDMI4 PA 0x30
HDMI4 checksum 0x49
Boot reason: A/C power on?!T8032 init A/C on case loader stage...
郟DWNC_Init
Do USB upgrade
USB: Vbus turn up time = 199 ms, Max =0 ms.
No USB 郿evice.
USB upgrade stop
Disable VGA wakeup
Standby            郆oot-
Byte 0 : Gating(2 ~ 62), Size=61, Mid=32, Set=32.
Byte 1 :?Gating(2 ~ 57), Size=56, Mid=29, Set=29.
HW Byte 1 : DQS(10 ~ 43), Size 34, Set 26, HW_Set 29.
DRAM A Size = 10?4 Mbytes.
Boot
Start Pmain
0x0000a000
EMMC boot
CID:0xc9d9210f
:0x048600d2
:0x34473164
:0x90014a48
郘ZHS addr:0x00100040
郆oot
Start Lmain
MT5880 Boot Loade鄏 v0.9
Load HDMI interna鄉 EDID.................
HDMI1 PA 0x10
HDMI1 checksum 0x69
HDMI2 PA 0x10
HDMI2 checksum 0x69
HDMI3 PA 0x20
HDMI3 checksum 0x59
HDMI4 PA 0x30
HDMI4 checksum 0x49
B鄌ot reason: A/C power on!!T8032 init A/C on case loader stage...
郟DWNC_Init
Do USB upgrade
USB: Vbus turn 鄒p time = 200 ms, Max =0 ms.
No USB device.
USB upgrade stop
Disable VGA wakeup
Standby
这是在开机的时候的打印信息
Boot-
Byte 1 : Gating(2 ~ 62), Size=61, Mid=32, Set=32.
Byte 2 : Gating(2 ~ 72), Size=71, Mid=37, Set=37.
HW Byte 0 : DQS(12 ~ 45), Size 34, Set 28, HW_Set 31.
HW Byte 1 : DQS(10 ~ 43), Size 34, Set 26, HW_Set 28.
HW Byte 2 : DQS(12 ~ 42), Size 31, Set 27, HW_Set 30.
Boot
Start Pmain
0x0000a000
EMMC boot
CID:0xc9d9210f
:0x048600d2
:0x34473164
:0x90014a48
Boot
Start Lmain
HDMI1 PA 0x10
HDMI1 checksum 0x69
HDMI2 PA 0x10
HDMI2 checksum 0x69
HDMI3 PA 0x20
HDMI3 checksum 0x59
HDMI4 PA 0x30
HDMI4 checksum 0x49
PDWNC_Init
Do USB upgrade
USB-2: insert.
USB-2: ClassCode= 0xFF, u4Diff=146 ms.
No USB device.
USB upgrade stop
Boot reason: A/C power on!!Boot reason: A/C power on!!Org:0x30 Flags:0x30
Flash load lzhs header from 0x80000 to dram(0x1506120), size=2048
Decompression uboot to 0x00800000...
Flash load image from 0x80000 to dram(0x1506120), size=0x36678
secure boot ok
LZHS start
LZHS done
Starting image...
U-Boot 2011.12.12 (Jan 16 2014 - 22:37:17)
DRAM:  808 MiB
WARNING: Caches not enabled
MMC:   HOST 1
Dev Num: 0, Timing Position: 0, Sample Edge: 0x00
90014A48:34473164:048600D2:C9D9210F
id1:4A483447 id2:31640486
eMMC Name: H26M31002GPR
Dev Num: 4, Timing Position: 1, Sample Edge: 0x00
Dev Num: 4, Timing Position: 2, Sample Edge: 0x11
: 0
0.0.0.0
In:    serial
Out:   serial
Err:   serial
Net:   Net Initialization Skipped
No ethernet found.
PDWNC_REBOOT_CMD_OFFSET contains
## Booting kernel from Legacy Image at 00008000 ...
   XIP Kernel Image ... OK
OK
Starting kernel ...
发表于: 2016-8-9 05:59:57
没看懂,知识有限,请楼主一一介绍,谢谢
发表于: 2016-8-9 08:12:18
以为有高手解释一下大概
发表于: 2016-8-9 09:05:44
以为是发征婚广告的。。。
发表于: 2016-8-9 11:58:44
可以自己
字节0:门控(67 - 2),大小= 66,中= 34,设置= 34。
字节1:门控(57 - 2),大小= 56,中= 29,设置= 29。
字节2:门控(67 - 2),大小= 66,中= 34,设置= 34。
字节3:门控(62 - 2),大小= 61,中= 32,设置= 32。
HW字节0:DQS(12 ~ 46),大小35,29,31 hw_set。
HW字节1:DQS(10 ~ 44),大小35,27,29 hw_set。
HW字节2:DQS(12 ~ 43),大小32,27,30 hw_set。
HW字节3:DQS(10 ~ 44),大小35,27,29 hw_set。
一个大小为1024 MB DRAM。
启动
开始pmain
0x0000a000
eMMC启动
CID:0xc9d9210f
:0x048600d2
:0x34473164
:0x90014a48
lzhs地址:0x00100040
lzhs尺寸:0x000a65b0
lzhs校验:0x0000005d
启动
开始lmain
mt5880 Boot Loader V0.9
开机原因:A / C电源!!
VGA EDID .................内部负荷
使用基于代码的EDID .................
HDMI EDID .................内部负荷
CEC物理偏移156
hdmi1物理ADR 0x10
hdmi1 PA 0x10
hdmi1校验0x69
HDMI2 PA 0x10
0x69 HDMI2校验
hdmi3 PA 0x20
hdmi3校验0x59
hdmi4 PA 0x30
hdmi4校验0x49
sif_master0:新设计
红外数据登记:0x 0
开机原因:A / C电源!!t8032 init的A / C的情况下装载阶段…
负载t8032 FW(地址:0x%2 d81600,尺寸:24576)成功!!
t8032固件版本:73
t8032改变装载阶段…
ldr_flashcopy 0xf010 0x59a80 0x80
在EEP第一MAC是有效的(90:CF:7d:EC:CD:32)
第一:(90:CF:7d:EC:CD:32)
第二:(FF FF FF FF:::::FF FF)
pdwnc_init
开机原因:A / C电源!!
做USB升级
USB:VBUS打开时间= 200毫秒,马克斯= 0毫秒。
任何USB设备。
USB升级停止
开机原因:A / C电源!启动原因:A / C上的电源!org:0x10标志:预料!
禁用VGA唤醒
李pdwnc_setled_mode测试:1
待机郆OO鄑—
DRAM通道校准。
HW字节1:DQS(10 ~ 44),?尺寸35,27,29 hw_set。
HW字节2:DQS(12 ~ 44),大小33,28,30 hw_set。
HW字节3:DQS(10 ~ 45),大小36,27,29 hw_set。
一个大小为1024 MB DRAM。
启动
开始pmain
0x0000a000
eMMC启动
CID:0xc9d9210f
:0x048600d2
:0x344731?四
:0x90014a48
lzhs地址:0x00100040
lzhs尺寸:0x000a65b0
lzhs校验:0x0000005d
郆OOT
开始lmain
郆OOT的原因:A / C电!!
?CEC物理偏移156
hdmi1物理ADR 0x10
hdmi1 PA 0x10
hdmi1校验0x69
HDMI2 PA 0x10
0x69 HDMI2校验
hdmi3 PA 0x20
hdmi3校验0x59
hdmi4 PA 0x30
hdmi4校验0x49
sif_master0:新设计
红外数据登记:0x 0
开机原因:A / C电源?!t8032 init的A / C的情况下装载阶段…
t8032固件版本:73
t8032改变装载阶段…
郟dwnc_init
开机原因:A / C电源!!
做USB升级
USB:VBUS打开时间= 199毫秒,马克斯= 0毫秒。
没有USB郿装置。
USB升级停止
禁用VGA唤醒
待机郆OOT—
DRAM通道校准。
字节0:门控(62 - 2),大小= 61,中= 32,设置= 32。
字节1:?门控(2 - 57),大小= 56,中= 29,设置= 29。
HW字节1:DQS(10 ~ 43),大小34,26,29 hw_set。
DRAM的大小= 10?4 MB。
启动
开始pmain
0x0000a000
eMMC启动
CID:0xc9d9210f
:0x048600d2
:0x34473164
:0x90014a48
郘ZHS地址:0x00100040
lzhs尺寸:0x000a65b0
lzhs校验:0x0000005d
郆OOT
开始lmain
mt5880引导装载鄏V0.9
开机原因:A / C电源!!
负载HDMI国际鄉EDID .................
CEC物理偏移156
hdmi1物理ADR 0x10
hdmi1 PA 0x10
hdmi1校验0x69
HDMI2 PA 0x10
0x69 HDMI2校验
hdmi3 PA 0x20
hdmi3校验0x59
hdmi4 PA 0x30
hdmi4校验0x49
sif_master0:新设计
红外数据登记:0x 0
B鄌OT的原因:A / C电!!t8032 init的A / C的情况下装载阶段…
t8032固件版本:73
t8032改变装载阶段…
郟dwnc_init
开机原因:A / C电源!!
做USB升级
USB:VBUS转鄒P时间= 200毫秒,马克斯= 0毫秒。
任何USB设备。
USB升级停止
禁用VGA唤醒
李:pdwnc_setled_mo百度翻译一下,有结果。
 楼主| 发表于: 2017-3-25 00:14:56
夏小明 发表于 2016-8-9 05:59
没看懂,知识有限,请楼主一一介绍,谢谢
我也不懂呀。我只是修好之后读出来的打印信息。
发表于: 2017-4-14 12:55:34
明显插的U盘不行,换个试下
发表于: 2017-4-21 14:27:03
待机打印信息有乱码!!!
发表于: 2017-11-7 21:06:39
这个太难了
GMT+8, 2024-12-19 17:56 , Processed in 0.061433 sec., 9 queries .
