查看: 1572|回复: 0
帮忙分析下32E72RA 8M92机芯的打印信息.
发表于: 2016-3-5 22:47:57
帮忙分析下32E72RA  8M92机芯的打印信息,看是否正常,先谢谢了! 我自己分析是正常不知对不对
2016-3-5, 0:25:24
COM8, BaudRate:115200 bps, RXD: VGA->12,TXD: VGA->15, Printed by RT809F:
UART_115200
BIST0-OK
BIST1-OK
[3456789ABC][456789ABC]-78
[3456789ABC][56789ABC]-78
_U
Hello U-Boot
U-Boot 1.1.6 (Aug 26 2011 - 16:32:29)
Board: MSTAR JANUS2 (CPU Speed 600 MHz)
DRAM:  128 MBytes
U-Boot is running at DRAM 0x87600000
Module: KEYPAD USB FAT NAND FLASH UBI UBIFS NET SPI STANDBY JFFS2 LOGO ENV=SERIAL
Flash is detected (0x0507, 0xC2, 0x20, 0x15)
MDrv_SERFLASH_GetInfo()
u32AccessWidth = 1
u32TotalSize   = 2097152
u32BlkNum      = 32
u32BlkSize     = 65536
>>> nand: AUTO CE/WP
>>>>> MBoot: NFIE CLK (reg_clk_nfie=0x10)
>>>>> SET Duty cycle to 3:1  (NC_WIDTH=0x410)
Flash Make code = 0x2C, ID = 0xDC
.[INFO] Cache Line Size: 64 Bytes
NAND: 512 MBytes
In:    serial
Out:   serial
Err:   serial
Net:   MSVC00B000100100415881TH0000000T
EnvFlag =:32.....CONFIG_ENV_ADDR=:1E0000
keypad_pressed_1 is:0
Channel =0,adc_val=FF
Channel =1,adc_val=FF
keypad_pressed_2 is:0
keypad_pressed is [0]
ir_pressed is [0]
check_sw_upgrade
6m30_not_install 00
6m30_not_install 00
db_table.panelpara_offset =:0xBDE1A...db_table.panelpara_size=:0x60
MDrv_PNL_Init u32PnlRiuBaseAddr = BF200000
MDrv_PNL_Init u32PMRiuBaseAddr = BF000000
u32ReadBuffVirAddr = A0000000, u32IntBuffVirAddr = A0100000, u32OutBuffVirAddr = A0730000
verJPD_SetStatus >>>>>>>>>>> w:1366,  h:768,  p:1368
GE_SetOnePixelMode
init Shared
HAL_MAD_SetMemInfo[DSP_DEC] = 0x02400000
HAL_MAD2_SetMemInfo[DSP_SE] = 0x02300000
check data 3
dat0 0 <===> DE
dat1 0 <===> BF
dat2 0 <===> FB
  Dsp code verify error!!
******Amplifier_TI5711_SWMute(0)
UnProtect MIU block 0 : 0x75F1000 0x76C8000
Protected address should be aligned to 8KB
NAND read: device 0 offset 0x80000, size 0x400000
Reading data from 0x524288x -- 100% complete.
4194304 bytes read: OK
## Booting image at 81000000 ...
   Image Name:   Linux-2.6.32.15-mstar
   Created:      2011-08-19   7:46:31 UTC
   Image Type:   MIPS Linux Kernel Image (lzo compressed)
   Data Size:    3101286 Bytes =  3 MB
   Load Address: 80000000
   Entry Point:  80004150
   Uncompressing Kernel Image ... OK
GMT+8, 2024-11-26 19:25 , Processed in 0.055591 sec., 9 queries .
