查看: 3957|回复: 0
飞利浦42PFL1335-T3正常的打印信息(809F读取)
发表于: 2016-1-18 11:54:36
Macaw12: BD_MST030B_10AL8_12052
SPI BOOT
Console Initial OK
BIST_0 PASS.
76
[23456789ABC][23456789AB]
0076
MIU Initial OK
[LGPS]: u16LongPulseThr = 0379
[INTG]: u16IntegrationThr = 0024
[WDOG]: u8WatchDogCount = 0021
Keypad Initialize OK
MDrv_PNL_Init u32PnlRiuBaseAddr = A0200000
MDrv_PNL_Init u32PMRiuBaseAddr = A0000000
[XC,Version] 00589490
MApi_XC_Init, 558, pXC_InitData->stPanelInfo.eLPLL_Type=1
MApp_DB_LoadHDCP_KEY
HDCP_DB_BANK 0x3B
FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
CHECK HDCP data:NG!
HDCP_INDEX = 99;
CHECK HDCP data:OK!
MHL Init, MHL_TYPE = 0x20
mapi_mhl_init()
**Load MHL EDID...
**Load DevCap...
GE_SetOnePixelMode
[GOP_ALL][Driver Version]: 0087, BuildNum: 1887, ChangeList: 2147483647
[HAL_GOP_InitMux] ((gop4g<<2)|gop2g):1
[HAL_TSP_CPU_SetBase][2156] load firmware (address, size) = (0x00476C00, 0x00002820)
firmware 111 0x00476C00 0x00000000 0x00008ED8
[HAL_DSCMB_SetBank][156] Set bank 0xA0200000
[MST Macaw12 Utopia Version[12.1.49]
--- u8BPStatus=8C
g_u8DCOnOff = OFF
POWERON_MODE_OFF >>
should go to standby!!!!!
MHL power standby mode
[CEC][0] blnRes=0, cecError0=4, cecError1=0
[CEC][1] blnRes=0, cecError0=4, cecError1=0
[CEC][2] blnRes=0, cecError0=4, cecError1=0
[CEC][3] blnRes=0, cecError0=4, cecError1=0
[CEC][4] blnRes=0, cecError0=4, cecError1=0
[CEC][5] blnRes=0, cecError0=4, cecError1=0
[CEC][6] blnRes=0, cecError0=4, cecError1=0
[CEC][7] blnRes=0, cecError0=4, cecError1=0
[CEC][8] blnRes=0, cecError0=4, cecError1=0
[CEC][9] blnRes=0, cecError0=4, cecError1=0
[CEC][End]blnRes=0, cecError0=4, cecError1=0
Power down
MDrv_Power_ExecutePowerDown
=> StandBy
以上为插电源蓝灯亮待机状态信息
以下为按待机键开机状态的信息
鼅屈???
SPI BOOT
Console Initial OK
BIST_0 PASS.
76
0076
MIU Initial OK
HDCP_DB_BANK 0x3B
CHECK HDCP data:NG!
HDCP_INDEX = 99;
CHECK HDCP data:OK!
mapi_mhl_init()
**Load MHL EDID...
**Load DevCap...
GE_SetOnePixelMode
--- u8BPStatus=8C
ENABLE_DMP
bIsUsbPQ3DFlag -------------01
Disable Aeon
Disable Aeon Done
Auth OK
create Audio SHM data ...
Change to CEC wake up sourceCurrent software version: 8
ui8dDmodState:0x5 configure done:0x1 ui8SDPReset:0x1
bypass state:0x0; Tuner used(silicon tuner=0):0x1
tuner ui8ADCConfig: 0x14; ui8LNAOnOff: 0x0
ui8FreqOffset 0x08_0x00: 0xA0
ui8FreqOffset 0x08_0x01: 0x16
IF freq_lif: 0x39 0xE9  0x34
ADC rate ratio: 0x0 0x0  0x10
DSP reset options ui8FatalRst = 0x1, ui8WeakRst =  0x1
TS interface ui8SerialEnabled= 1 ui8SamplingEdegeMode =1, clock select ui8ClockOutSelect0
msAPI_Tuner_Serial_Control(bParallelMode=0)
Serial_mode=1
UI_INPUT_SOURCE_COMPONENT2
DSP code loaded successfully
_MAPP_EPGDB_Setup: [Current EPG DB occupy size: 0x4F5AD8];  [Max EPG DB config. size: 0x500000]
unsupport compress
Lvds Clock To Gpio
========= CUS04_ATV_MM_M12 =========
DVB-T Software Version: 0.00
[Board]: BD_MST030B_10AL8_12052
[Panel]: K420WD_LD280_A
[Tuner]: NUTNUE_FK1602
[DRAM TYPE]: DDR2
[MEMORY_MAP]: MMAP_64MB
[DRAM SIZE]: 64 MB
[FLASH SIZE]: 4 MB
[ATV]: PAL
[Mirror]: 0
[ENABLE_PWS]: 1
[ENABLE_POWER_SAVING_DPMS]: 1
[DEMO_FINE_TUNE]: DFT_STD_ORIGINAL_SETTING
[ENABLE_DLC]
[DISPLAY_LOGO]
=> DC_BOOT (1)
PM Wakeup by SAR
GMT+8, 2024-12-19 23:47 , Processed in 0.050273 sec., 9 queries .
