故障打印信息仅供学习!
发表于: 2019-6-12 17:38:08
没有什么用,没有解释,没有说明。
发表于: 2019-6-19 23:05:07
   TUART_115200
BIST0-OK
BIST1-OK
[0123456789A][0123456789A]-55
[0123456789A][0123456789]-54
_nPD=>cmd: eeprom read  0x874bff7c 0x1fed 0x1
EEPROM @0x0 read: addr 874bff7c  off 1fed  count 1 ... cmd: md.b 0x874bff7c 0x1
874bff7c: 55    U
done
Wait for PM51 standby...........PM51 run ok...........1.SAR Config= 0x700ff00
2.SAR Config= 0x700ff00
1.SAR Config= 0x7f0ff01
2.SAR Config= 0x7f0ff01
==== Enter Standby Mode !! ====
UART_115200
BIST0-OK
BIST1-OK
_nPDSkipping flash_init
Module: KEYPAD USB FAT NAND UBI UBIFS NET SPI EEPROM STANDBY JFFS2
NAND:  nand_bbt: searching bbt....Bad block table found at page 131008, version 0x01
nand_bbt: searching bbt.....Bad block table found at page 130944, version 0x01
256 MiB
In:    serial
Out:   serial
Err:   serial
Net:   No ethernet found.
MSVC00B000100100208768TH0000000T
Set MIU0 group priority:c9.....
Set MIU1 group priority:c9.....
Change MIU0 select.....
Group0:d80   Group1:88    Group2:200   Group3:f1
Change MIU1 select.....
Group0:4200  Group1:e00   Group2:30    Group3:4000
EEPROM @0x0 read: addr 80200000  off 0280  count 1 ... cmd: md.b 0x80200000 0x1
80200000: ff    .
done
80200000: 5a5aa5ff    ..ZZ
EEPROM @0x0 read: addr 80300000  off 0281  count 1 ... cmd: md.b 0x80300000 0x1
80300000: ff    .
done
EEPROM @0x0 read: addr 80400000  off 0282  count 1 ... cmd: md.b 0x80400000 0x1
80400000: ff    .
done
EEPROM @0x0 read: addr 80500000  off 0283  count 1 ... cmd: md.b 0x80500000 0x1
80500000: ff    .
done
>>>>>>>>eeprom 0x280 0x281 0x282  0x283 data as follow:
data_1[0x280]--->:ff
data_1[0x281]=:>>>>>ff
data_1[0x282]=:>>>>>ff
data_1[0x283]=:>>>>>ff
>>>>>>>>eeprom 0x281 0x282  0x283 data end:
defatult_nandset is:168
defatult_set is:165
*ucp is:255
EEPROM @0x0 read: addr 80200000  off 1fee  count 1 ... cmd: md.b 0x80200000 0x1
80200000: 1c    .
done
80200000: 5a5aa51c    ..ZZ
data_1[0x1FEE]--->:28
EEPROM @0x0 read: addr 874bfefc  off 1fec  count 1 ... cmd: md.b 0x874bfefc 0x1
874bfefc: 00    .
done
EEPROM @0x0 write: addr 874bfefc  off 1fec  count 1 ... cmd: md.b 0x874bfefc 0x1
874bfefc: 00    .
done
keypad_pressed_1 is:0
keypad_pressed_2 is:0
keypad_pressed is [0]
incorrect device type in UBI
Partition UBI not found!
Error, no UBI device/partition selected!
## Booting image at 81000000 ...
Bad Magic Number
<< MStar >># mstarEMAC Mem Base:8771c000
Rx buff:771c000
RBQP:774c000
Packet buffer:8771b056
phy [0]=ffff
phy [1]=786d
MAC Address 00:30:1B:BA:02B
Auto-Negotiation...
Link Status Speed:100 Full-duplex:1
word_ETH_CFG 803(Re)start EMAC...
Using  device
TFTP from server 10.120.29.5; our IP address is 10.120.29.55
Filename 'auto_update.txt'.
Load address: 0x87501dd0
Loading: *#
done
Bytes transferred = 471 (1d7 hex)
>> mstar [[kernel
phy [1]=786d
(Re)start EMAC...
Using  device
Filename '[[kernel'.
Load address: 0x87502dd8
Loading: *#
done
Bytes transferred = 187 (bb hex)
>> tftp 0x80400000 NAND/uImage.lzo
Using  device
Filename 'NAND/uImage.lzo'.
Load address: 0x80400000
done
Bytes transferred = 5840896 (592000 hex)
>> ubi part UBI
>> ubi write 0x80400000 RFS 0x800000
>> mstar [[chakra
phy [1]=786d
(Re)start EMAC...
Using  device
Filename '[[chakra'.
Loading: *#
done
done
Bytes transferred = 1650688 (193000 hex)
>> ubi part UBI
>> ubi write 0x80400000 APP2 0x3800000
>> mstar set_config
phy [1]=786d
(Re)start EMAC...
Using  device
Filename 'set_config'.
Loading: *#
done
Bytes transferred = 684 (2ac hex)
>> setenv MS_MEM LX_MEM=0x2900000 EMAC_MEM=0x100000 DRAM_LEN=0x10000000 LX_MEM2=0x44D05000,0x3200000
>> setenv MS_GOP0_MIU 0
>> setenv MS_RFS ubi.mtd=1,2048 root=ubi:RFS rootfstype=ubifs rw
>> setenv bootargs console=ttyS0,115200 $(MS_RFS) $(MS_MEM) MS_GOP0_MIU=$(MS_GOP0_MIU) $(mtdparts)
>> setenv bootcmd ' ubi part UBI;ubi read 81000000 KL 400000; bootm 81000000;
>> setenv verify n
>> saveenv
Saving Environment to NAND...
Erasing and writing environment to Nand...done
>> net_miu
cmd: tftp 0x87502dd8 miu_setting.txt
Using  device
Filename 'miu_setting.txt'.
Loading: *#
done
Bytes transferred = 169 (a9 hex)
cmd: set MIU0_GROUP_PRIORITY 1:2:0:3
cmd: set MIU1_GROUP_PRIORITY 1:2:0:3
cmd: set MIU0_GROUP_SELMIU 0D80:0088:0200:00F1
cmd: set MIU1_GROUP_SELMIU 4200:0E00:0030:4000
>> printenv
bootdelay=0
sw_version=0.0.0
baudrate=115200
preboot=echo;echo Type "help" for more commands.
MS_BOARD=BD_MST087F_D01A_TCL_I48
mtdids=nand0=edb64M-nand
mtdparts=mtdparts=edb64M-nand:256k(nand_partition_tbl),256k(linux_boot_param),8m(kernel),512k(chakra_boot_param),8m(charkra_bin),8m(rootfs),39m(usr)
serverid=10.120.29.5
ethact=
stdin=serial
stdout=serial
stderr=serial
partition=nand0,0
MS_MEM=LX_MEM=0x2900000 EMAC_MEM=0x100000 DRAM_LEN=0x10000000 LX_MEM2=0x44D05000,0x3200000
MS_GOP0_MIU=0
MS_RFS=ubi.mtd=1,2048 root=ubi:RFS rootfstype=ubifs rw
bootargs=console=ttyS0,115200 ubi.mtd=1,2048 root=ubi:RFS rootfstype=ubifs rw LX_MEM=0x2900000 EMAC_MEM=0x100000 DRAM_LEN=0x10000000 LX_MEM2=0x44D05000,0x3200000 MS_GOP0_MIU=0 mtdparts=edb64M-nand:256k(nand_partition_tbl),256k(linux_boot_param),8m(kernel),512k(chakra_boot_param),8m(charkra_bin),8m(rootfs),39m(usr)
bootcmd=ubi part UBI;ubi read 81000000 KL 400000; bootm 81000000;
verify=n
filesize=a9
fileaddr=87502DD8
ipaddr=10.120.29.55
serverip=10.120.29.5
MIU0_GROUP_PRIORITY=1:2:0:3
MIU1_GROUP_PRIORITY=1:2:0:3
MIU0_GROUP_SELMIU=0D80:0088:0200:00F1
MIU1_GROUP_SELMIU=4200:0E00:0030:4000
Environment size: 1143/131068 bytes
>> reset
Skipping flash_init
256 MiB
In:    serial
Out:   serial
Err:   serial
80200000: ff    .
done
80300000: ff    .
done
80400000: ff    .
done
80500000: ff    .
done
defatult_set is:165
*ucp is:255
80200000: 1c    .
done
874bfefc: 00    .
done
874bfefc: 00    .
done
Bad Magic Number
<< MStar >>#
发表于: 2019-6-19 23:07:45
这个重新写引导升级试试呢,和长虹59机芯有的一拼,停在控制台了
发表于: 2019-6-20 10:20:20
没用看不懂没有解说,乱七八糟的
发表于: 2021-1-16 17:13:03
我的天呀。就是一个打印信息。没有分析。
GMT+8, 2025-12-15 14:38 , Processed in 0.063491 sec., 11 queries .
