查看: 5113|回复: 5
ite8580 - ite8586 back up from lenovo y400 and y 500
发表于: 2016-2-24 23:27:00
wecan carefully match the surrounding EC is not the same. Therefore, thecorresponding board is not the same
Usage:1. The need to download the upgrade package ITE858 series, covering theoriginal RT809F installation directory
2. the corresponding pin chip solderedEC
3. The adapter plate is mounted to the dedicated programmer, then dedicatedprogrammer installed RT809F on!
4. Start reading program as shown below
Admin will correct this : read here and buy it    http://www.ifix.net.cn/thread-42195-1-1.html
发表于: 2016-12-17 12:27:40
FA XIAN ZIJI HEN MEI WEN HUA
 楼主| 发表于: 2017-1-19 18:01:30
crottt kkkkk
发表于: 2017-7-18 07:22:19
merci beaucoup
发表于: 2017-7-18 07:23:27
merci beaucoup
GMT+8, 2025-12-15 14:23 , Processed in 0.072611 sec., 10 queries .
