楼主 |
发表于: 2016-11-20 19:33:14
显示全部楼层
001: Programmer is not connected.
002: The currently selected:S29AL008D70TFI02@TSOP48, capacity: 8Mbits, 1Mbytes.
003: Adapter model£oRT-TSOP48-1, 0.5, 12*18, Pin to Pin
004: Serial number:20161007122248-045821 ,PCB V1.60,Boot V1.00
005: Download device programming algorithm......
006: Algo update OK
007: >------------------------------------OK---------------------------------------<
008: The pin detection value is 0xFFFFFFFFCDFF£¬Device library number is 0xFFFFFFFFCCFF¡£
009: Chip pins contact is detected OK.
010: Ignore the chip ID to continue.
011: Start reading chip......
012: Read successful£¬Elapsed time£o0.188 seconds¡£
013: Auto verifying...
014: Verification successful£¬Elapsed time£o0.189 seconds¡£
015: Buffer data checksum: 16bits_0xFA16 £¬32bits_0x08CCFA16 :
016: Elapsed time: 0.388 seconds£¬average speed of 5405030 bytes/sec.
017: >------------------------------------OK---------------------------------------<
018: The currently selected:S29AL008D70TFI01@TSOP48, capacity: 8Mbits, 1Mbytes.
019: Adapter model£oRT-TSOP48-1, 0.5, 12*18, Pin to Pin
020: Download device programming algorithm......
021: Algo update OK
022: >------------------------------------OK---------------------------------------<
023: The pin detection value is 0xFFFFFFFFCDFF£¬Device library number is 0xFFFFFFFFCCFF¡£
024: Chip pins contact is detected OK.
025: Chip ID selected does not match the current ID, operation has been terminated.
026: ID verification error.
027: Point "read" will pop up "save" dialog box, "write" will pop up the "open" dialog box.
028: The currently selected:NAND_AUTO
029: Download device programming algorithm......
030: Algo update OK
031: >------------------------------------OK---------------------------------------<
032: The pin detection value is 0xFFFFFFFFDDFF£¬Device library number is 0xF18F00799C0¡£
033: Chip pins contact is detected OK.
034: TotalPageNum: 0x100,PageNumInBlock: 64,PageSize: 2112
035: NewMFR: 0x5A , ID: 0x5A5A5A5A5A5A5A5A, 3.3V, CE:1, 16bit, Col: 2, Row: 2, TLC.
036: PageSize:4096B, OobSize:64B, BlockSize:128KB, ChipSize:0MB.
037: Recognition of the NAND parameters is special
