楼主: BenCesur
RT809F verify error. I'm need help.
 楼主| 发表于: 2016-1-6 06:21:14
Thanks Admin.
But same error again.
001:  D:\BILGISAYAR-TAMIR\BIOS\KBC ROM\KB9012\QCLA4 LA-8861P.BIN
002:  File loading OK. Checksum: 16bit_0x91DA,32bit_0x010491DA;
003:  Programming device......
004:  Erase & Write successfully,19.91 seconds elapsed.
005:  Auto verifying...
006:  Device blank checked failure,start address: 0x7DA.
007:  Verified failure,0.108 seconds elapsed.
008:  Write error occurred,Operation was aborted
 楼主| 发表于: 2016-1-6 06:30:24
Admin;
Software nevest version.
Not USB hub. Directly pc connect.
Via 2 different adapters and 5 different kb ic tried.
Same.
001:  D:\PC\BIOS\KBC ROM\KB9012\QCLA4 LA-8861P.BIN
发表于: 2016-6-11 16:39:58
Hello.I have the same problem.Verification error.An the opened and written file is not the same that is readed out.
Start verifying chip......
086:  Chip verification error, start position: 0x800.
087:  Start verifying chip......
088:  Chip verification error, start position: 0x800.
089:  Start writing chip......
090:  Elapsed time: 21.52 seconds£¬average speed of 6092 bytes/sec.
091:  >------------------------------------OK---------------------------------------<
092:  Start verifying chip......
093:  Chip verification error, start position: 0x500.
094:  Start verifying chip......
095:  Chip verification error, start position: 0x500.
096:  Start verifying chip......
097:  Chip verification error, start position: 0x500.
098:  Start blank checking chip......
099:  Chip is not blank, start position: 0x0.
An after different write/read session different verify error.
发表于: 2016-6-13 11:04:04
楼主你请教季老师啊??????
GMT+8, 2024-12-21 12:45 , Processed in 0.071989 sec., 10 queries .
