查看: 6109|回复: 4
求助长虹JUC7.820.00064487主板打印信息
发表于: 2015-12-30 09:27:10
开机打印信息如下,不知道升级主程序可以升级好吗,还是要重写引导?引导在
nand内存里面,809f不能写,怎么修复?现在是开机没有启动画面
Boot-
DRAM Channel A Calibration.
HW Byte 0 : DQS(26 ~ 53), Size 28, Set 36, HW_Set 43.
HW Byte 1 : DQS(20 ~ 50), Size 31, Set 32, HW_Set 37.
HW Byte 2 : DQS(25 ~ 54), Size 30, Set 36, HW_Set 44.
HW Byte 3 : DQS(21 ~ 54), Size 34, Set 34, HW_Set 38.
DRAM A Size = 512 Mbytes.
Boot
Start Pmain
0x0000a000
Nand boot
NID=0x2690d398
LZHS addr:0x00100040
LZHS size:0x0008a008
LZHS checksum:0x000000bc
Boot
Start Lmain
No PCIE on this board.
MT5396 Boot Loader v0.9
Boot reason: A/C power on!!
read from eeprom ioff 0 phy_off f00
SIF_Master0: new design
CEC Physical offset 159
HDMI1 Physical adr 0xff
HDMI1 PA 0xff
HDMI1 checksum 0xff
HDMI2 PA 0x20
HDMI2 checksum 0xde
HDMI3 PA 0x30
HDMI3 checksum 0xce
HDMI4 PA 0x40
HDMI4 checksum 0xbe
IR DATA register : 0x       0
T8032 init A/C on case loader stage...
Load T8032 FW (addr: 0x  d62910, size: 24576)success!!
T8032 FW version: 24
LDR_FlashCopy 0xf010 0x45280 0x80
Detect NAND flash ID: 0x2690D398
Detect TC58DVG3S0E/FTA00 NAND flash(SLC): 1024MB
NAND_BDM_Mount: Partid=0, offset=0x0, size=0x400000
NAND_BDM_Mount: Partid: 0, Total Block Count: 16, Bad Block Count: 0
Disable VGA wakeup
GPIO_MtkLedCtrlFunc_eLedStatus=2
---standby_EEPDTV_GetCfg, bLedOnOff = 0x1!!
Standby           ?!
HW Byte 0 : DQS(26 ~ 54), Size 29, Set 37, HW_Set 43.
HW Byte 2 : DQS(25 ~ 54), Size 30, Set 36, HW_Set 43.
HW Byte 3 : DQS(21 ~ 56), Size 36, Set 35, HW_Set 39.
Boot
Start Pmain
0x0000a000
Nand boot
NID=0x2690d398
Boot
Start Lmain
/////////////////////////////go in PDWNC_Init(void)
GPIO_MtkLedCtrlFunc_eLedStatus=1
Enable Led blinking (gpio_idx 200, on_value 1, period 20, type: SRV)
USB0: Set GPIO43 = 1.
USB1: Set GPIO44 = 1.
USB2: Set GPIO211 = 1.
USB3: Set GPIO210 = 1.
test current product usb number=3
test for set usbhub reset success!!
Do USB upgrade
USB: Vbus turn up time = 258 ms, Max =0 ms.
No USB device.
USB upgrade stop
Read boot logo index from eeprom: 0, 0x01
Load boot logo index: 0
NAND_SDM_Mount: Partid=9, offset=0x3d600000, size=0x2a00000
NAND_SDM_Mount: Partid: 9, Total Block Count: 168, Bad Block Count: 0
Find panel index 97 from EEPROM
Translate panel index to 97
wPanelNumber == 109
u4Offset == 0x7e70
Calc Flashpanel attrib checksum =0xff
[xh_dbg] select flash panel's base data
Calc Flashpanel ex_attrib checksum =0xffffffff
[xh_dbg] select flash panel's extra data
[hhhxxx] panel_table.c
[hhhxxx] LoadProductIndex line 7304
Find product index 48 from EEPROM
[xh_pnl_drv]set CHProductTypeIndex = 48  n[LVDS] vDrvLVDS7To4FifoEnable !
---------- [SA7] vErrorHandleInit ----------
[SA7] Error handling init
[SA7] PANEL_GetPanelWidth=0x556, PANEL_GetPanelHeight=0x300 , wDrvGetOutputHTotal=0x898 , wDrvGetOutputVTotal=0x465
[SA7] PANEL_GetHTotalMax=0x7d0, PANEL_GetHTotalMin=0x5b4, PANEL_GetVTotalMax=0x3f7, PANEL_GetVTotalMin=0x310
[SA7] PANEL_GetPixelClkMax=80000000, PANEL_GetPixelClkMin=63000000
[SA7] PANEL_GetPixelClk60Hz = 0x4c61e80
---------- [SA7] vErrorHandleSetByTiming ----------
[SA7] u2HSyncWidth=280, u2HSyncStart=1920, u2VSyncWidth=45, u2VSyncStart=1080
---------- [SA7] vErrorHandleSetByTiming end----------
---------- [SA7] vErrorHandleSetByPanel end----------
[SA7] vDDDSInit
GetVDelay50Hz     = 65535
GetHDelay50Hz     = 255
GetHDutyCycle50Hz = 909
[SA7] u2HSyncWidth=30, u2HSyncStart=1382, u2VSyncWidth=3, u2VSyncStart=804
vDrvSetOCLKClockSchemaInit.
[SA7] _fgVopllUseDDDS = True
[LVDS] VOPLL Initialize successful !
[SA7]u4DispBit = 0x      20, u4LVDSPort = 0x       0u4FinaleEnablePair = 0x  effff0
======= [SA7] vDrvLVDSOn toggele RG_LVDSA_EN ===========
---------- Panel[ 97] CHM_M320X12_D5_A 1366x768 ----------
PixelClk[Max=80000000, 60Hz=80092800, 50Hz=66744000, Min=63000000]
HTotal[Max=2000, 60Hz=1648, 50Hz=1648, Min=1460] HSyncLen[60Hz=282, 50Hz=282]
VTotal[Max=1015, 60Hz=810, 50Hz=810, Min=784] VClk[Max=63, Min=47]
HSyncWidth=30, VSyncWidth=3, HPosition60Hz=0x810, HPosition50Hz=0x810, VPosition=1024
LVDS_JEIDA, LVDS_ODD_SW_OFF, SINGLE_PORT, DISP_24BIT
WFB_PANEL_RESET_OFF, PWM_LOW_PANEL_BRIGHT
3D_POLARIZED_RLRL, SPLIT_OFF,
Backlight[High=0x0, Middle=0x80, Low=0xb3]
DimFreq60Hz=160, DimFreq50Hz=160
Delay[LvdsOn=20, BacklightOn=500, BacklightOff=20, LvdsOff=20]
MaxOverscan=50
Current panel setting is CHM_M320X12_D5_A
Backlight gpio=204, turn on value=0, LVDS gpio=209, turn on value=1
Pixel Shift=0 (1366 x 768)
Color:14 BmpAddr:0x0f000000 Width:1366 Height:768
osd flip en
osd mirror en
Panel 1366 x 768
LDR_OsdDisplay(14, 0x0f000000, 1366, 768) return 0
Flash load lzhs header from 0x80000 to dram(0x1543490), size=2048
Decompression uboot to 0x00800000...
Flash load image from 0x80000 to dram(0x1543490), size=0x3a31c
secure boot ok
LZHS start
LZHS done
Starting image...
U-Boot starts...
Booting sequence is from NAND Flash
Detect TC58DVG3S0E/FTA00 NAND flash: 1024MB
1024 MiB
0.0.0.0
In:    serial
Out:   serial
Err:   serial
Net:   init MMAC driver
ethernet internal PHY init successful!
priv : 0x007252b0
Mmac:hyAddr=0
Mmac::initialize
Loading from nand0, offset 0x800800
Attempt to read non page aligned data, continue: offset:0x800800 page:0x1000
Loading from nand0, offset 0x1a00000
## Booting kernel from Legacy Image at 00008000 ...
   XIP Kernel Image ... OK
OK
Starting kernel ...
___lzo_mod_init___
___init: /init.mt5396.rc: 30: invalid option 'write'
init:init: cannot open '/initlogo.rle'
!@#!@# @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ alsa_card_dummy_init 201105032315
!@#!@# @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ fake_buffer=0
@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ alsa_card_dummy_init end
init: =========>starting console
/ # init: I read console
init: the model is changhong and logo is changhong
init: =================dtv_update bash running======================
init: need not to update system libi ************
init: =====changhong model select module init=======
init: =========>starting servicemanager
init: =========>starting vold
init: =========>starting netd
init: =========>starting debuggerd
init: =========>starting ril-daemon
init: =========>starting zygote
init: =========>starting media
init: =========>starting dbus
init: =========>starting installd
init: =========>starting keystore
init: =========>starting insmod
init: =========>starting pre-init
init: =========>starting dtv_svc
init: =========>starting post-init
init: =========>starting chlogohandle
==> pre-init start
5.55 9.31
input: Dummy Touch Screen as /devices/virtual/input/input1
prepare to changed logo to changhong
[USB2] Vbus On.
[USB3] Vbus On.
currlogo = changhong
[SHM alloc]{size = 20480, order = 3, ui4_page_num =5}
adapt_dev_mmap vma->vm_pgoff = 18c90, vm_start = 4010d000, vm_end = 4747d000
dtv_svc_main: fbm phy addr = 18c90000, share mem addr = 40108000, vir addr = 4010d000, size = 121044992
TO USER LEAVE :
Register the cb_entry 0x00026864
_make_post_reg_addr_to_kernel error.
Reg WDT interrupt callback successful..
drv_init as 0x39 model
SCWatchdog enable:1080000000
_FCT_0: sched_getparam 716 error -1
[CEC]_Cec_Process8032Data msg num = 0.
Disable gpio 200 Led blinking
wPanelNumber == 109
u4Offset == 0x7e70
[PCMCIA]Internal CI.
[PCMCIA]CI 5V Power On
[PCMCIA]PCMCIA_Init : 0
TunerInit.....................[Vendor_Demod]Total 3 func table exist
[Vendor_Demod]TunerAll u1PrCfg =0
[Vendor_Demod]TunerAll tunertype 0x76
[SWDMX]FBM_POOL_TYPE_SWDMX: 0x1de27c70, 2359296
[SWDMX]_u4APreFIFO: 0xdde27c70--0xde067c70, 2359296
 楼主| 发表于: 2015-12-30 09:28:49
TVD MsgCtrl:  NRL:60/40, PER:100/90
current--amp =2
[TVD]TVD Descramble Box sts=1[TVD]TVD Descramble Box V Lock sts=1[TVD]TVD Descramble Box Mute Threashold sts=1[Vendor_Demod]Total 3 func table exist
wPanelNumber == 109
u4Offset == 0x7e70
ChanghongTV Adpt: Pnl resolution read ok
[MTVDECEX]:MTVDECEX_HDMI_SetHdcp[MTVDECEX]:_MTVDECEX_HDMI_SetHdcpData
- u4DataCnt = 320
bHDMIHDCPKeySet!!!
DaCEC Physical offset 159
HDMI1 Physical adr 0x10
HDMI1 PA 0x10
HDMI1 checksum 0xd6
HDMI2 PA 0x20
HDMI2 checksum 0xc6
HDMI3 PA 0x30
HDMI3 checksum 0xb6
HDMI4 PA 0x40
HDMI4 checksum 0xa6
[MTVDECEX]:_MTVDECEX_HDMI_SetEdidData
- u4DataCnt = 256
ta
[MTVDECEX]:_MTVDECEX_VGA_SetEdidData
- u4DataCnt = 256
- uc1Length = 320
[MTVDECEX]:MTVDECEX_HDMI_SetEdidData
- uc1Length = 256
[MTVDECEX]:MTVDECEX_VGA_SetEdidData
- uc1Length = 256
---ProductType---u2FlashAqIndex=48  u1Partition=12
!!!! FlashAQ(48) Init OK !!!!
!!!! Load to 2nd page: 3
!!!! Load to 2nd page: 1
_AudOssAdap_Init() 1
[AUD]_u4Capability[1] 1
!!!! Load to 2nd page: 0
!!!! Load to 2nd page: 2
[FeedMixSndThread] Init - 201108011600
[UOP_DSP_MIXSOUND_FLAG] Reset MIXSOUND_MEMPLAY related common dram
[FeedMixSndThread] Enter
Enable Led blinking (gpio_idx 200, on_value 1, period 0, type: OPCTRL)
******_TAS5711_Mute(1)
Panel 1366 768
******_TAS5711_Mute(0)
hello enter,read length:3686400/3686400
#########################read2#####
P3 fading: 0xff
{IOM} UART thread inited.
gl_init MTAL_Init!
gl_init MTAL_Init complete!
gl_init MTGFX_GetBufferPartitio[_AudFeedAlsaMixSndThread] Init - 201109161652
[_AudFeedAlsaMixSndThread] Enter
n complete!
gl_init gl_mem_manager_init complete!
gl_init MTOSD_RGN_LIST_Create complete!
gl_init MTOSD_RGN_Create complete!
[* GL DFB *] Create plane (ON window (Shared)) :1011743
[AUD]!!!! MISS AUD_MW _setoutport, Dec (0), OutPort = 0x00000007
[FM-Linux]Mount /dev/mtd/mtd9 to /data successfully.
[FM](/dev/mtd/mtd9) is mounted to (/data) successfully(0)
{CI_glue}:ci_eng_init
{DT} Real Time Clock is available on this system.
Create FeedStreamThread
warning: `zygote' uses 32-bit capabilities (legacy support in use)
UMP<2>: New session opened
Mali<2>: MMU session begin
Mali<2>: Page directory for session 0xd4d1b320 placed at physical address 0x14E84000
Mali<2>: MMU session begin: success
Mali<2>: Core: session_begin: for Mali-400 PP
Mali<2>: Core: session_begin: for Mali-400 GP
init: =========>starting bootanim
Mali<2>: Page directory for session 0xd4375280 placed at physical address 0x14E88000
{CDB} Loading metadata (version 7)
--get DRV_CUSTOM_CUST_SPEC_PDP_LCD_SEL=2--
--_get
_p
dp
_lc
d_
ty
pe
iu
2_
da
ta=
2-
-_g
et_
p
dp_lc
d_type -iu2_data=2-
--_get_pdp_lcd_type -iu2_data=2-
EEPROM size is 0xba0.
EEPROM size is 0x1000.
[BRDCST] _brdcst_svls_init !!!!
[SCPOS]Scaler mode changed. Turn off impo[BRDCST]  _brdcst_init_scc_component 1101!!!!!
[BRDCST]  _brdcst_init_scc_component surt protection
[SCPOS]Scaler mode changed. Turn off import protection
PE_GetUiRange error! 0, 55, -798114616
ccess 1148!!!!!
[348]{analogScanInit}
[351]{analogScanInit}(h_svctx:17110336)
[367]{analogScanInit}
[235]{dvbcScanInit}
[239]{dvbcScanInit}---scan map init return 0
[255]{dvbcScanInit}
[inps_client][587][x_inps_init] >>>>>>API: x_inps_init()
---update POWER_SAVE  value[NPTV]FlashPQ Gamma OK
:0--
---update
DRV_CUSTOM_VID_TYPE_CH3D_OPRATION:get
PO
WER
_SAVE  val
ue
:0--
--bgama_onoff  = 1---
APP_CFG_RECID_VID_3D_NAV get:0x1
APP_CFG_RECID_VID_3D_NAV set:0x1
APP_CFG_RECID_VID_3D_DISTANCE get:0xffffffff
APP_CFG_RECID_VID_3D_DISTANCE set:0xffffffff
APP_CFG_RECID_VID_3D_IMG_SFTY get:0x0
APP_CFG_RECID_VID_3D_IMG_SFTY set:0x0
MTVDO_RegCbFunc---------
_AUD_DspAmpSet  _fgAmp_used_external=0
_AUD_DspAmpSet(main)  _fgMuted_by_user=0
------------------------------------{_hndlr_channel_set_listener 161}arg[0]=0x80f0a2b5 arg[1]=0x0 return 1271017472
{_hndlr_channel_set_listener 171}a_channel_set_listener return 0
edb_set_listener i4_ret=0
{_hndlr_edb_set_listener 157}a_edb_set_listener return 0
---update---APP_CFG_RECID_AUD_KEY_SOUND----ui1_key_sound=0---
  a_drv_misc_cb_3d_fct_register
  a_drv_misc_cb_usb_fct_re
ui1_idx=0
ui1_idx=1
gisterstar: star_open(eth0)
star: request interrupt vector=40
star: Internal PHY mode
star: MAC: 00:14:49:CE:08:66
ADDRCONF(NETDEV_UP): eth0: link is not ready
reason: 0x00000004 - 0x00000000
[inps_client][1839][x_inps_pip_focus_change] >>>>>> API: x_inps_pip_focus_change( 0 ).
[inps_client][1843][x_inps_pip_focus_change] Already in current focus(0)!
ServiceManager: 0xe7c0ChanghongTVService: connect to client
ChanghongTV_Svc_Adpt_GetsID_sRet(GetMo
[xh_drv] get DRV_CUSTOM_CUST_SPEC_TYPE_BARCODE_STATUS 1
delName)
ChanghongTV_Svc_Adpt_GetsID_iRet(GetPanelIsPDP)
[xh_drv] get DRV_CUSTOM_CUST_SPEC_TYPE_BARCODE_STR Y715002549526712090008FD
{x_d_interface_cust_set 111}
<ACFG2> i2_src_gr111--------------= 2
=========== [xinyuan]video zoom flag set:0 ==========
=========== [xinyuan]video zoom flagFRC set:0 ==========
Chan
ghongTV_Svc_Adpt_SetiIDiPara_iRet(18, 0)
 楼主| 发表于: 2015-12-30 09:31:55
ChanghongTV_Svc_Adpt_SetiIDiPara_iRet(18, 0)
Pcmcia_Set(): nothing has been done
/home1/brianpchuang/auto/p4/w/20120531_105340/changhong_android_REL_Disty/vm_linux/dtv_linux/dtv_driver_adpt/mt5396/adaption/adpt_res_mngr/rm_dev.c 2887:RM DEV ERR:e_set_type 265, e_drv_type 208, ret:-16
[MD:ResMgr] rm_set:e_set_type=265, h_obj=0x00050671,
RET:-16, caller:0x00047670
[inps_client][740][x_inps_bind] >>>>>>API: x_inps_bind( win_id: 0 , input_id[NPTV]vApiVideoSetFixColorSpaceMode = 0!
Disconnect FB at VFE disconnect
: 2 )
[inps_client][766][x_inps_bind] {x_inps_bind 766} set [main_svctx] input source to (2)
[inps_client][279][_inps_svctx_nfy] TV_WIN_ID_MAIN[e_code:1]
[inps_client][279][_inps_svctx_nfy] TV_WIN_ID_MAIN[e_code:8]
[SA7]for Wakeup setting
[IR]//(u4PowerDownEn & WAK_VGA) == 1
[IR]//6896 set vga pdwnc module
[MD:ResMgr] rm_set:e_set_type=2097408, h_obj=0x00010620, RET:1, caller:0x0006c444
{_get_input_grp 670}
{x_d_int
erface_cust_set 111ChanghongTV_Svc_Adpt_SetiIDiPara_iRet(18, 0)
[NPTV]FlashPQ Qty Min/Max OK
wwwwwwwwwwwwwxxxxxxxxxxxxxxxxxx vApiChanghongSC_CalWinOverScan_Aspect_AdjPos timingidx = 0, 147
_ChtvTvdNOtifySrcSignalSt, 0, 0!
ChanghongTVService::c_notify_callback(8, 0, 0)
ChanghongTVService::notify_callback(8, 0, 0)
[inps_client][279][_inps_svctx_nfy] TV_WIN_ID_MAIN[e_code:6]
[MD:ResMgr] rm_set:e_set_type=2097408, h_obj=0x0001061
a, RET:1, caller:0x00051b6c
{/home1/brianpchuang/auto/p4/w/20120531_105340/changhong_android_REL_Disty/vm_linux/dtv_linux/dtv_driver_adpt/mt5396/adaption/adpt_res_mngr/rm_dev.c 2887:RM DEV ERR:e_set_type 2097412, e_drv_type 272, ret:-16
Chang[VDP]------- in VDP_DrvSrcRangeChgNotify--------
[MD:ResMgr] rm_set:e_set_type=2097412, h_obj=0x00010613, RET:-16, caller:0x00051c38
[MD:ResMgr] rm_set:e_set_type=2097408, h_obj=0x00010614, RET:1, caller:0x0016b048
----------uiCurrent_SrcTypTmg not change:18!----------
Ch[VDP]------- in VDP_DrvSrcRangeChgNotify--------
[SM] AS(0x010114A5), set audio format (AUD_DEC_FMT_PCM)
[MD:ResMgr] rm_set:e_set_type=2097408, h_obj=0x00010609, RET:1, caller:0x00133f60
[inps_client][279][_inps_svctx_nfy] TV_WIN_ID_MAIN[e_code:35]
[inps_client][279][_inps_svctx_nfy] TV_WIN_ID_MAIN[e_code:5]
{_inps_signal_status_nfy_fct_wrapper 113}
{_inps_signal_status_nfy_fct_wrapper 124}
{_get_input_gr 670}
{{_get_input_grrpp  6670}
[inps_client][318][_inps_svctx_nfy] INPS_STATE_READY_BIND (signal loss:1)
{_nfy_operation_done_nfy_fct_wrapper 138}
{_nfy_operation_done_nfy_fct_wrapper 149}
<ACFG2>e_screen_mode--------------= 6015712
[inps_client][279][_inps_svctx_nfy] TV_WIN_ID_MAIN[e_code:37]
 楼主| 发表于: 2015-12-30 09:33:14
{x_d_in
ChanghongTV_Svc_Ad[VDP]------- in VDP_DrvSrcRangeChgNotify--------
=========== [wqtt]WIFI_GPIO_SWITCH set:0 ==========
[MD:ResMgr] rm_set:e_set_type=265, h_obj=0x00050671, RET:-16, caller:0x00047670
[inps_client][740][x_inps_bind] >>>>>>API: x_inps_bind( win_id: 0 , input_id: 2 )
APP_CFG_RECID_PDP_LCD_GEL be
gin--------
get APP_CFG_RECID_PDP_LCD_GEL :2
UMP<2>: Session closed
Mali<2>: Session ending
Mali<2>: Core: session_close: for Mali-400 GP
Mali<2>: Core: session_close: for Mali-400 PP
Mali<2>: MMU session end
Mali<1>: Cleanup of descriptor 1 mapping to 0xd61407e0 in descriptor table
Mali<1>: Cleanup of descriptor 3 mapping to 0xd66ed560 in descriptor table
Mali<2>: Session has ended
DISABLE MediaScanner
[AUD]======> AV Sync Thread GoGoGo <=======
init: =========>starting adbd
Linux video capture interface: v2.00
===logo===
usbcore: registered new interface driver uvcvideo
USB Video Class driver (v0.1.0)
gin--------
fuse init (API version 7.14)
[xh_drv] get DRV_CUSTOM_CUST_SPEC_TYPE_GET_CURRENT_PANEL_IS_3D 1
NTFS driver 2.1.29 [Flags: R/O MODULE].
input: mtkinp_events as /devices/virtual/input/input2
input: Changhong V mouse as /devices/virtual/input/input3
input: ChangH-touch as /devices/virtual/input/input4
vinput driver  init successful!
Component {com.android.providers.media/com.android.providers.media.MediaScannerReceiver} new state: disabled
init: untracked pid 1506 exited
init: untracked pid 962 exited
Bluetooth: Core ver 2.15
NET: Registered protocol family 31
Bluetooth: HCI device and connection manager initialized
Bluetooth: HCI socket layer initialized
Bluetooth: L2CAP ver 2.14
Bluetooth: L2CAP socket layer initialized
Bluetooth: HIDP (Human Interface Emulation) ver 1.2
Bluetooth: Generic Bluetooth USB driver ver 0.6
usbcore: registered new interface driver btusb
rtusb init rt2870 --->
usbcore: registered new interface driver rt2870
rtw driver version=v3.3.1_3083.20111213
##########rtw_suspend_lock_init ###########
usbcore: registered new interface driver rtl8192cu
usbcore: registered new interface driver r871x_usb_drv
USBHIF Version 1.xx Loaded...
HTC HOST Version 1.xx Loaded...
ath_hal: 0.9.17.1 (AR5416, DEBUG, REGOPS_FUNC, WRITE_EEPROM, 11D)
ath_dfs: Version 2.0.0
Copyright (c) 2005-2006 Atheros Communications, Inc. All Rights Reserved
ath_rate_atheros: Copyright (c) 2001-2005 Atheros Communications, Inc, All Rights Reserved
ath_dev: Copyright (c) 2001-2007 Atheros Communications, Inc, All Rights Reserved
ath_usb: Copyright (c) 2001-2005 Atheros Communications, Inc, All Rights Reserved
ath_module_init loaded
ath_module_init : Max. WiFi device support to 2
usbcore: registered new interface driver ATHEROS_AR9271
Compat-wireless backport release: compat-wireless-2011-09-19-2-g5904b94
Backport based on linux-next.git next-20110927
cfg80211: Calling CRDA to update world regulatory domain
[xh_drv] get DRV_CUSTOM_CUST_SPEC_TYPE_SW_VERSION_INFO_STR =LM38-V1.00051-F2.60-P1.41-A010-T8$
[xh_drv] get DRV_CUSTOM_CUST_SPEC_TYPE_DTV_ATV_SEL 0
[xh_drv] get DRV_CUSTOM_CUST_SPEC_TYPE_NETWORK_DATA_ADDRESS adr = 0x c00  size = 160
usbcore: registered new interface driver ath6kl_usb
===running changhong script here===
find changhong.rsstore, do nothing !
Status: 0121 index: ff.
Status: 0130 index: ff.
Status: 0118 index: ff.
input: uinput as /devices/virtual/input/input5
[xh_drv] get DRV_CUSTOM_CUST_SPEC_TYPE_PRODUCT_NAME_STR 3D32B2000i
Mali<2>: Page directory for session 0xcdfc2f20 placed at physical address 0x14E88000
gin--------
发表于: 2019-6-7 15:59:19
怎么联机的。告诉我一下
GMT+8, 2024-11-26 21:21 , Processed in 0.083508 sec., 11 queries .
