楼主: yhx080232
在板上飞线读写EMMC,如何找到关键的飞线点?
发表于: 2018-3-22 09:10:26
好资料收藏
发表于: 2018-3-22 12:49:17
好资料 公开的秘籍 谢谢季老师
发表于: 2018-3-23 11:15:49
谢谢季老师 保存备用了
点评回复 支持 反对
举报
达成家电
1
主题
13
帖子
1975
积分
金牌会员
积分1975 .. 收听TA
发消息
6#
发表于 2016-7-25 11:37:53 | 只看该作者
保存备用了,谢谢
发表于: 2018-3-26 13:47:25
好资料,一定要收藏。
发表于: 2018-3-26 17:37:20
了不起。。。。长见识拉?。
发表于: 2018-3-26 20:09:54
还在学习中''''''
发表于: 2018-3-27 15:29:31
admin 发表于 2016-7-24 11:32
EMMC在线读写需要找到VCC/GND/CLK/CMD/D0至少5根线。VCC/GND这个最好找,不用多讲。
如果有图纸或者拆了EM ...
Hello
today encountered a problem, cannot write dump larger than 4GB on emmc, tried several emmc chips, all same result. Everything gets written up to 4GB, after that program just loops at 52% or 53% depends on chip size. When i verfy what is written it is only 4GB. Only way to write whole chip is to use "options" and to limit from 0-3500MB then from 3500-7500MB writing from two parts, but then i get currupted at least one sector and i have to repair it manually. I persume this is problem of using 32-bit integer in program code instead of 64-bit (long) integer. Can this be fixed with patch as is really unusable like this.
Thanks.
RT809H-20180312-Patch http://www.ifix.org.cn/thread-56912-1-1.html  发表于 2018-3-27 15:38
发表于: 2018-3-27 17:04:17
(li
there is another error now, can you please check, i write file SDA.img it writes it but also reports an error about missing file SDA.img.part1  (line 46) which i never had as my dump is only from one part called SDA.img
  1. 027:  Chip pins contact is detected OK.
  2. 028:  Identified the genuine adapter£oRT-BGA169-01,V2.1, SN: 20180130152510-S02420
  3. 029:  eMMC OCR: C0FF8080
  4. 030:  eMMC CID:  FE014E4D4D4330384738C1F415B5B0
  5. 031:  eMMC CSD: D04F01320F5913FFFFFFFFEF8A4000
  6. 032:  Chip ID:4E0100FE,Chip Name:MMC08G
  7. 033:  Chip Size: User=7504MB,Boot1=Boot2=2048KB,RPMB=128KB.
  8. 034:  VCCIO: 3.3V
  9. 035:  0x1FEFF8000
  10. 036:  Chip pins contact is detected OK.
  11. 037:  Identified the genuine adapter£oRT-BGA169-01,V2.1, SN: 20180130152510-S02420
  12. 038:  eMMC OCR: C0FF8080
  13. 039:  eMMC CID:  FE014E4D4D4330384738C1F415B5B0
  14. 040:  eMMC CSD: D04F01320F5913FFFFFFFFEF8A4000
  15. 041:  Chip ID:4E0100FE,Chip Name:MMC08G
  16. 042:  Chip Size: User=7504MB,Boot1=Boot2=2048KB,RPMB=128KB.
  17. 043:  C:\DUMPS\SDA.IMG
  18. 044:  Start writing chip......
  19. 045:  . Start to write and check the user area data, large capacity, please be patient.
  20. 046:  File can't open : C:\DUMPS\SDA.IMG.part1
  21. 047:  Elapsed time: 426.4 seconds£¬average speed of 36903438 bytes/sec.
  22. 048:  >------------------------------------OK---------------------------------------<
复制代码
is this OK ?
发表于: 2018-3-27 17:33:12
Also, please, when i read chip, i get dump in two files one is name as i wanted, second is called .part1, i need to merge these files to get original dump ? And for writing dump, i need to cut file on some exact size as it asks for .part1 even if not exists and first file is 7.5GB ? Or we can use only dumps made by RT809H software ? This would be really bad.
GMT+8, 2024-12-19 23:39 , Processed in 0.058103 sec., 10 queries .
