查看: 3774|回复: 4
创维32E61HR不开机 8M61机芯请大师看看打印信息
发表于: 2015-12-2 18:57:21
创维32E61HR不开机  8M61机芯请大师看看打印信息打印信息如下、、
UART_115200
BIST0-OK
BIST1-OK
[123456789A][0123456789A]-55
[0123456789A][0123456789]-54
_nPD
U-Boot 1.1.6 (Jan 19 2011 - 20:07:39)
Board: MSTAR TITANIA (CPU Speed 504 MHz)
DRAM:  0x8000000
Skipping flash_init
Module: KEYPAD USB FAT NAND UBI UBIFS NET EEPROM JFFS2 LOGO
NAND:  nand_bbt: searching bbt....Bad block table found at page 65472, version 0x01
nand_bbt: searching bbt.....Bad block table found at page 65408, version 0x01
128 MiB
In:    serial
Out:   serial
Err:   serial
Net:   No ethernet found.
MSVC00B000100100222324DA:100726T
Set MIU0 group priority:c9.....
Set MIU1 group priority:c9.....
Change MIU0 select.....
Group0:d80   Group1:88    Group2:200   Group3:f1
Change MIU1 select.....
Group0:4200  Group1:e00   Group2:30    Group3:4000
cmd: md.b 0x80200000 0x1
80200000: ff    .
80200000: 5a5aa5ff    ..ZZ
.ndata_1[7fa]--->:ff
2.defatult_set is:165
3.*ucp is:255
keypad_pressed_1 is:0
keypad_pressed_2 is:0
1.MSAPI_WDT_StartHit any key to stop autoboot:  0
cmd: md.b 0x874bfef8 0x1
874bfef8: 01    .
cmd: md.b 0x874bfef9 0x1
874bfef9: 00    .
0x00220000-0x07260000 : "mtd=3"
Using volume CK
UBIFS: recovery needed
UBIFS: recovery deferred
UBIFS: mounted UBI device 0, volume 3, name "CK"
UBIFS: mounted read-only
UBIFS: file system size:   %ld bytes (%ld KiB, %ld MiB, 0 LEBs)
UBIFS: journal size:       %ld bytes (%ld KiB, %ld MiB, 0 LEBs)
UBIFS: media format:       w4/r0 (latest is w4/r0)
UBIFS: default compressor: LZO
UBIFS: reserved for root:  %lu bytes (%lu KiB)
ubifs_mount SUCCESS !!
u32ReadBuffVirAddr = a4000000, u32IntBuffVirAddr = a4050000, u32OutBuffVirAddr = a4680000
MApi_JPEG_SetDbgLevel: DbgLevel = 0x0000
verJPD_SetStatus >>>>>>>>>>>>>>>>>>>>>>>> w: 1366  h: 768
PNL_WIDTH=0x556
2.MSAPI_WDT_ClearUBI already initialized!!
Volume KL found at volume id 0
read 4194304 bytes from volume 0 to 81000000(buf address)
发表于: 2015-12-5 15:12:11
先刷机看看呗  没有同型号 不好比较哦
发表于: 2015-12-5 15:39:52
不开机,主板各主要电压,以及背光都什么情况?
发表于: 2016-1-20 11:29:31
请问怎样操作 可以看这个信息
发表于: 2019-6-29 12:08:40
YDMX 2016-1-20 11:29
请问怎样操作 可以看这个信息
同问?
解决了吧
GMT+8, 2024-11-28 00:53 , Processed in 0.050759 sec., 9 queries .
