查看: 7863|回复: 5
创维8K86正常开机信息
发表于: 2015-11-7 14:53:30
创维8K86正常开机信息
Boot-Preloader T8032 NO ack!(启动预载T8032结束)
DRAM Channel A Calibration.(开始检测DDR)
HW Byte 0 : DQS(9 ~ 35), Size 27, Set 22.
HW Byte 1 : DQS(7 ~ 32), Size 26, Set 19.
HW Byte 2 : DQS(10 ~ 32), Size 23, Set 21.
HW Byte 3 : DQS(3 ~ 33), Size 31, Set 18.
DRAM A Size = 256 Mbytes.
Boot   (开始检测BOOT)
Start Pmain
0x000030a4
NID=0x9510daec
LZHS addr:0x00100040
LZHS size:0x0005d150
LZHS checksum:0x000000ca
Boot
Start Lmain
MT5395 Boot Loader v0.9
MUSB none SoftReset 0x29424 = 0x01030000.
MUSB pBase = 0xF0029000 init ok.
MUSB pBase = 0xF002E000 init ok.
Boot reason: A/C power on!!
Load HDMI internal EDID.................
SIF_Master0: new design
SIF_Master1: old design
Set IRCLKSEL as 6 for USR TYPE IR!
Load T8032 FW (addr: 0x  d34194, size: 12288)success!!
T8032 FW version: 66
LDR_FlashCopy 0xf010 0x2ba80 0x80
Detect SLC NAND flash ID: 0x9510DAEC
Detect SS K9F2G08U0B NAND flash: 256MB
NAND_BDM_Mount: Partid=0, offset=0x0, size=0x200000
[BDM] Partition: 0, Bad Block Count: 0
Boot reason: A/C power on!!Boot reason: A/C power on!!Org:0x30 Flags:0x30
Do USB upgrade(常规检测,是否有升级需求)
No USB device.
USB upgrade stop
Boot reason: A/C power on(上电)!!Not support [LdrLedBlinkikng]!!
Reset Demod GPIO=41, 0->1
NAND load lzhs header from 0x40000 to dram(0xfe3060), size=2048(加载NAND开始)
Decompression uboot to 0x00f00000...
NAND load image from 0x40000 to dram(0xfe3060), size=0x33550
LZHS hardware decode start
LZHS hardware decode done
Starting image...
U-Boot starts...
NAND Flash:  Detect NAND flash ID: 0x9510DAEC detDetect SS K9F2G08U0B NAND flash: 256MB(detect:检测)
256 MiB
Booting sequence is from NAND Flash
In:    serial  (串行)
Out:   serial
Err:   serial
Boot from kernelA and rootfs at partition 6
Hit any key to stop autoboot:  0 (按任意键停止自动引导)
Partition rootfsA defined at mtdparts:
ID:6, Offset:0x00c00000, Size:0x00600000
Loading from nand0, offset 0x800000
Automatic boot of image at addr 0x00008000 ...
## Booting kernel from Legacy Image at 00008000 ...
   XIP Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux........................................................................................ done, booting the kernel.
INIT: version 2.86 booting(init:初始化)
Mounting local filesystems: mount mount: according to /proc/mounts, /dev/root is already mounted on /
Running rc.local...
net.ipv4.tcp_window_scaling = 6
# mount basic
UBI device number 0, total 280 LEBs (35553280 bytes, 33.9 MiB), available 0 LEBs (0 bytes), LEB size 126976 bytes (124.0 KiB)
real    0m 0.10s
user    0m 0.00s
sys     0m 0.05s
real    0m 0.14s
user    0m 0.00s
sys     0m 0.09s
kobject_add_internal failed for ramzswap0 with -EEXIST, don't try to register things with the same name in the same directory.
ERROR: ld.so: object '/3rd/lib/preloadable_libiconv.so' from LD_PRELOAD cannot be preloaded: ignored.
[AppManager]init
[AppManager]init dfb start
input thread's parent pid is 304 tid is 304
[DirectFB]: Wait to Init IR...!
==>DFB capability not changed!
[ProcessManager]init
[AM] init succeed
--1,8--
[AM] init input NON_CANONICAL_INPUT success
                                           [AM] default process state '4' 'dtv_app_mtk'
        [dtv_app_mtk]>ERROR: ld.so: object '/3rd/lib/preloadable_libiconv.so' from
                                  [dtv_app_mtk]>[ FakeDM ] Init...
[FakeDM] Init FM...                                               [dtv_app_mtk]>
/dev is created./mnt is already existed.  That is OK.
/mnt/usb is created.[FakeDM] FM inited...            [dtv_app_mtk]>
[DM] _dm_cb_msg_thread enter             [dtv_app_mtk]>
[DM] _dm_nfy_req_thread enterdtv_app_mtk]>
[DM] _dm_nfy_req_thread get_nl_sock:57mtk]>
[DM] _dm_open_dev_thread: entered     [dtv_app_mtk]>
                                 input thread pid is 304 tid is 307
        original scheduler policy 0
        scheduler nice -10
        original child scheduler policy 0 prio 0
        new child
scheduler policy 2 prio 99
                    Start to wait IR event...
[FM-Linux]Mount /dev/mtd8 to /basic successfully._app_mtk]>
[FM](/dev/mtd8) is mounted to (/basic) successfully(0)app_mtk]>
{DT} Real Time Clock is available on this system.     [dtv_app_mtk]>
<AM> wakeup reason = 6                           [dtv_app_mtk]>
{CDB} Loading metadata (version 7)]>
{CDB} Loading metadata (version 7)[dtv_app_mtk]>
INFO: __357__(sys_ap_start.c:a_appl_init)p_mtk]>
INFO: __358__(sys_ap_start.c:a_appl_init)[dtv_app_mtk]>
INFO: __359__(sys_ap_start.c:a_appl_init)[dtv_app_mtk]>
INFO: __360__(sys_ap_start.c:a_appl_init)[dtv_app_mtk]>
[ACFGIPC]@@@@@@@@@@@@@@@@@videoSettingThreadCreate@@@@@@@@@@@@@@@@@[ACFGIPC]+++++++++++++++++++++videoSettingThreadFunc
msgReceiveId :0x0
msgSendId    :0x0
INFO: __363__(sys_ap_start.c:a_appl_init)
                                         [dtv_app_mtk]>
china_atv_vol_get_comp line 5794 ui4_mask_idx=0
                                               [dtv_app_mtk]>
nav_custom_register_components@@@@@@@@@@@@@@@@@@@1122
a_tv_set_input_src_id#########8138######t_g_crnt_src_ret_id=0
a_tv_set_input_src_id#########8141######t_g_b_first_src=1
a_tv_set_input_src_id#########8153######t_g_last_src_ret_id=0
a_tv_set_input_src_id#########8154######t_g_crnt_src_ret_id=0
a_tv_set_input_src_id#########8155######ui1_input_src=0
<ACFG> Open audio outport: 0 ms                [dtv_app_mtk]>
{APP_TV} TV Brdcst type = 1  TV_SCART Enabled: 0 Monitor_SCART Enabled: 1
        [dtv_app_mtk]>
china_atv_vol_get_comp line 5794 ui4_mask_idx=4
                                               [dtv_app_mtk]>
_nav_updater_usb_handle_msg@@@@@@@@@@@451@@@@@@@@@@@@@@b_delay_start=0
Call function : a_msg_convert_register.                               [dtv_app_mtk]>
                                        [dtv_app_mtk]>
Call function _mc_app_init_fct.
                                [dtv_app_mtk]>
<msgconvert> msg_convert_custom_init
                                     [NPTV]AdaptiveLuma: Enable Luma Histogram
Set TDTV datamode to(1)
bDrvUpdateInternalFrameRate
[dtv_app_mtk]>
###<_lb_ver_info_create 255><bK08Flash==1>###
[dtv_app_mtk]>
              [dtv_app_mtk]>:dtv_app_mtk,am,:started=menu
                                                         [dtv_app_mtk]>
        [dtv_app_mtk]>:dtv_app_mtk,am,:started=factory
# mount 3rd        [dtv_app_mtk]>
           [dtv_app_mtk]>UBI device number 1, total 520 LEBs (66027520 bytes, 63.0 MiB), available 0 LEBs (0 bytes), LEB size 126976 bytes (124.0 KiB)
        [dtv_app_mtk]
>rea0m 0.19s
       [dtv_app_mtk]>user       0m 0.00s
                                        [dtv_app_mtk]>sys       0m 0.13s
        UBIFS: recovery needed
UBIFS: recovery completed
[dtv_app_mtk]>real      0m 0.06s
        [dtv_app_mtk]>sys       0m 0.02s
        [dtv_app_mtk]>[FM-Linux]Mount /dev/mtd9 to /3rd successfully.
[dtv_app_mt[FM](/dev/mtd9) is mounted to (/3rd) successfully(0)
usbcore: registered new interface driver r871x_usb_drv
rtw driver version=v2.0.1126.20101020
usbcore: registered new interface driver rtw_usb_drv
<WPA> Creat WPA supplicant
                          [dtv_app_mtk]>
<WPA> send init indication by supc
<WPA> wndrv indication: success   [dtv_app_mtk]>
[INET] x_net_network_init      [dtv_app_mtk]>
[INET] share memory initializedpp_mtk]>
                               [dtv_app_mtk]>
[Dragon_Inet] :_read_mac_config$$$$$$$
                                      loop: module loaded
SCSI subsystem initialized
Driver 'sd' needs updating - please use bus_type methods
USB USB_PWR_SWITCH_GPIO_CUST.
hub reset: Set GPIO20 = 0.
[USB]MUSB ResetPhy u4Reg 0x24= 0x1c30000
MtkUsbHcd MtkUsbHcd.0: USB Host Controller
MtkUsbHcd MtkUsbHcd.0: new USB bus registered, assigned bus number 1
MtkUsbHcd MtkUsbHcd.0: irq 15, io mem 0xf0029000
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
[INET] _read_mac_config: the network config star: star_open(eth0)
star: request interrupt vector=8
star: Internal PHY mode
checksum err, byte: 0xff, ret: 0xea
[INET] x_neMtkUsbHcd MtkUsbHcd.1: USB Host Controller
MtkUsbHcd MtkUsbHcd.1: new USB bus registered, assigned bus number 2
MtkUsbHcd MtkUsbHcd.1: irq 11, io mem 0xf002e000
usb usb2: configuration #1 chosen from 1 choice
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
t_ni_set_mac, eth0 0xbc83a7219e46
[INET] if disable eth0           [dtv_app_mtk]>
[INET] if enable eth0 [dtv_app_mtk]>
[INET] if enable eth0[dtv_app_mtk]>
[INET] x_net_set_if_type (6)p_mtk]>
                            Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
usbcore: registered new interface driver usbhid
usbhid: v2.6:USB HID core driver
[INET] wifi0 is unplug!
[INET] eth0 is unplug! [dtv_app_mtk]>
                      Get MW OP
FFFFFF Set plane enable by MW OP idx: 0 enable:0
Get MW OP
FFFFFF Set plane enable by MW OP idx: 0 enable:1
Hub: Reset GPIO20 = 1.
CustomCode is 0x e0e, KeyCode is 0x11
U4KEY: 0x8f001
pbFlag =1[MW_IRRC_NotifyFunc] sound play.
[dtv_app_mtk]>
Get MW OP
Get MW OP
[dtv_app_mtk]>
              [dtv_app_mtk]>:dtv_app_mtk,am,:paused=navigator
scrn_svr_view_hide@@@@@@@@@@@@@@@@@@@@@@@@@@@516[menu_custom_resume 594][ENTRY HERE!!!]can not do here!
        [ir move btn repeat] REPEAT Frame, send PrevKey 0x   8f001
[dtv_app_mtk]>(#) DirectFBError [p_dst_surf->p_dfb_surf->Blit( p_dst_surf->p_dfb_surf, p_src_surf->p_dfb_surf, &dfb_rect, i4_dst_x, i4_dst_y)]: Invalid area present!
[dtv_app_mtk]>
           [dtv_app_mtk]>:dtv_app_mtk,am,:resumed=menu
U4KEY: 0x8f001[MW_IRRC_NotifyFunc] sound play.
Get MW OP
Get MW OP
[dtv_app_mtk]>
============error rm_user_nfy_fct , handle = 0x150655=========
        [dtv_app_mtk]>
                                               [dtv_app_mtk]>
[dtv_app_mtk]>
              [dtv_app_mtk]>:dtv_app_mtk,am,:resumed=navigator
                                                              [dtv_app_mtk]>
        [dtv_app_mtk]>:dtv_app_mtk,am,:paused=menu
        Get MW OP
Get MW OP
发表于: 2017-7-17 16:45:01
谢谢楼主分享!
发表于: 2017-7-24 21:10:13
好资料,保存下.
发表于: 2017-12-24 10:45:52
在这谢谢师傅们的好资料
发表于: 2017-12-31 22:28:54
在这谢谢师傅们的好资料
发表于: 2018-1-20 09:33:54
在这谢谢师傅们的好资料
GMT+8, 2024-12-19 17:47 , Processed in 0.074189 sec., 14 queries .
