查看: 4098|回复: 2
正常的创维32E15HR 8M49机芯的打印信息
发表于: 2015-12-1 21:58:12
INNT
55
[56789AB][56789AB]
0088
BOOTR2AP
Hello Janus:A0000000
====> Time: 17:38:19
USB_Init_ConfigureUSB port 0 enter power save done
USB port 1 enter power save done
USB_Init_Configure done...
Flash is detected (0x0904, 0x1C, 0x30, 0x16)
[msKeypad_Init]: Allocated channel number > 2 !!!
sar input test...
----  MApi_XC_Sys_Init
Sub window input source must be disabled before set frame buffer address. Ex:when video play, you canˇt use this function.
[MWE] H-SPLIT-RIGHT/H-SCAN Function
[MWE] Hstart  2E7  Hend  591  Vstart    0 Vend  2FF
s8SN0(7F) s8SN1(0)
Mirror function (0)
_COPRO_Init: u32RiuBaseAdd = A0200000
[PHOTO] Decode Memory
[PHOTO] statue, 0 --> 1
[PHOTO] JPEG, Baseline, (1366x768, 1366(1368)x768), size: 4147200, thumbnail: 0
[PHOTO] Orient: 1, Date Time: NO
[PHOTO] statue, 1 --> 2
[PHOTO] statue, 2 --> 3
[PHOTO] total time: 82, progress: 1000
[PHOTO] statue, 3 --> 0
-------------- Calibration failed.
Delete path failed
i = 0, pPath->src(34)
[_MApi_XC_CheckPostAction_OnPathChange @ 1949] YUV no exist, do EVENT_SOG_CALIBRATION ==>
[MUX]  ======[path created]====== source: 34  sink: 1
==>ADC SetInputSource Count=1
_MApi_XC_PostAction_OnPathChange @ 1958, u8PostCondition_OnPathAdd(0x0)
MApp_DMP_InitDMPStat
[MWE] Hstart   3C  Hend   3B  Vstart    0 Vend  2FF
DSP code loaded successfully
audio DSP_DEC LoadCode success..
===PowerOn_Music===
_GOP_GWIN_AlignChecker, This FB format needs to 4-pixels alignment !!!
Delete path success
Delete path failed
i = 0, pPath->src(2)
[MUX]  ======[path created]====== source: 2  sink: 1
[MUX]  ======[path created]====== source: 2  sink: 20
DVB-T Software Version: 0.00
[Board]: BD_MST6M48_SKYWORTH_QFP
[Panel]: WXGA_AU20_T200XW02
[MEMORY_MAP]: MMAP_64MB
[DRAM SIZE]: 64 MB
[FLASH SIZE]: 4 MB
[Mirror]: 0
[ENABLE_PWS]: 1
[ENABLE_POWER_SAVING_DPMS]: 0
[DEMO_FINE_TUNE]: DFT_STD_FULLHD_CMO216
[ENABLE_DLC]
[MWE]
[DISPLAY_LOGO]
[ENABLE_POWERON_MUSIC]
发表于: 2015-12-1 22:44:59
呵呵   不错不错
发表于: 2015-12-6 21:30:23
                               看不懂啊?
GMT+8, 2024-12-19 21:04 , Processed in 0.049122 sec., 9 queries .
