查看: 3046|回复: 0
LED32K11开机打印信息
发表于: 2015-11-15 14:08:37
2015-11-15, 11:55:28
COM5, BaudRate:115200 bps, RXD: VGA->11,TXD: VGA-> 4, Printed by RT809F:
INNT
55
[56789AB][56789AB]
0088
BOOTR2AP
Hello Janus:A0000000
## heap size is 187K under 300K!!
====> Time: 13:32:57
----  MApi_XC_Sys_Init_Karl_Check
g_u16Miu0_Dqs0~~~~~________-0x=FE0
g_u16Miu0_Dqs1~~~~~_________0x=FE0
core/api/msAPI_MailBox.c 119
USB_Init_ConfigureUSB port 0 enter power save done
USB port 1 enter power save done
USB_Init_Configure done...
Flash is detected (0x0904, 0x1C, 0x30, 0x16)
sar input test...
s8SN0(24) s8SN1(25)
AC on and DC on GOGOGO!!!!!!
DSP code loaded successfully
DVB-T Software Version: 0.00
[Board]: BD_MST216A_JNS_10A_9463
[Panel]: CAS_AF080A080B_1
[MEMORY_MAP]: MMAP_64MB
[DRAM SIZE]: 64 MB
[FLASH SIZE]: 4 MB
[Mirror]: 0
[ENABLE_PWS]: 1
[ENABLE_POWER_SAVING_DPMS]: 0
[DEMO_FINE_TUNE]: DFT_STD_FULLHD_CMO216
[ENABLE_DLC]
[MWE]
[DISPLAY_LOGO]
[ENABLE_POWERON_MUSIC]
GMT+8, 2024-12-19 21:09 , Processed in 0.048276 sec., 9 queries .
