用户名  找回密码
楼主: admin
PEB-1扩展板读写速度统计_配套RT809F使用_支持IT8586E_IT8580E系列EC和多引脚BIOS
发表于: 2016-4-9 22:34:42
hello friend what I'm doing wrong ?
举报
 楼主| 发表于: 2016-4-10 13:27:37
If the chip is blank,please connect the Pin100  to GND with a fly line.
举报
发表于: 2016-4-11 13:07:45
admin
非常感谢你
举报
发表于: 2016-4-11 22:18:39
thank you friend solved by placing pin 100 on GND Thanks
举报
发表于: 2016-4-20 00:02:38
hi,
after connect pin 100 to gnd i am able to write few chips.
few days later i try to write chip from same roll pack.
but this error give me.
after this error i just shut down pc. turned on again.
programmer is not detect chip.
after i put new chip same process happening.
what should i do?
is peb-1 make chip wrong?
please help.
连接销100之后至GND,我能够写一些筹码。
几天后,我试着写从同一个卷组的芯片。
但这个错误给我。
这个错误后,我就关闭电脑。再次导通。
程序员无法检测芯片。
之后,我提出了新的芯片同样的过程发生。
我该怎么办?
为PEB-1使芯片错了吗?
请帮忙。
举报
发表于: 2016-4-20 00:17:21
能否请你给我PEB-1引脚连接到TQFP128连接示意图
举报
 楼主| 发表于: 2016-4-20 08:54:55
举报
发表于: 2016-4-20 12:37:32
checked all pin one by one. everything is ok. pin 100 to gnd also ok. but still gives me error.
检查了所有在一个接一个。 一切都好。销100也GND确定。但仍然给我的错误。
举报
发表于: 2016-4-20 12:49:35
这个错误后,程序将无法检测到8586e了。
举报
GMT+8, 2025-4-23 07:10 , Processed in 0.063916 sec., 10 queries .
