查看: 10217|回复: 6
康佳LED32IS97
发表于: 2013-5-31 15:45:15
UART_115200
BIST0-OK
BIST1-OK
[0123456789][012345678]-44
[12345678][0123456789]-44
_nPD
U-Boot 1.1.6 (Mar 19 2010 - 17:39:59)
Board: MSTAR TITANIA (CPU Speed 504 MHz)
DRAM:  0x8000000
Skipping flash_init
Flash:  0 kB
NAND:  nand_bbt: searching bbt....Bad block table found at page 262080, version 0x01
nand_bbt: searching bbt.....Bad block table found at page 262016, version 0x01
nand_read_bbt: Bad block at 0x050a0000
nand_read_bbt: Bad block at 0x151e0000
512 MiB
In:    serial
Out:   serial
Err:   serial
Net:   No ethernet found.
MSVC00B000100100208768TH0000000T
Set MIU0 group priority:c9.....
Set MIU1 group priority:c9.....
Change MIU0 select.....
Group0:d80   Group1:88    Group2:200   Group3:f1
Change MIU1 select.....
Group0:4200  Group1:e00   Group2:30    Group3:4000
start init IIC-------------->
come to konka path----@1------
EEPROM @0x0 read: addr 80200000  off 1ffa  count 1 ... cmd: md.b 0x80200000 0x1
80200000: ff    .
done
EEPROM @0x0 read: addr 80400000  off 1ffb  count 1 ... cmd: md.b 0x80400000 0x1
80400000: ff    .
done
memory display value read from eeprom ----->:80200000: 5a5aa5ff    ..ZZ
80400000: 800010ff    ....
data_1[1FFA]--->:ff
data_2[1FFB]--->:ff
---------->defatult_set is:165
---------->defatult_set1 is:90
*ucp is:255
*ucp1 is:255
startFlag_0 is:1
startFlag_2 is:1
update start------------>
Check USB port[0]:
Host type:2
scanning bus for devices... Wait for hub reset....
1 USB Device(s) found
Check USB port[1]:
??? Waiting for Peripheral Connecting Fail...
usb init failed
Check USB port[0]:
Host type:2
check from usb_init(1)>>>>>>>>>>>>>>>>>>
usb_p_switch is------@1------>>:0
(Re)start USB 0...
Check USB port[0]:
Host type:2
       scanning bus for storage devices... 0 Storage Device(s) found
keypad_pressed is [0]
0x00220000-0x1f260000 : "mtd=3"
Volume KL found at volume id 0
read 4194304 bytes from volume 0 to 81000000(buf address)
## Booting image at 81000000 ...
   Image Name:   Linux-2.6.28.10-mstar
   Created:      2010-11-29   9:57:09 UTC
   Image Type:   MIPS Linux Kernel Image (lzo compressed)
   Data Size:    3585631 Bytes =  3.4 MB
   Load Address: 80400000
   Entry Point:  80404150
   Uncompressing Kernel Image ... OK
Starting kernel ...
L2 enabled
Linux version 2.6.28.10 (root@localhost.localdomain) (gcc version 4.3.2 (Sourcery G++ Lite 4.3-51) ) #27 PREEMPT Mon Nov 29 04:56:36 EST 2010
LINUX started...
boot_command_line: console=ttyS0,115200 ubi.mtd=3,2048 root=ubi:RFS rootfstype=ubifs rw LX_MEM=0x2F00000 EMAC_MEM=0x100000 DRAM_LEN=0x10000000 LX_MEM2=0x45604000,0x2900000 MS_GOP0_MIU=0 mtdparts=edb64M-nand:128k(NPT),1m(BL0),1m(BL1),508160k(UBI),-(NA)
LX_MEM  = 0x400000, 0x2F00000
LX_MEM2 = 0x45604000, 0x2900000
CPHYSADDR(PFN_ALIGN(&_end))= 0x9F4000
EMAC_LEN= 0x100000
DRAM_LEN= 0x10000000
console [early0] enabled
CPU revision is: 00019554 (MIPS 34Kc)
Begin Titania3_setup
BDetermined physical RAM map:
memory: 02f00000 @ 00400000 (usable)
memory: 02900000 @ 45604000 (usable)
Wasting 32768 bytes for tracking 1024 unused pages
Initrd not found or empty - disabling initrd
Zone PFN ranges:
  DMA      0x00000400 -> 0x00008000
  Normal   0x00008000 -> 0x00020000
  HighMem  0x00020000 -> 0x00047f04
Movable zone start PFN for each node
early_node_map[2] active PFN ranges
    0: 0x00000400 -> 0x00003300
    0: 0x00045604 -> 0x00047f04
  Normal zone: 768 pages exceeds realsize 0
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 21001
Kernel command line: console=ttyS0,115200 ubi.mtd=3,2048 root=ubi:RFS rootfstype=ubifs rw LX_MEM=0x2F00000 EMAC_MEM=0x100000 DRAM_LEN=0x10000000 LX_MEM2=0x45604000,0x2900000 MS_GOP0_MIU=0 mtdparts=edb64M-nand:128k(NPT),1m(BL0),1m(BL1),508160k(UBI),-(NA)
alloc ebase: 810e7000
Primary instruction cache 32kB, VIPT, 4-way, linesize 32 bytes.
Primary data cache 32kB, 4-way, VIPT, cache aliases, linesize 32 bytes
Writing ErrCtl register=00006d80
Readback ErrCtl register=00006d80
PID hash table entries: 256 (order: 8, 1024 bytes)
CPU freq count = 252000000
CPU frequency 504.00 MHz
console handover: boot [early0] -> real [ttyS0]
Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
Memory: 82980k/48128k available (4127k kernel code, 7092k reserved, 1387k data, 172k init, 41984k highmem)
SLUB: Genslabs=6, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Calibrating delay loop... 334.84 BogoMIPS (lpj=167424)
Mount-cache hash table entries: 512
net_namespace: 288 bytes
NET: Registered protocol family 16
SCSI subsystem initialized
cfg80211: Using static regulatory domain info
cfg80211: Regulatory domain: US
        (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
        (2402000 KHz - 2472000 KHz @ 40000 KHz), (600 mBi, 2700 mBm)
        (5170000 KHz - 5190000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
        (5190000 KHz - 5210000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
        (5210000 KHz - 5230000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
        (5230000 KHz - 5330000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
        (5735000 KHz - 5835000 KHz @ 40000 KHz), (600 mBi, 3000 mBm)
 楼主| 发表于: 2013-5-31 15:46:31
还没完,,接着来
cfg80211: Calling CRDA for country: US
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 2048 (order: 2, 16384 bytes)
TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
TCP: Hash tables configured (established 2048 bind 2048)
TCP reno registered
highmem bounce pool size: 64 pages
JFFS2 version 2.2. (NAND)2001-2006 Red Hat, Inc.
fuse init (API version 7.10)
msgmni has been set to 80
alg: No test for stdrng (krng)
io scheduler noop registered
io scheduler anticipatory registered
io scheduler deadline registered
io scheduler cfq registered (default)
Serial: 8250/16550 driver4 ports, IRQ sharing disabled
serial8250: ttyS0 at I/O 0xbf201300 (irq = 8) is a 16550
serial8250: ttyS1 at I/O 0xbf220c00 (irq = 79) is a 16550
serial8250: ttyS2 at I/O 0xbf220d00 (irq = 90) is a 16550
brd: module loaded
loop: module loaded
PPP generic driver version 2.4.2
PPP Deflate Compression module registered
PPP BSD Compression module registered
PPP MPPE Compression module registered
NET: Registered protocol family 24
PPPoL2TP kernel driver, V1.0
pegasus: v0.6.14 (2006/09/27), Pegasus/Pegasus II USB Ethernet driver
usbcore: registered new interface driver pegasus
rtl8150: v0.6.2 (2004/08/27):rtl8150 based usb-ethernet driver
usbcore: registered new interface driver rtl8150
usbcore: registered new interface driver asix
usbcore: registered new interface driver cdc_ether
usbcore: registered new interface driver net1080
usbcore: registered new interface driver rndis_host
usbcore: registered new interface driver cdc_subset
usbcore: registered new interface driver zaurus
Linux video capture interface: v2.00
usbcore: registered new interface driver uvcvideo
USB Video Class driver (v0.1.0)
Driver 'sd' needs updating - please use bus_type methods
Driver 'sr' needs updating - please use bus_type methods
usbmon: debugfs is not available
Mstar-ehci-2 H.W init
Titania3_later_start_ehc2 start
Mstar-ehci-2 Mstar-ehci-2.1: Mstar EHCI
Mstar-ehci-2 Mstar-ehci-2.1: new USB bus registered, assigned bus number 1
Mstar-ehci-2 Mstar-ehci-2.1: irq 74, io mem 0xbf201a00
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb1: Product: Mstar EHCI
usb usb1: Manufacturer: Linux 2.6.28.10 ehci_hcd
usb usb1: SerialNumber: mstar
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
Mstar-ehci-1 H.W init
Titania3_later_start_ehc1 start
Mstar-ehci-1 Mstar-ehci-1.0: Mstar EHCI
Mstar-ehci-1 Mstar-ehci-1.0: new USB bus registered, assigned bus number 2
Mstar-ehci-1 Mstar-ehci-1.0: irq 15, io mem 0xbf204800
usb usb2: configuration #1 chosen from 1 choice
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb2: Product: Mstar EHCI
usb usb2: Manufacturer: Linux 2.6.28.10 ehci_hcd
usb usb2: SerialNumber: mstar
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
mice: PS/2 mouse device common for all mice
usbcore: registered new interface driver hiddev
usbcore: registered new interface driver usbhid
usbhid: v2.6:USB HID core driver
[ PHY Addr ] ==> :1
alloRAM_ADDR_BASE= 0x3300000  alloRAM_SIZE= 0x100000
After T12 FIX -----------------------------<7>Mstar-ehci-1 Mstar-ehci-1.0: GetStatus port 1 status 000803 sig=j CSC CONNECT
NAND device: Manufacturer ID: 0xec, Chip ID: 0xdc (Samsung NAND 512MiB 3,3V 8-bit)
Creating 5 MTD partitions on "NAND 512MiB 3,3V 8-bit":
0x00000000-0x00020000 : "NPT"
mtd: Giving out device 0 to NPT
0x00020000-0x00120000 : "BL0"
mtd: Giving out device 1 to BL0
0x00120000-0x00220000 : "BL1"
mtd: Giving out device 2 to BL1
0x00220000-0x1f260000 : "UBI"
mtd: Giving out device 3 to UBI
0x1f260000-0x20000000 : "NA"
mtd: Giving out device 4 to NA
parse_cmdline_partitions: add_mtd_partitions
Advanced Linux Sound Architecture Driver Version 1.0.18rc3.
usbcore: registered new interface driver snd-usb-audio
ALSA device list:
  No soundcards found.
TCP cubic registered
NET: Registered protocol family 17
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
ieee80211: 802.11 data/management/control stack, git-1.1.13
ieee80211: Copyright (C) 2004-2005 Intel Corporation <jketreno@linux.intel.com>
====> hub_port_init 1
Plug in USB Port1
VFS: Mounted root (ubifs filesystem).
Freeing unused kernel memory: 172k freed
udev->speed: 3
init started: BusyBox v1.14.2 (2010-01-14 17:26:33 CST)
starting pid 385, tty '': '/etc/init.d/rcS'
usb 2-1: configuration #1 chosen from 1 choice
hub 2-1:1.0: USB hub found
hub 2-1:1.0: 4 ports detected
Initializing random number generator...
usb 2-1: New USB device found, idVendor=0424, idProduct=2514
usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
mknod: /dev/random: File exists
mknod: /dev/urandom: File exists
chown: unknown user/group root:root
1+0 records in
1+0 records out
Mounting vendor
UBIFS error (pid 405): ubifs_scan: corrupt empty space at LEB 1:28730
UBIFS error (pid 405): ubifs_scanned_corruption: corruption at LEB 1:28730
UBIFS error (pid 405): ubifs_scan: LEB 1 scanning failed
UBIFS error (pid 405): ubifs_recover_master_node: failed to recover master node
mount: mounting ubi:VEN on /vendor failed: Invalid argument
Mounting conf
Mounting opt
Mounting chakra
insmod: can't read '/lib/modules/ir.ko': No such file or directory
Open dbus!!
Open Chakra!!
./AP.elf: error while loading shared libraries: libdrvMIU.so: cannot open shared object file: No such file or directory
Mounting kksetting
Mounting kkdoc
Mounting kkopt
Mounting kkwork
Mounting kketc
Mounting font
Mounting PTS
/home/kketc/upgrade/upgrade_daemon: error while loading shared libraries: libmadp.so: cannot open shared object file: No such file or directory
starting pid 455, tty '': '/bin/echo /bin/Xjys > /proc/sys/kernel/hotplug'
Please press Enter to activate this console.
康佳LED32IS97N 6I78 不开机,帮忙看看是神马问题
发表于: 2013-5-31 17:28:19
好几个错误,文件丢失,重新升级主程序试下。
发表于: 2013-5-31 17:41:00
UART_115200
BIST0确定
BIST1-OK
[0123456789] [012345678] -44
[12345678] [0123456789] -44
_nPD
U-Boot的1.1.6(2010年3月19日 - 十七时39分59秒)
局::MSTAR二氧化钛(CPU速度504兆赫)
DRAM:0x8000000
跳绳flash_init
闪光灯:0 KB
NAND:nand_bbt的:BBT搜索.... 262080页,版本0X0&#8203;&#8203;1发现坏块表
搜索nand_bbt:BBT ..... 262016页,版本0X0&#8203;&#8203;1发现坏块表
:坏nand_read_bbt的块0x050a0000
:坏nand_read_bbt的块0x151e0000
512 MIB
:串行
日期:串行
错误:串行
净:没有以太网。
MSVC00B000100100208768TH0000000T? ?
设置MIU0组优先级:C9 .....
设置MIU1组优先级:C9 .....
设置MIU0组优先级:C9 .....
设置MIU1组优先级:C9 .....
更改选择MIU0 .....
GROUP0:D80组别:88第2组:200组3:F1
更改选择MIU1 .....
GROUP0:4200组别:E00第2组:30组3:4000
启动初始化IIC -------------->
康佳路径---- @ 1 ------
EEPROM @ 0X0读:地址80200000关闭计数1FFA 1 ... CMD:md.b 0x80200000 0X1
80200000:FF。
EEPROM @ 0X0读:地址80400000关闭计数1FFB 1 ... CMD:md.b 0x80400000 0X1
80400000:FF。
内存显示值读取从EEPROM ----->:80200000:5a5aa5ff .. ZZ
80400000:800010ff ....
_1 [1FFA] --->:FF
_2 [1FFB] --->:FF
----------> defatult_set是:165
----------> defatult_set1是:90
* UCP是:255
* UCP1是:255
startFlag_0是:1
startFlag_2是:1
更新开始------------>
检查USB端口[0]:
主机类型:2
扫描设备总线...等枢纽复位....
1个USB Device(次)
检查USB接口[1]:
?等待外设连接故障...
USB初始化失败
错误,无法初始化低阶部分
检查USB端口[0]:
主机类型:2
扫描设备总线...等枢纽复位....
1个USB Device(次)
检查从usb_init(1)>>>>>>>>>
,usb_p_switch ------ 1 ------ >>:0
(重新)启动USB 0 ...
检查USB端口[0]:
主机类型:2
扫描设备总线...等枢纽复位....
1个USB Device(次)
&#160;&#160;&#160;&#160;&#160;&#160;&#160;扫描总线的存储设备...找到0存储设备(次)
keypad_pressed是[0]
按任意键停止自动引导:0
0x00220000-0x1f260000:“MTD = 3”
卷KL发现在卷ID 0
阅读从0到8100(buf的地址量4194304字节)
##引导形象在8100 ...
&#160;&#160;&#160;图片名称:linux-2.6.28.10-MSTAR
&#160;&#160;&#160;创建时间:2010-11-29 9时57分09秒UTC
&#160;&#160;&#160;图片类型:MIPS Linux内核映像(LZO压缩)
&#160;&#160;&#160;数据大小:3585631字节= 3.4 MB
&#160;&#160;&#160;加载地址:80400000
&#160;&#160;&#160;入口点:80404150
&#160;&#160;&#160;解压缩内核形象...行
从内核开始...
启用L2
Linux的“版本2.6.28.10(root@localhost.localdomain)(gcc版本4.3.2(的Sourcery G+ +精简版4.3-51))#27 PREEMPT的周一11月29日2010年美国东部时间4点56分36秒
LINUX启动时...
boot_command_line:CONSOLE = ttyS0上,115200 ubi.mtd的= 3,2048根部= UBI:RFS rootfstype =的UBIFS RW LX_MEM = 0x2F00000 EMAC_MEM = 0x100000处DRAM_LEN = 0x10000000处LX_MEM2 = 0x45604000,0x2900000 MS_GOP0_MIU = 0 mtdparts = edb64M-NAND:128K(NPT)米(BL0),1M(BL1),508160k(UBI), - (NA)
LX_MEM =为0x400000,0x2F00000的
CPHYSADDR(PFN_AL&#8203;&#8203;IGN(&_end))= 0x9F4000
EMAC_LEN = 0x100000处
控制台[early0]启用
CPU修订为:00019554(MIPS 34Kc)
开始Titania3_setup“
BDetermined物理RAM的地图:
内存:02f00000 00400000(可用)
内存:02900000 45604000(可用)
浪费了32768个字节用于跟踪1024个未使用的页面
initrd文件找不到或空 - 禁用的initrd
区PFN范围:
&#160;&#160;DMA 0x00000400时 - > 0x00008000的
&#160;&#160;正常0x00008000的 - > 0x00020000处
&#160;&#160;HIGHMEM 0x00020000 - > 0x00047f04
活动区开始为每个节点PFN
early_node_map [2]的活跃PFN范围
&#160;&#160;&#160;&#160;0:0x00000400时 - > 0x00003300
&#160;&#160;&#160;&#160;0:0x00045604 - > 0x00047f04
&#160;&#160;普通区:768页超过realsize 0
内置1区运行我们的秩序,流动性分组。总页数:21001
内核命令行:CONSOLE = ttyS0上,ubi.mtd 115200的= 3,2048根部= UBI:RFS rootfstype =的UBIFS RW LX_MEM = 0x2F00000 EMAC_MEM = 0x100000处DRAM_LEN = 0x10000000处LX_MEM2 = 0x45604000,0x2900000 MS_GOP0_MIU = 0 mtdparts = edb64M NAND:128K( “不扩散核武器条约”),1M(BL0),1609米(BL1),508160k(UBI), - (NA)
ALLOC EBASE:810e7000
一级指令缓存32KB,VIPT,4路,行尺寸32字节。
主数据缓存32KB,4路,VIPT,缓存别名,行尺寸32字节
写作ErrCtl寄存器= 00006d80
回读ErrCtl寄存器= 00006d80
PID哈希表项:256(顺序为:8,1024字节)
CPU频率数= 2.52
CPU频率504.00兆赫
安慰切换:启动[early0] - >真实ttyS0上]
的dentry缓存哈希表项:8192(顺序为:3,32768字节)
inode的缓存哈希表项:4096(顺序为:2,16384字节)
内存:提供82980k/48128k(内核代码4127k,7092k保留,1387k的数据,172K的init,41984k HIGHMEM的的)
的SLUB:Genslabs = 6,HWalign = 32,订单= 0-3,MinObjects = 0时,CPU的= 1,节点= 1
校准延迟循环... 334.84的将以bogomips(LPJ = 167424)
山缓存哈希表项:512
net_namespace:288字节
NET:注册协议族16
SCSI子系统初始化
usbcore:注册新的接口驱动程序USBFS
usbcore:注册新的接口驱动枢纽
usbcore:注册新的设备驱动USB
cfg80211:使用静态监管领域信息
cfg80211:监管领域:美国
&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;(start_freq - end_freq带宽),(max_antenna_gain,max_eirp)
&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;(2402000千赫 - 2472000千赫@ 40000千赫),(600 MBI,2700 MBM)
&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;(5170000千赫 - 5190000千赫@ 40000千赫),(600 MBI,2300 MBM)
&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;(5190000千赫 - 5210000千赫@ 40000千赫),(600 MBI,2300 MBM)
&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;(5210000千赫 - 5230000千赫@ 40000千赫),(600 MBI,2300 MBM)
&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;(5230000千赫 - 5330000千赫@ 40000千赫),(600 MBI,2300 MBM)
&#160;&#160;&#160;&#160;&#160;&#160;&#160;&#160;(5735000千赫 - 5835000千赫@ 40000千赫),(600 MBI,3000 MBM)
相关帖子
led19hs95 W25X40(有图片)康佳BT系列液晶彩电主板电路原理图康佳lc32es66电视机开机黑屏康佳_lcd32ds30_lcd32es62康佳LC32GS80C LG屏数据
分享到:
QQ空间
腾讯微博
腾讯朋友
转播0
淘帖0
分享0
收藏0
评分
回复举报
阿尔法罗密欧
3
主题
1
听众
624
积分
高级会员
收听TA发消息
禁止帖子
沙发
&#160;发表于1小时前|只看该作者
还没完,接着来
cfg80211:调用药物滥用资料中央档案室的国家:美国
NET:注册协议族2
IP路由缓存哈希表项:1024(订货量:0,4096字节)
TCP建立哈希表项:2048(顺序为:2,16384字节)
TCP绑定哈希表项:2048(顺序:1,(8192字节))
TCP:哈希表配置(2048绑定2048成立)
TCP里诺注册
NET:注册协议族1
HIGHMEM反弹池大小:64页
JFFS2版本2.2。 (NAND)2001-2006红帽,Inc
融合的init(API版本7.10)
参数msgmni已被设置为80
ALG:没有测试为stdrng(krng)
IO调度NOOP注册
IO调度预见性注册
IO调度的最后期限注册
IO调度CFQ注册(默认)
编号:一万六千五百五十分之八千二百五十driver4端口,禁用IRQ共享
serial8250:ttyS0上的I / O 0xbf201300(IRQ = 8)16550
serial8250登录:ttyS1在I / O 0xbf220c00(IRQ = 79)16550
serial8250:ttyS2设在I / O 0xbf220d00(IRQ = 90)是16550
BRD:模块加载
循环:模块加载
PPP通用驱动程序版本2.4.2
PPP Deflate压缩模块注册
PPP BSD压缩模块注册
PPP MPPE压缩模块注册
NET:注册协议族24
PPPoL2TP内核驱动程序,1.0版
飞马:v0.6.14(2006/09/26),飞马/飞马II USB以太网驱动程序
usbcore:注册新的接口驱动飞马
RTL8150:v0.6.2(2004/08/27):基于RTL8150 USB-以太网驱动程序
usbcore:注册新的接口驱动程序RTL8150
usbcore:注册新的接口驱动ASIX
usbcore:注册新的接口驱动cdc_ether
usbcore:注册新的接口驱动程序net1080
usbcore:注册新的接口驱动rndis_host
usbcore:注册新的接口驱动程序cdc_subset
usbcore:注册新的接口驱动程序的Zaurus
Linux下的视频捕捉接口:V2.00
usbcore:注册新的接口驱动uvcvideo
USB视频类驱动程序(词库v0.1.0)
驱动'SD'需要更新 - 请给bus_type方法
'SR'驱动需要更新 - 请给bus_type方法
usbmon:debugfs的不可用
晨星EHCI-2 H.W初始化
Titania3_later_start_ehc2开始
晨星晨星EHCI-2-EHCI 2.1:晨星EHCI
晨星晨星EHCI-2-EHCI 2.1:新的USB总线注册,分配总线数量1
晨星晨星EHCI-2-EHCI 2.1:IRQ 74,IO MEM 0xbf201a00
USB USB1:配置#1选自1选择
枢纽1-0:1.0:USB集线器发现
枢纽1-0:1.0:1端口检测
USB USB1:新的USB设备发现,符的idVendor = 1d6b,idProduct = 0002
USB USB1:USB设备字符串:MFR = 3,产品= 2,序列号= 1
USB USB1:产品:晨星EHCI
USB USB1:制造商:Linux 2.6.28.10的ehci_hcd
USB USB1:序列号:MSTAR
ehci_hcd:USB 2.0的增强主机控制器(EHCI)驱动器
晨星-EHCI 1 H.W初始化
Titania3_later_start_ehc1开始
晨星晨星EHCI-1-EHCI 1.0:晨星EHCI
晨星EHCI-1晨星EHCI-1.0:新的USB总线登记,分配总线2号
晨星晨星EHCI-1-EHCI 1.0:IRQ 15,IO MEM 0xbf204800
USB USB2:配置#1选自1选择
枢纽2-0:1.0:USB集线器发现
枢纽2-0:1.0:1端口检测
USB USB2:新的USB设备发现,符的idVendor = 1d6b,idProduct = 0002
USB USB2:新的USB设备字符串:MFR = 3,产品= 2,序列号= 1
USB USB2:产品:晨星EHCI
USB USB2:制造商:Linux 2.6.28.10的ehci_hcd
USB USB2:序列号:MSTAR
初始化USB大容量存储驱动...
usbcore:注册新的接口驱动USB存储
USB Mass Storage支持注册。
鼠标:PS / 2鼠标设备共同所有小鼠
usbcore:注册新的接口驱动程序hiddev
usbcore:注册新的接口驱动程序USBHID
USBHID:V2.6:USB HID核心驱动
[PHY地址] ==>:1
alloRAM_ADDR_BASE = 0x3300000 alloRAM_SIZE = 0x100000处
<7>后T12 FIX -----------------------------晨星晨星EHCI-1-EHCI-1.0的getStatus端口1状态000803信号= J CSC CONNECT
NAND设备制造商ID:0xec,芯片ID:0xdc(三星NAND为512MiB 3,3 V 8位)
“NAND为512MiB 3,3 V 8位”创建5 MTD分区:
为0x00000000,0x00020000处:“不扩散核武器条约”
MTD设备0“不扩散核武器条约”
0x00020000处0x00120000:“BL0”
MTD设备1 BL0
0x00120000-0x00220000:“BL1”
MTD设备2至BL1
0x00220000-0x1f260000:“UBI”
MTD装置3 UBI
0x1f260000为0x20000000:“NA”
MTD装置4 NA
parse_cmdline_partitions:add_mtd_partitions
高级Linux声音架构驱动程序版本1.0.18rc3。
usbcore:注册新的接口驱动程序SND-USB音频
ALSA设备列表:
&#160;&#160;没有找到声卡。
TCP立方米注册
NET:注册协议族17
RPC注册的udp传输模块。
RPC:注册TCP传输模块。
IEEE80211:802.11数据/管理/控制堆栈的git-1.1.13
IEEE80211:版权所有(C)2004-2005英特尔公司<jketreno@linux.intel.com>
插入USB端口1
VFS:安装根(UBIFS文件系统)。
释放未使用的内核内存:172K解脱出来
udev的速度:3
初始化开始:BusyBox的v1.14.2(2010-01-14 17点26分33秒CST)
启动PID 385,TTY'':'/ etc / init.d下/ RCS
USB 2-1:选择1选择配置#1
枢纽2-1:1.0:USB集线器发现
枢纽2-1:1.0:4个检测
初始化随机数生成器...
USB 2-1:发现新的USB设备,符的idVendor = 0424,idProduct = 2514
USB 2-1:新的USB设备字符串:MFR = 0 = 0,序列号,产品= 0
MKNOD:为/ dev /随机文件存在
MKNOD:为/ dev / urandom的文件存在
乔敦:未知的用户/组根:根
1 +0记录
1 +0记录了
安装供应商
UBIFS错误(PID 405):ubifs_scan:腐败LEB 1:28730空
UBIFS错误(PID 405):ubifs_scanned_corruption:LEB 1:28730腐败
UBIFS错误(PID 405):ubifs_scan:LEB 1扫描失败
UBIFS错误(PID 405):ubifs_recover_master_node:失败恢复主节点
安装:安装UBI:VEN /供应商失败:无效的参数
安装机密
安装选择
安装轮
insmod的:不能读/ lib中/模块/ ir.ko的“:没有这样的文件或目录
打开dbus的!
打开积分!
。/ AP.elf中:错误而载入共享库:libdrvMIU.so:无法打开共享对象文件:没有那个文件或目录
安装kksetting
安装kkdoc
安装kkopt
安装kkwork
安装kketc
安装字体
安装分
/家庭/ kketc /升级/ upgrade_daemon:错误而载入共享库:libmadp.so:无法打开共享对象文件:没有那个文件或目录
PID为455起,TTY'':'/ BIN /回声/ BIN / Xjys> / proc / sys目录/内核/热插拔
请按Enter键来激活此控制台。
 楼主| 发表于: 2013-5-31 19:38:38
这么强悍啊
Mounting vendor
我升级了主程序,,这个地方还是显示出错
发表于: 2013-6-1 10:34:35
2楼 ,用啥软件翻译的?
发表于: 2013-6-1 17:21:34
此机型采用UBI文件系统,LEB为Logical Erase Block,逻辑擦除块。
如果你升级主程序时没有出现错误并且程序版本和硬件完全对应,那就是LEB映射的PEB上,连续坏块过多造成的了,请更换NAND闪存芯片,然后重新升级。
GMT+8, 2024-12-19 19:00 , Processed in 0.059310 sec., 10 queries .
