用户名  找回密码
楼主: admin
PEB-1扩展板读写速度统计_配套RT809F使用_支持IT8586E_IT8580E系列EC和多引脚BIOS
发表于: 2017-1-15 11:38:42
怎么 我下载 的版本16  年9月9号的  没有设置线序这个 功能啊
举报
发表于: 2017-1-29 22:14:36
恳求阅读权限。。。。。。。。。。。啊
举报
发表于: 2017-2-3 19:49:01
谢谢楼主的分享
举报
发表于: 2017-2-9 19:55:44
IT8518能读写吗?这个EC带程序吗?
举报
发表于: 2017-2-15 14:57:09
谢谢楼主的分享经验
举报
发表于: 2017-3-4 13:22:42
admin 发表于 2016-4-9 14:09
请使用160408测试版软件,并将IT8586E的第100脚接GND。
Hi admin, I'm using RT809F + PEB-1 for read and write IT8586E.
When I'm using "Adapter BOARD" (IT8586E soldered on the PCB Adapter Board), it can read and write successfully without problem.
But, when I'm using FPC Cable to connect KB Connector on MotherBoard to KB Connector on Adapter Board, I always get "Chip failed enter into ISP status, operation terminated"
I have select the line before but always get the problem.
I have try :
1. I checked "Change Sequence Order". My KB Connector on MB (NM-A281) have different sequence "pin 1" with KB Connector on Adapter Board, the result is same Error.
2. Rearrange the line so I dont "checked sequence order", same result Error.
3. Connect IT8586E pin 20 & pin 21 to GND, same result Error
When I checked the scheme of Adapter Board, I have different things in MB Board
1. On Adapter Board, IT8586E pin 3 go to PEB-1 pin 34, but in my MB (NM-A281) it short to GND
2. On Adapter Board, IT8586E pin 14 (WRST#) go to PEB-1 pin 35
3. On Adapter Board, IT8586E pin 20, pin 21, pin 113 go to PEB-1 pin 33
4. On Adapter Board, IT8586E pin 112 go to PEB-1 pin 40
5. On Adapter Board, IT8586E pin 26, pin 50, pin 74, pin 92, pin 114 go to PEB-1 pin 37
6. On Adapter Board, IT8586E pin 127 go to PEB-1 pin 38
7. On Adapter Board, IT8586E pin 1, pin 27, pin 49, pin 75, pin 91, pin 122 go to PEB-1 pin 36 (GND)
So whats wrong for this ERROR ?
举报
发表于: 2017-3-4 13:39:57
This is the picture
举报
发表于: 2017-3-7 08:43:36
刚买了RT809F,先用着,以后准备再购买一块RT809H。
举报
发表于: 2017-3-15 14:16:36
sir i buy RT809H last one month but i dont know how program IT85XX SERIES , npce288/388 . please help me . i activated my programmer seriel no also.
举报
发表于: 2017-3-15 14:26:48
RT809H very fast read and right , its good
举报
GMT+8, 2025-4-14 03:15 , Processed in 0.052725 sec., 11 queries .
