查看: 7998|回复: 12
LED42K360J 升级失败请问大哥们有什么办法可以救活
发表于: 2016-3-13 17:46:49
这个数据先前很难找,于是就到网上找了一个相近的,谁知道刷上就死机了,只有底下的白色大指示灯一直在亮。请问有没有师傅知道怎么救活的办法
网上说只要按住设置键再开机就可以再重新升级·······
但是我怎么升级没有用
奉上打印信息
Boot-
DRAM Channel A Calibration.
Byte 0 : Gating(2 ~ 62), Size=61, Mid=32, Set=32.
Byte 1 : Gating(2 ~ 57), Size=56, Mid=29, Set=29.
Byte 2 : Gating(2 ~ 67), Size=66, Mid=34, Set=34.
Byte 3 : Gating(2 ~ 62), Size=61, Mid=32, Set=32.
HW Byte 0 : DQS(12 ~ 44), Size 33, Set 28, HW_Set 31.
HW Byte 1 : DQS(9 ~ 40), Size 32, Set 24, HW_Set 27.
HW Byte 2 : DQS(12 ~ 43), Size 32, Set 27, HW_Set 29.
HW Byte 3 : DQS(8 ~ 41), Size 34, Set 24, HW_Set 27.
DRAM A Size = 512 Mbytes.
Boot
Start Pmain
0x0000a000
EMMC boot
CID:0xcb864089
:0x20560062
:0x594e4958
:0x90014a48
LZHS addr:0x00100040
LZHS size:0x000a6288
LZHS checksum:0x000000c6
Boot
Start Lmain
MT5880 Boot Loader v0.9
Boot reason: A/C power on!!
use code based  EDID.................
Load HDMI internal EDID.................
CEC Physical offset 156
HDMI1 Physical adr 0x10
HDMI1 PA 0x10
HDMI1 checksum 0x69
HDMI2 PA 0x10
HDMI2 checksum 0x69
HDMI3 PA 0x20
HDMI3 checksum 0x59
HDMI4 PA 0x30
HDMI4 checksum 0x49
SIF_Master0: new design
IR DATA register : 0x       0
Load T8032 FW (addr: 0x  d81550, size: 24576)success!!
T8032 FW version: 73
LDR_FlashCopy 0xf010 0x59880 0x80
1st MAC in EEP is valid (90:cf:7d:d2:d1:88)
1st : (90:cf:7d:d2:d1:88)
2nd : (ff:ff:ff:ff:ff:ff)
PDWNC_Init
Do USB upgrade
USB: Vbus turn up time = 200 ms, Max =0 ms.
No USB device.
USB upgrade stop
Boot reason: A/C power on!!Boot reason: A/C power on!!Org:0x30 Flags:0x30
Flash load lzhs header from 0x80000 to dram(0x1506020), size=2048
Decompression uboot to 0x00800000...
Flash load image from 0x80000 to dram(0x1506020), size=0x365a9
secure boot ok
LZHS start
LZHS done
Starting image...
U-Boot 2011.12.12 (Jul 17 2013 - 18:24:15)
DRAM:  808 MiB
里面显示了NO USB 驱动····是不去从USB看来没有办法升级了········
发表于: 2016-3-13 17:58:40
智能机看升的是什么了,如果是引导看下是不是带外挂外挂可以拆卸啦
 楼主| 发表于: 2016-3-13 18:22:40
听用户说原来就是卡在开机的画面不停的循环,他升级之后就变成这样了。所以这个问题就是升级不当致使的。应该没有别的硬件故障
发表于: 2016-3-13 18:54:55
找固件刷吧
 楼主| 发表于: 2016-3-13 19:56:57
现在重新找朋友找了一个一样的,可是就是刷不进去了。郁闷
发表于: 2016-3-13 20:04:10
刷机固件太难找了,不是万不得已还是别刷机
 楼主| 发表于: 2016-3-13 20:11:56
所以以后不一样的,哪怕相近的都不能随便用。真的是自寻烦恼
发表于: 2016-3-13 20:19:53
可以联系一下售后,购买原厂的刷机固件
 楼主| 发表于: 2016-3-13 20:28:44
夜雨佳人 发表于 2016-3-13 20:19
可以联系一下售后,购买原厂的刷机固件
现在是完全升级不能,能够查询到的资料都试了一下没用。做最坏的打算,就是换板,剩下的留到以后能力强了再修
发表于: 2016-3-13 21:15:53
lwh314 发表于 2016-3-13 20:28
现在是完全升级不能,能够查询到的资料都试了一下没用。做最坏的打算,就是换板,剩下的留到以后能力强了 ...
高,这这法我喜欢,要是我我也这样
GMT+8, 2024-12-21 22:48 , Processed in 0.059619 sec., 9 queries .
