查看: 4335|回复: 0
正常的欧宝丽(长虹)32J1M(板号JUC7.820.00086169打印信息
发表于: 2016-4-3 12:56:50
2016-4-3, 12:51:20
COM4, BaudRate:115200 bps, RXD: VGA->15,TXD: VGA->12, Printed by RT809F:
Macaw12: BD_MST030B_10AL8_12052
SPI BOOT
Console Initial OK
BIST_0 PASS.
76
[23456789AB][123456789ABC]
0066
MIU Initial OK
Keypad Initialize OK
MDrv_PNL_Init u32PnlRiuBaseAddr = A0200000
MDrv_PNL_Init u32PMRiuBaseAddr = A0000000
[XC,Version] 00676880
MApi_XC_Init, 558, pXC_InitData->stPanelInfo.eLPLL_Type=1
==========> u8CS[E6]
==========> u8CS[5F]
HdcpKey all load Ok!
GE_SetOnePixelMode
[GOP_ALL][Driver Version]: 0087, BuildNum: 1887, ChangeList: 2147483647
[HAL_GOP_InitMux] ((gop4g<<2)|gop2g):1
[MST Macaw12 Utopia Version[12.1.18]
Static LoadJpegPng Init start >>>
u16JpegPngNum = 1
----- Index = 0------
u32BinFileImgAddr = 0x322B36, u32BinFileImgSize = 0xA41C
Static LoadJpegPng Init end <<<<
Static LoadJpegPng  start >>>
----- Index = 0--------proccess notify in other page
Image:
u16BufImgWidth = 0x306
u16BufImgHeight = 0x1F9
u16BufImgPitch = 0x308
u32BuffSize = 0xBF590
u8FileFmt = 0
u8BufImgFmt = 0
, u32BuffSize = 0xBF590
, u32DramBufAddr = 0xC69590
-----------------------Disable Aeon
Disable Aeon Done
Static LoadJpegPng end <<<<
Mirror function (1)
Auth OK
create Audio SHM data ...
Enable Watch_DOG to 120s for USB
===== Check Audio Decoder Protection from hash-key IP =====
Hash-key Support DD.
Hash-key Support DD+.
Hash-key Support Generic HE-AAC !!
Hash-key Support WMA.
===== Check Protection IP End                         =====
Disable Aeon
Disable Aeon Done
R620D Init success
Enable Watch_DOG to 10s for Un USB
DSP code loaded successfully
Patch Off
>> MDrv_AVD_Set2D3DPatchOnOff OFF
========= CUS04_ATV_MM_M12 =========
DVB-T Software Version: 0.00
[Board]: BD_CH_V59
[Tuner]: R20D
[DRAM TYPE]: DDR2_800
[MEMORY_MAP]: MMAP_64MB
[DRAM SIZE]: 64 MB
[FLASH SIZE]: 4 MB
[ATV]: PAL
[Mirror]: 0
[ENABLE_PWS]: 1
[ENABLE_POWER_SAVING_DPMS]: 1
[ENABLE_DLC]
[MWE]
[DISPLAY_LOGO]
[ENABLE_POWERON_MUSIC]
=> DC_BOOT (1)
PM Wakeup by SAR
set USB port auto switch to 0
-Set_VD_SetMode>> msAPI_AVD_CombSyncUnstableCheck  True!!!!
Patch On
>> MDrv_AVD_Set2D3DPatchOnOff  ON
HandleGlobalKey
GMT+8, 2024-12-19 19:50 , Processed in 0.055154 sec., 9 queries .
