2016-4-16, 18:7:1
COM4, BaudRate波特率:115200 bps, RXD: VGA->12,TXD: VGA->15, Printed 冲洗by RT809F:
UART通用异步接收器-发射器_115200
BIST0-OK
[0123456789A][123456789A][123456789AB][123456789A]-5565
U[AT][MB][start ub][390]
U-Boot 2011.06 (Apr 22 2014 - 15:55:37)
DRAM: 256 MiB
Hello U-Boot
Stack栈Pointer指针 at: 87e3d3c0
uboot held保留、保存 at [8f000000~90000000]
Now running in RAM - U-Boot at: 871f0180
NAND: DMA MODE
[NC_Init] SDRNAND is detected
CIS is found @Blk0
FCIE is set放置、设置to 54MHz
128 MiB
*** Warning - set default默认for mtdparts, using default environment环境
Creating 1 MTD partitions on"nand0":
0x000000640000-0x000000840000 :"mtd=2"
Bad block 块table表、目录 found at page65472, version 0x01
Bad block块 table表、目录 found at page65408, version 0x01
nand_read_bbt: Bad block块 at 0x000006000000
nand_read_bbt: Bad block块 at 0x0000064e0000
UBI: attaching把…固定mtd1 to ubi0
UBI: physical自然的、物理的 eraseblock擦除块 size: 131072 bytes (128 KiB)
UBI: logical逻辑的 eraseblock擦除块 size: 126976 bytes
UBI: smallest flash I/O unit单元: 2048 (最小的flash输入/输出 单元)
UBI: VID header标头 offset: 2048 (aligned 对准的2048)
UBI: data offset抵消、补偿: 4096
UBI: attached附加的、附属的 mtd1 to ubi0
UBI: MTD device name: "mtd=2"
UBI: MTD device size: 2 MiB
UBI: number of good PEBs: 16
UBI: number of bad PEBs: 0
UBI: max. allowed容许的 volumes: 128
UBI: wear耗损-leveling 水准测量threshold门槛、入口: 250
UBI: number of internal 内部的volumes: 1
UBI: number of user用户 volumes: 1
UBI: available 能找到的、可获得的PEBs: 1
UBI: total 全部的number of reserved保留 PEBs: 15
UBI: number of PEBs reserved保留、储备 for bad PEB handling处理、操作: 2
UBI: max/mean至多/意思是 erase清除 counter计数器: 387/183
NAND read: device设备 0 offset抵消、补偿 0x180000, size大小、尺寸 0xa8
168bytes read: OK
Volume卷"MPOOL" found at volume id 0
UARTBUS OFF!!
